michael9000
multi threading in c
Mon Nov 30, 2020 2:04 am
Hi
I am looking to build an app to expand my coding skills that will likely include multithreading in the form of a 3d renderer.
I expect to have to learn a new language to achieve this. Currently I only know python.
C looks interesting but I'm unclear how well c lends itself to multithreading.
So, my question, is c a practical language to write multithreaded code?
Michael
DarkElvenAngel
Re: multi threading in c
Mon Nov 30, 2020 2:23 am
C programming and multiple threads are no problem at all.
LdB
Mon Nov 30, 2020 2:27 am
jahboater
Mon Nov 30, 2020 2:30 am
Do you still need pthreads?
See section 7.26 in the ISO standard.
Pi4 8GB and Pi4 4GB running Raspberry Pi OS 64-bit
knute
Mon Nov 30, 2020 2:50 am
Threads are pretty simple in C++. The compiler command line is in the code.
#include <iostream>
#include <unistd.h>
#include <thread>
// g++ mt.c -o mt -lpthread
using namespace std;
void a() {
    for (int i=0; i<25; i++) {
        cout << "a";
        cout.flush();
        sleep(1);
void b() {
    for (int i=0; i<12; i++) {
        cout << "b";
        cout.flush();
        sleep(2);
int main(int argc,char *argv[]) {
    thread a_thread(a);
    thread b_thread(b);
    a_thread.join();
    b_thread.join();
    cout << endl;
pi:~/bin$ mt
ababaabaabaabaabaabaabaabaabaabaabaaa
LdB
Mon Nov 30, 2020 3:04 am
I still avoid C11 threads too many problems and different implementations. All supposed to being fixed in C2x lets see :-)
Rather than me give you biased personal views you can just search for the official defect list at the standards committee and work out how big a problem it is to what you want to do.
illecitnom
Mon Nov 30, 2020 2:29 pm
If your purpose is exploiting multi-core capabilities of today CPUs, why don't you get the easiest way, i.e. C + OpenMP?
OpenMP comes with the C/C++ (but also Fortran) compiler and is as easy as
#include <omp.h>
int i;
# pragma omp parallel num_threads (4) // run with 4 threads
... block of code to be distributed among cores
Then compile with -openmp option (or equivalent, may vary for different compilers)
gcc my_test.c -openmp -O3 -o my_test
If you compile without the -openmp option the openmp pragmas are simply ignored and the program is executed single-thread
PS: the choice of C sounds good to me
michael9000
Mon Nov 30, 2020 10:11 pm
Thankyou all for your answers. I will go with C.
Michael
Return to “C/C++”
