samulio
Any alternative library of WiringPi in C++
Fri Oct 02, 2020 12:06 pm
I am working with pi 4 B Module. When I go to use Wiring pi I see a shocking news that was WiringPi is deprecated. What can I do now. Please help me
B.Goode
Re: Any alternative library of WiringPi in C++
Fri Oct 02, 2020 12:10 pm
viewtopic.php?f=66&t=287021&p=1735019#p1735019
jahboater
Sat Oct 03, 2020 9:10 am
This one is well written, well supported, and fast:
http://abyz.me.uk/rpi/pigpio/
Pi4 8GB running PIOS64 Lite
dsyleixa123
Sat Oct 03, 2020 9:21 am
but that lib is not easily understandable and usable in the sense of Wiring/Arduino C/C++ beginner- und layman--friendlyness, and multiple example codes for either function are hard to find.
Wishful (but also not officially available for wiringPi) would be a lib publication like the Arduino and espressif communities do, on github, providing a hierarchically structured repo with source codes and multiple examples in dedicated example subdirs, e.g.
https://github.com/arduino-libraries
https://github.com/espressif/arduino-es ... /libraries
Sat Oct 03, 2020 9:39 am
Who says?
"deprecate" means:
"to not approve of something or say that you do not approve of something"
Anyway, WiringPi is still very much alive and well, supported by those who do not disapprove of it: https://github.com/WiringPi/WiringPi
A statement here recently by WiringPi's original creator hinted that he may get back to supporting it in the future if circumstances permit.
B.Goode
Sat Oct 03, 2020 9:48 am
Who says?
Its developer/maintainer, apparently, unless you think this 12-month old bog post is somehow a spoof -
http://wiringpi.com/wiringpi-deprecated/
(Although the fact that the announcement is a year old means it should not be considered 'shocking... ' )
Sat Oct 03, 2020 10:03 am
Yes. I know. I read that a year ago. I totally sympathize with the maintainer's problems there.
But this is Free and/or Open Source software we are talking about. It is expected that it can live on without support of the original creator. That is largely the whole point of it.
I conclude that whilst the maintainer (and others) may regard the versions he created and released as "deprecated", there is no reason the software should be regarded as such. Especially if others are carrying on maintenance and development of it.
Classic examples of this are MySql, which many would deprecate today, but it lives on very successfully as MariaDB. Or what about Java?
Yes, it's a bit late to be shocked.
jahboater
Sat Oct 03, 2020 10:45 am
The examples are here:
http://abyz.me.uk/rpi/pigpio/examples.html
This is for the Raspberry Pi by the way, not the Arduino.
dsyleixa123
Sat Oct 03, 2020 11:56 am
of course it's for the Pi, WiringPi is also for the Pi, as it uses (partially) the Wiring=Arduino ideas.
OTOH, e.g. looking at rotary encoder pigpio files
http://abyz.me.uk/rpi/pigpio/code/rotary_encoder_c.zip
http://abyz.me.uk/rpi/pigpio/code/RED.zip
the examples are hardly understandable (not to say: confusing) for a hobby user, it's looking rather obfuscated.
Also code for more devices with convenient API functions would be wishful ( e.g., ads1115, mcp23011, pcf8574, CMPS12, mpu6050(dmp), mpu9250(dmp), bmp280, GPS Neo-6M, UART-communication from Raspi to Raspi or Arduino), providing tutorial-overviews and extensively commented source code also for teaching purposes
As to the library-APIs, the Wiring=Arduino philosophy for beginner-friendlyness also for Pi-users is the crucial idea.
The objective of the thesis was to make it easy for artists and designers to work with electronics, by abstracting away the often complicated details of electronics so they can focus on their own objectives.
https://arduinohistory.github.io/
http://people.interactionivrea.org/h.ba ... ow_res.pdf
As to the TOP, I still use WiringPi and IIRC it's finally still part of the Raspi OS distros (Stretch + Buster, apt-package).
kenblu24
Tue Oct 06, 2020 1:25 am
That implies that it is actively being worked on. The unofficial wPi mirror says in the readme:
Pull-requests may be accepted to add or fix support for newer hardware, but new features or other changes will not be accepted.
It's basically on end-of-life support, and barely even that, as there's no actual compiled release.
Tue Oct 06, 2020 1:42 am
I don't know what you mean by that.
"end-of-life" in the software world generally refers to closed source, proprietary, copyrighted software who producer has announced they are no longer developing or supplying it and will cease all support soon. After which there is no way to keep it alive as the source is not available and licensing prevents it. Think old versions of Windows etc.
As I said, this is open source software we are talking about. As long as there is even one person fixing bugs as they are found and adapting to new hardware, and one person using it then it is as alive as the day it was created.
I don't see that "new features or other changes" is required for it to be said that the code is still alive.
And as this is open source software, a library to be built into other peoples code, then compiled releases are not required for it to be alive and useful.
dsyleixa123
Tue Oct 06, 2020 7:42 am
not to forget:
there is already a fork supporting the Pi 4, thanks to Milliways:
viewtopic.php?p=1730729#p1730729
it just has to be maintained for further updates, upgrades, and extensions.
Perhaps by DougieLawson?
viewtopic.php?p=1725904#p1725904
Return to “C/C++”
