rvinoth39
need somagic drivers easycap
Mon Jan 07, 2013 10:24 am
hi everyone. i'm new to this forum. need some help.
i've a 1/3'' sony ccd pal camera cxd3142r . it has two wires one for power supply 12V and another BNC.
Now i got bnc to rca male converter cable and connected to easycap D60 v3.1c smi grabber chipset.
now the question is how can i get easycap working with my pi model B???
after lsusb it detects and shows the easycap. i've mplayer installed and as well as ffmpeg.
how do i capture the video????
rvinoth39
Re: need somagic drivers easycap
Tue Jan 08, 2013 10:44 am
Hi all.. i successfully compiled somagic firmware and now i'm trying to get the video from s-input
rvinoth39
Thu Jan 10, 2013 6:34 am
:( today when i restarted did lsusb. it showed no firmware again.... today i did everything the same as i did yesterday. but yesterday firmware was installed successfully.. now i think i've to install a fresh copy of OS and begin from start
rvinoth39
Fri Jan 11, 2013 6:14 am
hi guys again i've successfully installed somagic driver by installing a clean OS. now after i do sudo somagic-capture -c its showing unexplected block some numbers
rvinoth39
Fri Jan 11, 2013 10:51 am
i'm getting this error
Unexpected block, expected [aa aa 00 00] found [00 00 00 00]
rvinoth39
Fri Jan 11, 2013 12:09 pm
if anyone want to know how to install easycap v3.1c dc60 smi chipset pls let me know.. i'll reply how to do step by step
ramouch0
Wed Jan 23, 2013 4:49 pm
Yes, I am very interested in how you made it.
So far I've managed to compile the drivers but I have the same error as you :
addy
Fri Jan 25, 2013 10:54 am
Definitely very interested. It's my next planned project - if you could save me from reinventing the wheel it'd be awesome! Thanks!
- A
rvinoth39
Mon Jan 28, 2013 8:59 am
Sorry guys.. misunderstood.. i've compiled the drivers successfully but the unexpected block error comes... its because of USB issue. the kernel doesn't recognize the data from easycap. Have to try with some other kernel. i'm trying with different kernels. will intimate soon if it works.
I said the steps for compiling drivers alone.. the result is when we work with sudo somagic capture, unexpected block error comes. some guys didn't know to compile drivers, thats y i posted like that only for compiling drivers. sorry :idea:
jfrbernard
Tue Feb 05, 2013 11:58 am
I'm trying to do the same thing.
I've tryed with SmiUsbGrabber3C.sys driver and get the same error than you.
With my easycap, i receive a cd and the driver is SmiUsbGrabber3E.sys.
I did a fresh install of last rasbian os, install/compile somagic & somagic tools and install SmiUsbGrabber3E.sys firmware.
When i do a somagic-init, my usb device disapear and no new device appear.
Anyone have an idea ?
P.S. to list my usb devices i used :
ls /dev
lsusb
usb-devices I get
hat fox
Tue Feb 05, 2013 6:11 pm
I'm having the same issue. I compiled successfully but just get the unexpected block error.
I've tried somagic and the capture device on a laptop running Mint and all works fine (although I only tested it for a few minutes), so it's not a dud device.
I noticed there was a discussion here:
https://groups.google.com/forum/?fromgr ... 6YOygTXtqs
about running somagic on the Raspberry Pi, which suggests it's a Pi or ARM issue, possibly specific to the Pi kernel.
I have wondered if it's a power issue, perhaps the Pi's USB ports aren't giving enough power. Might be worth trying it with a decent powered hub.
In the mean time I'm looking for other Easycaps, there are at least 4 versions of these all with different chipsets, with different levels of Linux support. More info here:
http://linuxtv.org/wiki/index.php/Easycap
jfrbernard
Wed Feb 06, 2013 6:44 am
hat fox wrote: I have wondered if it's a power issue, perhaps the Pi's USB ports aren't giving enough power. Might be worth trying it with a decent powered hub.
Thanks. You're true, with a powered usb hub, the device doesn't disaperar anymore.
The somagic-capture --test-only doens't return error message.
Still working on it...
J-F
24hour
Sun Jul 21, 2013 12:54 am
Hello Guys,
any news about this?
rvinoth39
Mon Jul 22, 2013 5:00 am
no updates guys
still same error
drspringfield
Sun Oct 27, 2013 3:40 pm
It's a problem with isochronous USB on RPi (see http://www.raspberrypi.org/phpBB3/viewt ... =33&t=9927).
drgr33n
Mon Dec 23, 2013 1:55 pm
Just managed to get the V4L2 kernel modules compiled.
http://www.raspberrypi.org/phpBB3/viewt ... 71&t=64077
Rado
Tue May 06, 2014 3:00 pm
Hey guys, I thought I'd share my experience with a Somagic device too. I have the 4-input model (1c88:003f), all testing was done using a powered hub.
  • Pi model B, using easycap-somagic-linux drivers: Unexpected block errors
  • Pi model B, using kernel driver from drgr33n: getting "select timeout" errors and random freezes
  • BeagleBone Black, using easycap-somagic-linux drivers: I was able to make it work, however, I couldn't get stable image output - whenever I tried to capture a frame using mplayer, I could only get partial / broken frames. The same calls/parameters worked fine on an x86 linux with the device.
I needed this for a project which involves a few cameras (hence the 4-input model) and interval-based static captures (no video stream) only. Anyway, for now I will probably give up as I ran out of time. Does anyone know if the other chipset clones also come in 4-input versions? I think I've seen reference to an STK1160-based device with 4 inputs, but with em28xx ones, the chances of making it work on Pi or BBB would probably be better right? Thanks for any input/ideas.
cnguyen
Thu May 08, 2014 3:37 pm
raspberry pi with composite video input would be awesome.
Rado
Fri May 09, 2014 6:07 am
cnguyen wrote:raspberry pi with composite video input would be awesome.
It would, but useful only to a very small group of Pi users, and thus, it wouldn't justify the cost increase (development / manufacturing) I guess... :|
neufena
Fri Sep 19, 2014 12:31 pm
Does anyone have a copy of SmiUsbGrabber3E.sys or SmiUsbGrabber3F.sys? I can't find my driver disc and have search all over the net but can only find the 3C variant.
Fri Sep 19, 2014 12:56 pm
neufena wrote:Does anyone have a copy of SmiUsbGrabber3E.sys or SmiUsbGrabber3F.sys? I can't find my driver disc and have search all over the net but can only find the 3C variant.
The Driver Disk would not inlude ARMv6 Drivers, plug the device into the RPi and post output of lsusb
Thinking outside the box is better than burying your head in the sand...
neufena
Fri Sep 19, 2014 12:59 pm
No but the linux driver requires firmware which you extract from the windows driver (.sys file)
SteveDee
Fri Sep 19, 2014 3:04 pm
neufena wrote:Does anyone have a copy of SmiUsbGrabber3E.sys or SmiUsbGrabber3F.sys? ...
Try asking here: https://code.google.com/p/easycap-somagic-linux/
Rado
Fri Sep 19, 2014 3:29 pm
I've got the "F" one in my Projects folder from the time I last played with it - I'll send you a PM with the download link shortly.
Return to “C/C++”
