dsyleixa123
wiringPi: incidentally digitalWrite() to a pin which is defined as input?
Sun Aug 02, 2020 5:53 pm
hello,
using wiringPi, what happens if I incidentally digitalWrite() to a pin which is defined as pinMode(pin,INPUT)?
Re: wiringPi: incidentally digitalWrite() to a pin which is defined as input?
Sun Aug 02, 2020 5:55 pm
Try it and see? It won't break anything.
I haven't tried it, but I would expect it to either throw an error, or set the output state, which won't have any effect on an input pin.
Unreadable squiggle
dsyleixa123
Sun Aug 02, 2020 5:58 pm
I actually did it already but didn't observe anything obvious - not sure if I perhaps might damage sth though
Sun Aug 02, 2020 9:32 pm
Have you noticed that wiringPi is deprecated. You should NOT use deprecated code for new development as it may break in future and will NOT work on any future RPis.
http://wiringpi.com/wiringpi-deprecated/
fbe
Sun Aug 02, 2020 9:49 pm
digitalWrite writes to the GPSET*/GPCLR* registers.
If the GPIO pin is being used as an input (by default) then the value in the SETn field is ignored. However, if the pin is subsequently defined as an output then the bit will be set according to the last set/clear operation.
https://www.raspberrypi.org/documentati ... 11_1p0.pdf
Please stop using wiringPi!
dsyleixa123
Mon Aug 03, 2020 7:24 am
As long as wiringPi will not be further maintained again, I'll NEVER EVER buy new Raspis again and also won't use Buster etc, and so just work on my old Pis using Stretch. All works like a charm with wiringPi and all my console and my qt5 creator programs and many more, so no need to change all that.
@fbe:
thanks for clarification, of course I'll stay with wiringPi though
- pigpio is far too hard to understand, provides far too few example source codes, and it's not compatible to my program codes using the wiringPi API libs, and Arduino-like API syntax is indispensable! 8-)
Return to “C/C++”
