C++ running Python Problems
Posted: Tue Jun 30, 2020 8:19 pm
by CodeHelp
First, sorry if this is the wrong place, I'm a beginner to Raspberry Pi and C++ and Python. I'm trying to do the tutorial here: https://www.codeproject.com/Articles/82 ... splus-code , but I keep getting errors (I'm using Geany). The program will compile just fine, but when I build I get runtime errors. I've searched extensively for an answer and have found everything from python problems to alternate build commands, but cannot figure it out for the life of me. Any help is much appreciated.
PyTest.cpp
#include </usr/include/python3.7/Python.h>
int main(){
Py_Initialize();
PyRun_SimpleString("print('it Worked')");
Py_Finalize();
return 0;
Error Messages
g++ -Wall -o "PyTest" "PyTest.cpp" -lm -ldl -lpthread -pthread (in directory: /home/pi/Desktop/CtoPython)
/usr/bin/ld: /tmp/cc1X5N10.o: in function `main':
PyTest.cpp:(.text+0x14): undefined reference to `Py_Initialize'
/usr/bin/ld: PyTest.cpp:(.text+0x20): undefined reference to `PyRun_SimpleStringFlags'
/usr/bin/ld: PyTest.cpp:(.text+0x24): undefined reference to `Py_Finalize'
collect2: error: ld returned 1 exit status
Compilation failed.
Re: C++ running Python Problems
Posted: Tue Jun 30, 2020 9:30 pm
by PeterO
It looks like you aren't linking the appropriate library....
Here's how I found out....
$ pkg-config --list-all | grep Python
python              Python - Python library
python-3.7m         Python - Python library
python-3.7          Python - Python library
python2             Python - Python library
python3             Python - Python library
python-2.7          Python - Python library
$ gcc -o t t.c $(pkg-config --cflags --libs python3)
$ ./t
it Worked
Also the #include line shouldn't have the full path in it
#include <Python.h>
int main(){
Py_Initialize();
Py_Finalize();
return 0;
You need to add the include paths given by "pkg-config --cflags python3" to your geany project and add the library given by "pkg-config --libs python3" to the librarys to link.
PeterO
Posted: Tue Jun 30, 2020 10:37 pm
by CodeHelp
Thanks so much! I've got it working just fine now.
