waelCh
no such file or directory!!
Fri Dec 21, 2012 5:03 pm
Hi everyone..
i used to develop a little c++ program. I used ubuntu 12.04 -32 bits to develop my program. i have installed the "Cross Compiling Toolchain" in order to get an application wich can turn into the Raspberry.
The problem is that when i implement the program in the raspberry and i execute the command:
"./firsttest" (firsttest is the name of my application)
I got this message:
"-bash: ./firsttest: No such file or directory"
while the file "firsttest" exists!!
please i need help..!!
flyinghappy
Re: no such file or directory!!
Fri Dec 21, 2012 5:04 pm
Maybe set the file to be executable? Sounds like it may be something like that...
Pi with ArchLinux running a minidlna/samba home server
waelCh
Fri Dec 21, 2012 5:13 pm
I have done it and i make it executable with the command:
"chmod +x firsttest"
But nothing sound to be changed.
redhawk
Fri Dec 21, 2012 5:19 pm
If you compile a file it should automatically have the "x" executable flag.
./firstest should execute it, however using full path or `pwd`/firsttest should work as well.
Just out of curiosity you edit "firsttest" does it start with the letters "ELF" ??
Richard S.
Joe Schmoe
Fri Dec 21, 2012 5:31 pm
You usually get weird error messages like this when you try to execute a program compiled for one architecture on another architecture. Or, put more succinctly, when you try to run it on the "wrong" architecture.
Since cross-compilation is involved in your setup, I would look to that for the problem locus.
P.S. I used to hit this from time to time early on when I would take something from my Linux x86 boxes and try to run it on the Pi (which obviously doesn't work - but it is easy to forget that).
recliq
Fri Dec 21, 2012 6:21 pm
file will tell you what kind of file it is, ie. if it's a binary file and for which architecture it was build:
file firsttest
You should get something like this:
firsttest: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0xc410845b0312afa14b9e56dac6edaa64732c0b42, not stripped
ecw
Fri Dec 21, 2012 6:36 pm
Run ldd against it. There's a chance a shared library it expects is missing.
waelCh
Fri Dec 21, 2012 7:37 pm
well.. when i executed "file firsttest", i have got:
libs), for GNU/Linux 2.6.26, BuildID[sha1]=0xce75f733c0e4fce5bca9ab39a518cd6283868177, not st
ripped
and when i executed "ldd firsttest", i have got:
not a dynamic executable
Joe Schmoe
Fri Dec 21, 2012 8:01 pm
waelCh wrote:well.. when i executed "file firsttest", i have got:
ripped
Those are certainly the right tests to run.
It tells me that:
1) It was close enough to the right thing to "fool" the "file" command. I.e., "file" isn't very exact; it pretty much just believes what you tell it.
2) It isn't close enough to actually run on the Pi - which is why "ldd" said "What is that?"
All of which means that your cross-compilation environment is not quite configured right.
waelCh
Fri Dec 21, 2012 9:30 pm
So bad..
can you give me a great tutorial wich can describe me how to configure the toolchain suit?!
rfrankla
Thu Dec 27, 2012 11:40 pm
Hi, I created a procedure to build a cross-compiler. This is simply a record of what I did for myself, I have not cleaned it up, BUT it worked first time for me.
https://docs.google.com/document/d/1gtl ... Xa06s/edit
*** NOTE: do not move the compiler after "ct-ng build" of the compiler. If you want it in a different place you must rerun "ct-ng menuconfig" and set another in: Paths & Misc: --> Set "Prefix directory" then run "ct-ng build" again. ****
Also note: My procedure does NOT change/add-to PATH environment variable. There is no need to do this for cross-compilers, I did not need to do it to get good results!
These two notes contradict instructions in the Raspberry Pi wiki at eLinux. -- I believe the wiki is incorrect on these points.
Return to “C/C++”
