Allan V
Reading a GPIO Switch in C language
Fri Dec 20, 2019 9:54 pm
I have this code for incrementing a counter each time a GPIO pin is HIGH. I am interested in each time GPIO pin 7 is HIGH:
if (7)
      counter += 1;
else
      counter = counter;
This is written in C, and works for my application.
Paeryn
Re: Reading a GPIO Switch in C language
Sat Dec 21, 2019 12:00 am
if (7)
counter += 1;
else
counter = counter;
As with the OP, this code will always increment counter as 7 (being as it is not zero) will always evaluate to true, you have to actually test the value of reading a GPIO otherwise you are just testing the mathematical property that the number 7 is not the number 0. And well done on necroing a 4 year old thread.
<edited due to split from original thread>
mahjongg
Sat Dec 21, 2019 1:55 pm
split off, and moved to C/C++
cmrincon
Tue Dec 24, 2019 7:01 pm
Use wiring pi library
You can look for examples here: http://wiringpi.com/examples/
fbe
Tue Dec 24, 2019 10:18 pm
Avoid the wiringPi library. It is deprecated http://wiringpi.com/wiringpi-deprecated/ :(
dsyleixa123
Wed Dec 25, 2019 10:19 am
wiringPi is still available, and due to it's user-friendly Arduino-like functions it's still undefeated....
(hopefuly somebody will take the efforts to maintaining it further on!)
Wed Dec 25, 2019 2:07 pm
I don't think wiringpi is deprecated at all. Despite what Gordon says.
It's alive and well here:
https://github.com/search?q=wiringpi
https://github.com/WiringPi/WiringPi
There is even discussion on discord with 500 participants.
But if one just want to read and write GPIO from C one does need wiring pi at all. Just go to the registers directly: https://elinux.org/RPi_GPIO_Code_Sample ... ter_access
Return to “C/C++”
