platform independent c++ string length
Posted: Fri Dec 13, 2019 8:13 am
by ksharindam
I am creating a cross platform program which has a pdf writer.
I am writing string like this,
    std::string header;
    header = "%PDF-1.4\n";
    int offset = header.size();
    std::ofstream stream;
    stream.open(filename);
    stream << header;
    stream.close();
in both linux and windows, the returned offset is 9. In linux number of actual written bytes is 9, but in windows it is 10.
This may be due to the different line ending types. linux uses LF and windows uses CRLF (\r\n).
How can I get the actual size of the string that is written?
Or how can I use only LF newline even in windows platform?
Re: platform independent c++ string length
Posted: Fri Dec 13, 2019 8:33 am
by scotty101
Seems more like a question for stack overflow than a Raspberry Pi forum.
Posted: Fri Dec 13, 2019 8:53 am
by LdB
tellp
http://www.cplusplus.com/reference/ostr ... eam/tellp/
In your case read the value stream.tellp();
Posted: Fri Dec 13, 2019 11:35 am
by njh
It's not the question you asked, but: To write the identical PDF file on any platform (including a Pi) you should open a new file in binary mode and write the bytes required. Otherwise you will run into trouble when you write the "xref" section, or if you need any compressed or binary objects.
Posted: Fri Dec 13, 2019 11:50 am
by ksharindam
tellp
Tried it, but it returns 9 in both windows and linux.
Posted: Fri Dec 13, 2019 12:16 pm
by topguy
But you are saying that the file-size on Windows is 10 bytes ?
( I also think Njh had the best idea )
Posted: Fri Dec 13, 2019 12:21 pm
by ksharindam
Thanks. It works.
I opened the file in binary mode using...
stream.open(filename, std::ios::out|std::ios::binary);
