john77
Re: Problem using libgpiod
Tue Dec 31, 2019 6:22 am
DougieLawson wrote:
Mon Dec 30, 2019 11:36 pm
Are you using the right pin numbering scheme?
https://pinout.xyz/pinout/pin11_gpio17
https://pinout.xyz/pinout/pin16_gpio23
As I understood I should pass the BCM number (17) as an argument, not a physical pin (11).
I added
printf ("chip %p\n", chip);
printf ("line %p\n", line);
And I see
chip 0x3078c
line 0x30790
Also it should be
0x2f78c
0x2f790
shouldn't it?
Tue Dec 31, 2019 6:35 am
You've not told us what model of Raspberry you're using so it's impossible to tell you.
john77
Tue Dec 31, 2019 6:58 am
I'm not sure what model but it's quite old - it has 20-pin connector.
Tue Dec 31, 2019 8:11 am
Test your wiring with a small chunk of python3.
#!/usr/bin/python3
from gpiozero import LED, Button
from signal import pause
led = LED(17)
button = Button(23)
button.when_pressed = led.on
button.when_released = led.off
pause()
When GPIO23 is connected to GND the LED on GPIO17 should light up.
Notice the pause there so that the python3 program doesn't end before the button state is read and the LED is lit up. GPIO actions are very short lived.
john77
Tue Dec 31, 2019 8:53 am
It might be working good, no doubt. But my goal to get it running with gpiod lib. I develop in Qt C/C++.
Daniel Gessel
Wed Jan 01, 2020 3:35 pm
I believe the only documentation on libgpiod is the source code itself. Do you have that as reference? For output (controlling a pimoroni blinkt on a Pi4) I ended up using the ioctl calls directly as it seemed easier than using the library. I’m Not sure if the ioctl interface or libgpiod is kept more stable from kernel to kernel.
I’m confused as to why you think the pointers returned by the library should have any particular values: iirc, they are just the results of malloc calls.
lanmrpi
Fri Jun 05, 2020 3:29 pm
did you ever figure out how to use the libgpiod library?
I managed to install it, and was able to reproduce the code for making an LED blink, however I was not able to read any pins, or attach an event/interrupt to a pin.
If you want, I can post the blink equivalent with the libgpiod library
Ron
swahren
Fri Jun 05, 2020 6:36 pm
libgpiod already contains binaries to play with: gpioinfo, gpioset, gpioget
Why not start playing with them?
lanmrpi
Fri Jun 05, 2020 10:39 pm
huh?..
I am writing something, in C, that decodes quadrature encoder. I have some C code that does work and do that with wiringPi, but want to do it with libgpiod of course, now that sysfs is deprecated.
Redkey
Wed Aug 26, 2020 2:11 pm
If you want, I can post the blink equivalent with the libgpiod library.
I would like to see your blink source code.
Ken
Return to “C/C++”
