Re: Where can I begin learning C/C++?
Mon Oct 14, 2019 6:14 am
plugwash,
Expected by who though? that is the question.
I was thinking of these people: WG21 (ISO C++ Committee): https://isocpp.org/wiki/faq/wg21 The people, starting with Bjarne Stroustrup who have invested a large part of their lives into creating C++.
When Stroustrup added classes to C he obviously had a desire to be able to program in a particular way using classes and objects which was not easy or even possible to do in C. He had created a new tool and had some vision as to how people should use it.
Similarly when templates were added to C++ enabling generic and meta programming.
Similarly with the algorithms of the STL aimed at a promoting a more declarative style of programming rather than endlessly rewriting variations of the "for" loop.
All these new features have come to C++ with the intention that they are used. Used to enable easier programming, better correctness, better performance and so on.
Many of those features have come with the intention that they displace use of older features for better, more robust ones. For example use of new/delete is now discouraged, auto_ptr is obsolete, STL algorithms are preferred over "for" loops, etc, etc,
In short C++ today is a very different language than it was twenty years ago.
As far as I can tell today there is a lack of books and tutorials for beginners that focus on that "new C++". Beginners are faced with a bewildering number of older materials. Or newer books that explore features in a very advanced way.
Perhaps it's just not possible. Back in the day Scott Meyers was the source of such books, he seems to have bailed on C++ due to it's excessive complexity!
sal55
Mon Oct 14, 2019 10:30 am
plugwash,
This is where I disagree with this whole 'language building' aspect of C++. Classes, templates, meta-classes (whatever they are) and so on are not in themselves useful, but are needed to achieve an end, such as near first-class handling of dynamic strings and arrays.
Yet the humblest script language already has those built in, without needing any classes. (And dynamic types gives you generics for free.)
Each time you use a feature like the vector class in C++, you have to recompile the implementation code for it. All the machinery needed to give the things you really want to use, is exposed. It makes for a far more complex and cumbersome language, with frightful syntax. And undecipherable error messages, even if you leave out one comma, that go on for pages.
Hardly a beginners' language, even if they can do a good job of dressing it up, such as on Arduino. Actually, it's hardly a language for anyone, IMO.
(I've tried the Arduino IDE; I found there are 5 processing stages (on a PC) in order to get a source program into the device. The first stage coverts the friendly source code you type in, into actual C++. The next 4 involving compiling that, then invoking some hefty 0.8MB utilitities to convert the result into suitable binary formats, and to upload it via USB. This is where I lost interest as I couldn't control that process.)
dsyleixa123
Mon Oct 14, 2019 10:55 am
Arduino IS NOT C++, it USES C++, providing a high level-API for a convenient way to use different MCUs (AVR, SAM, SAMD, ESP) also by non-professional pogrammers (by help of Go and java IDE "processings"):
https://arduinohistory.github.io/
http://people.interactionivrea.org/h.ba ... ow_res.pdf
the "hefty 0.8MB utilitities" are basically C and C++ libs (for MCU cores and Arduino C++ classes), and Arduino does not forbid you to write your own completely correct and valid C++ code, there is no wizardry about it. ;)
This approach makes Arduino an ideal base for beginners to learn C and C ++ by doing 8)
jcyr
Mon Oct 14, 2019 1:10 pm
Citations please...
It's um...uh...well it's kinda like...and it's got a bit of...
sal55
Mon Oct 14, 2019 1:50 pm
The two I had in mind (looking in my Arduino directory) would be objcopy.exe or objdump.exe, possibly both.
(I remember working in a placement in the 1970s using an ICL mainframe, where one of the biggest programs that you could run, 'TKB' which was some sort of complicated linker, took up 750KB, most of the memory available for this time-sharing system. These utilities for converting a few hundred bytes of object code and sending it to a microprocessor, are bigger than that. Being around computing a long time gives you a useful sense of perspective!)
And I think everyone knows that Arduino is not C++, but you have to use C++ to program it in a HLL, unless there are alternatives that I don't know about. The 260MB Arduino directory includes g++.exe. Such a small device limits the size of program you can write, so 'build times' may not be significant, but having to use C++ grates if you are not a fan of that language.
dsyleixa123
Mon Oct 14, 2019 2:04 pm
what do you mean by "such a small device"?
Arduino supports really small AVRs with 16MHz/2.5 kB RAM, but also really big ones (ARM Cortex-M4 with Floating Point Unit, or ESP32) up to 180MHz/1M Flash/256K RAM and perhaps more (feat. stdio.h, RTOS, std::thread 8) ), and anything in between.
Of course most MCU C/C++ libs are down-sized for MCUs, not having all the complete POSIX lbs for Linux. Anyway, it's enough to learn about C/C++.
sal55
Mon Oct 14, 2019 3:24 pm
OK, I associated Arduino with the AVR. I don't know it also works with other processors.
The AVR processor I played with I think had 32KB RAM.
Mon Oct 14, 2019 3:36 pm
jcyr,
Citations please...
Well that is the topic of discussion here. The lack of up to date books, tutorials and other guides for modern C++. If I knew of any I would cite them
For now the statement I made is born out of watching all the presentations at CppCon for the past two or three years. Many of which discuss the topic of programming in "modern" C++ and how it should be introduced to beginners in C++.
If you watch here: https://www.youtube.com/user/CppCon/playlists you will find a lot of talk about how: new/delete is now discouraged, auto_ptr is obsolete, STL algorithms are preferred over "for" loops, etc, etc,...
They are the people designing and implementing all this new stuff in C++ and that is what they have in mind.
Sadly they no longer have guys like Scott Meyers to produce new books such materials to go with it.
dsyleixa123
Mon Oct 14, 2019 4:23 pm
It's actually one of the biggest advantages of Arduino: 1 highlevel API which fits all boards by providing tons of different cores.
jcyr
Mon Oct 14, 2019 5:26 pm
jcyr,
Citations please...
I don't think the implementation of new features explicitly discourages the use of old ones. It is a valuable aspect of C++ that everything that has ever been supported, still is! It goes so far as being able to correctly compile pure C code.
Preferring brevity, of course I would use
for (auto it : ar) ...
instead of
for (vector<int>::iterator it = ar.begin(); it < ar.end(); it++) ...
But there's no implication I shouldn't use the latter.
Mon Oct 14, 2019 6:27 pm
jcyr,
Certainly the designers and implementers of the new features have exactly that in mind.
For example: In the old days we created objects with "new" and then had to remember to use "delete" to avoid memory leaks. If you were clever you created some kind of "smart pointer" that did reference counting so that new and delete were taken care of automatically by your smart pointer. No more memory leak mistakes.
At some point that practice got standardized with auto_ptr, use of new/delete was discouraged.
Later came shared_ptr, unique_ptr, whatever_ptr when it was realized that auto_ptr was not very good. Use of auto_ptr is discouraged.
There are many other examples of discouraged C++ usage. See the CppCon presentations.
That is very true. They go out of their way to ensure backwards compatibility so that old code does not break. Whilst at the same time encouraging adoption of new facilities and dropping old ones for new code.
Almost. C++ does not support the variable length arrays of C and likely never will, it's a broken miss-feature. And a bunch of other stuff: https://en.wikipedia.org/wiki/Compatibi ... t_not_in_C++
jcyr
Mon Oct 14, 2019 7:19 pm
jcyr,
Again, you are given a choice between safety and performance. The use of whatever_ptr involves the added overhead of invoking constructors and destructors with time consuming reference counting (specially true for shared_ptr). Not so with new/delete, and no need to figure out how whatever_pointer actually works. These pointers (actually the store they point to) are generally freed automatically when you leave their scope. Again you get finer grain control with new/delete. You get to choose your poison.
unique_ptr can be a little buggy regarding destructors. shared_ptr will always do "the right thing", as long it was created with make_shared. But if you create a unique_ptr<Derived>, then convert it to unique_ptr<Base>, and if Derived is virtual and Base is not, then the pointer will be deleted through the wrong type and there can be undefined behavior. This can be fixed with an appropriate deleter-type in the unique_ptr<T, DeleterType>, but the default is to use the riskier version because it is a little more efficient.
Mon Oct 14, 2019 7:46 pm
jcyr,
I'm pretty sure you will find that C++ smart pointers do not do any extra allocations on the heap. They exist on the stack and get passed around like other plain old data. There are no extra calls to constructors and destructors for them. In fact I think unique_ptr get's compiled down to just a normal pointer value anyway. As such the performance hit is zero.
They are there if you need them and experience shows that you don't need much of a big code base or many people working on it before the ownership of data gets very vague and it's hard to figure out when one can delete what. Result: use after free or memory leak bugs to find. Or race conditions in threaded programs which can get very hard to find.
Yep.
There is enough rope in C++ to hang yourself a hundred different ways everyday. I have yet to find the best rope :)
jcyr
Mon Oct 14, 2019 8:21 pm
True, but by this: "These pointers (actually the store they point to)" I wasn't talking about the pointers themselves, but rather the objects they reference.
jachaney
Mon Oct 14, 2019 10:38 pm
Herb Schildt! A Beginner's Guide to C++.
Good examples, great structure, and wonderful coverage of overloading, and class structure.
Use Code:Blocks for an IDE, and start with a simple console application for the "hello, world!" I can be installed easily using `sudo apt-get install codeblocks`
Look up GTK+ documentation for making GUI based applications. I use the 2.0 version and downloaded the development libraries with `sudo apt-get install libgtk2.0-dev`. Then added `pkg-config --cflags gtk+-2.0` to the include path, and `pkg-config --libs gtk+-2.0` to the additional libraries.
plugwash
Mon Oct 14, 2019 11:35 pm
That depends on what type of smart pointer you are talking about and how you create it.
unique_ptr and the deprecated auto_ptr do just exist on the stack. shared_ptr on the other hand needs a "control block" stored on the heap. If you use make_shared then most implementations will allocate a single memory block for both the control block and the pointed-to object. If you make a shared_ptr from an existing pointer then the control block will be allocated seperately on the heap.
Smart pointers do have constructors and destructors and hence can't generally be passed and returned in registers.
shared/weak pointers also have the overhead of incrementing and decrementing reference counts.
charels
Tue Oct 15, 2019 9:19 pm
I don't get why people try to scare off others from c++ because of its depth. It is deep but not any more complex than lots of other languages if you don't think to yourself that you "have" to use all of its features.
If you just focus on this it really isn't that bad and you can still do a lot of things:
- Global variables
- Local Variables
- Functions
- while loops
- for loops
- variables (int,string,bool,float)
- Comparisons (if 5 <10 do something)
- importing
This is almost identical in all languages, so why not just learn it in C++? This is like 80% of coding anyways I could probably write our instruments entire software other than the GUI with just these features, will it be good? no. But I could still do it.
Wed Oct 16, 2019 4:25 am
charels,
I do it because C++ scares me. And I have been using it for twenty years.
When we teach children to swim we start them in the shallow pool. Why do we do that? We could just throw them in the deep end and walk away. After all, they don't need to use all that water underneath them do they?
On the other hand I tend to agree. Presented in the right way and with appropriate guidance C++ is as easy to teach beginners as any other.
Which is nicely demonstrated, with comparison to other languages, here: Patrice Roy “C++ as a First Language... Really?” https://www.youtube.com/watch?v=AyhPigwhwbk
At the end of the day, it's not the depth of C++ that scares me. If you see a feature you don't understand in some source you can generally find out. What scares me is it's failure modes, often silent, unpredictable, deadly. Hard to find and rectify therefore expensive.
sal55
Wed Oct 16, 2019 7:08 pm
It is all the massive complex machinery just below the surface that scares me. This a C++ hello world program:
#include <iostream>
int main()
    std::cout << "Hello, world!\n";
Seems innocuous enough, after you accept the peculiar way you have to do output. But look what happens when you type >> instead of << (scroll through):
Error(s):
source_file.cpp(7): error C2784: 'std::basic_istream<_Elem,_Traits> &std::operator >>(std::basic_istream<_Elem,_Traits> &,_Elem *)': could not deduce template argument for 'std::basic_istream<_Elem,_Traits> &' from 'std::ostream'
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\istream(1008): note: see declaration of 'std::operator >>'
source_file.cpp(7): error C2784: 'std::basic_istream<_Elem,_Traits> &std::operator >>(std::basic_istream<_Elem,_Traits> &,_Elem &)': could not deduce template argument for 'std::basic_istream<_Elem,_Traits> &' from 'std::ostream'
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\istream(1050): note: see declaration of 'std::operator >>'
source_file.cpp(7): error C2784: 'std::basic_istream<char,_Traits> &std::operator >>(std::basic_istream<char,_Traits> &,signed char *)': could not deduce template argument for 'std::basic_istream<char,_Traits> &' from 'std::ostream'
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\istream(1075): note: see declaration of 'std::operator >>'
source_file.cpp(7): error C2784: 'std::basic_istream<char,_Traits> &std::operator >>(std::basic_istream<char,_Traits> &,signed char &)': could not deduce template argument for 'std::basic_istream<char,_Traits> &' from 'std::ostream'
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\istream(1082): note: see declaration of 'std::operator >>'
source_file.cpp(7): error C2784: 'std::basic_istream<char,_Traits> &std::operator >>(std::basic_istream<char,_Traits> &,unsigned char *)': could not deduce template argument for 'std::basic_istream<char,_Traits> &' from 'std::ostream'
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\istream(1089): note: see declaration of 'std::operator >>'
source_file.cpp(7): error C2784: 'std::basic_istream<char,_Traits> &std::operator >>(std::basic_istream<char,_Traits> &,unsigned char &)': could not deduce template argument for 'std::basic_istream<char,_Traits> &' from 'std::ostream'
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\istream(1096): note: see declaration of 'std::operator >>'
source_file.cpp(7): error C2784: 'std::basic_istream<_Elem,_Traits> &std::operator >>(std::basic_istream<_Elem,_Traits> &&,_Ty &)': could not deduce template argument for 'std::basic_istream<_Elem,_Traits> &&' from 'std::ostream'
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\istream(1106): note: see declaration of 'std::operator >>'
source_file.cpp(7): error C2676: binary '>>': 'std::ostream' does not define this operator or a conversion to a type acceptable to the predefined operator
That was from MSVC; using g++ you get (again scroll through to see the extent):
Error(s):
source_file.cpp: In function ‘int main()’:
source_file.cpp:7:15: error: no match for ‘operator>>’ (operand types are ‘std::ostream {aka std::basic_ostream<char>}’ and ‘const char [15]’)
     std::cout >> "Hello, world!\n";
In file included from /usr/include/c++/5/iostream:40:0,
                 from source_file.cpp:3:
/usr/include/c++/5/istream:924:5: note: candidate: template<class _CharT, class _Traits, class _Tp> std::basic_istream<_CharT, _Traits>& std::operator>>(std::basic_istream<_CharT, _Traits>&&, _Tp&)
     operator>>(basic_istream<_CharT, _Traits>&& __is, _Tp& __x)
/usr/include/c++/5/istream:924:5: note:   template argument deduction/substitution failed:
source_file.cpp:7:18: note:   ‘std::ostream {aka std::basic_ostream<char>}’ is not derived from ‘std::basic_istream<_CharT, _Traits>’
/usr/include/c++/5/istream:808:5: note: candidate: template<class _Traits> std::basic_istream<char, _Traits>& std::operator>>(std::basic_istream<char, _Traits>&, signed char*)
     operator>>(basic_istream<char, _Traits>& __in, signed char* __s)
/usr/include/c++/5/istream:808:5: note:   template argument deduction/substitution failed:
source_file.cpp:7:18: note:   ‘std::ostream {aka std::basic_ostream<char>}’ is not derived from ‘std::basic_istream<char, _Traits>’
/usr/include/c++/5/istream:803:5: note: candidate: template<class _Traits> std::basic_istream<char, _Traits>& std::operator>>(std::basic_istream<char, _Traits>&, unsigned char*)
     operator>>(basic_istream<char, _Traits>& __in, unsigned char* __s)
/usr/include/c++/5/istream:803:5: note:   template argument deduction/substitution failed:
/usr/include/c++/5/istream:761:5: note: candidate: template<class _Traits> std::basic_istream<char, _Traits>& std::operator>>(std::basic_istream<char, _Traits>&, signed char&)
     operator>>(basic_istream<char, _Traits>& __in, signed char& __c)
/usr/include/c++/5/istream:761:5: note:   template argument deduction/substitution failed:
And this is for a very simple error where you can easily see what might be wrong. It's just the error messages that are impenetrable. The reason is that it is not reporting directly on the error in the source, but an error that is generated when it tries to compile the implementation code for 'cout' and '<<' and '>>', which is in C++ also, and which will not make sense to anyone unfamiliar with what is inside and can only see what they themselves have written.
This is a big problem with using meta-programming to implement language features that ought to be built-in.
This language should not be let anyway near a beginner. (I only saw a few bits of the video you posted; did it show what to do about impossibly long-winded and arcane error messages when you get something wrong?)
Wed Oct 16, 2019 7:51 pm
That is a good point. The eruption of C++ error messages can be overwhelming even for the experienced.
I have been playing with Rust recently. It also has polymorphism and meta-program via a sophisticated macro system. Despite that Rust's error messages are amazingly succinct and helpful, even offering suggestions to fix the problem that actually work. It's kind of fun having a chat with the Rust compiler as you fumble around trying to get something to compile.
I think the Rust guys have the perspective that failure is the normal case so the language design had better try and make that as least unpleasant as possible. They even refer to it as "ergonomics" in language design.
Paeryn
Wed Oct 16, 2019 10:24 pm
#include <iostream>
int main()
Error(s):
Error(s):
They both do report on the error in the source :-
MSVC looks to list the error as it tried to expand the templates and finally shows you the error in your source code.
G++ lists the error in your source code first and then shows you how it tried to expand the templates.
MSVC makes it easier to see as the error in your source code is the last thing printed and so is likely to still be on-screen without having to scroll up.
G++ makes it easier to read sequentially as the error is closer to the command line used. By the way, g++9 produces clearer error reports than 5 (writing this on my phone so I can't copy-paste its output).
They print the expansions as they show the exact error the compiler found when expanding the templates.
She who travels light — forgot something.
jahboater
Thu Oct 17, 2019 12:13 am
g++ 9.2 gives:-
$ g++ try.cpp
try.cpp: In function 'int main()':
try.cpp:5:12: error: no match for 'operator>>' (operand types are 'std::ostream' {aka 'std::basic_ostream<char>'} and 'const char [15]')
    5 |  std::cout >> "Hello, world!\n";
      |       |       const char [15]
In file included from /usr/local/include/c++/9.2.0/string:56,
                 from /usr/local/include/c++/9.2.0/bits/locale_classes.h:40,
                 from /usr/local/include/c++/9.2.0/bits/ios_base.h:41,
                 from /usr/local/include/c++/9.2.0/ios:42,
                 from /usr/local/include/c++/9.2.0/ostream:38,
                 from /usr/local/include/c++/9.2.0/iostream:39,
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/bits/basic_string.tcc:1466:5: note: candidate: 'template<class _CharT, class _Traits, class _Alloc> std::basic_istream<_CharT, _Traits>& std::operator>>(std::basic_istream<_CharT, _Traits>&, std::__cxx11::basic_string<_CharT, _Traits, _Alloc>&)'
 1466 |     operator>>(basic_istream<_CharT, _Traits>& __in,
/usr/local/include/c++/9.2.0/bits/basic_string.tcc:1466:5: note:   template argument deduction/substitution failed:
try.cpp:5:15: note:   'std::ostream' {aka 'std::basic_ostream<char>'} is not derived from 'std::basic_istream<_CharT, _Traits>'
In file included from /usr/local/include/c++/9.2.0/istream:991,
                 from /usr/local/include/c++/9.2.0/iostream:40,
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/bits/istream.tcc:931:5: note: candidate: 'template<class _CharT, class _Traits> std::basic_istream<_CharT, _Traits>& std::operator>>(std::basic_istream<_CharT, _Traits>&, _CharT&)'
  931 |     operator>>(basic_istream<_CharT, _Traits>& __in, _CharT& __c)
/usr/local/include/c++/9.2.0/bits/istream.tcc:931:5: note:   template argument deduction/substitution failed:
In file included from /usr/local/include/c++/9.2.0/iostream:40,
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/istream:756:5: note: candidate: 'template<class _Traits> std::basic_istream<char, _Traits>& std::operator>>(std::basic_istream<char, _Traits>&, unsigned char&)'
  756 |     operator>>(basic_istream<char, _Traits>& __in, unsigned char& __c)
/usr/local/include/c++/9.2.0/istream:756:5: note:   template argument deduction/substitution failed:
try.cpp:5:15: note:   'std::ostream' {aka 'std::basic_ostream<char>'} is not derived from 'std::basic_istream<char, _Traits>'
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/istream:761:5: note: candidate: 'template<class _Traits> std::basic_istream<char, _Traits>& std::operator>>(std::basic_istream<char, _Traits>&, signed char&)'
  761 |     operator>>(basic_istream<char, _Traits>& __in, signed char& __c)
/usr/local/include/c++/9.2.0/istream:761:5: note:   template argument deduction/substitution failed:
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/bits/istream.tcc:963:5: note: candidate: 'template<class _CharT2, class _Traits2> std::basic_istream<_CharT, _Traits>& std::operator>>(std::basic_istream<_CharT, _Traits>&, _CharT2*)'
  963 |     operator>>(basic_istream<_CharT, _Traits>& __in, _CharT* __s)
/usr/local/include/c++/9.2.0/bits/istream.tcc:963:5: note:   template argument deduction/substitution failed:
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/istream:803:5: note: candidate: 'template<class _Traits> std::basic_istream<char, _Traits>& std::operator>>(std::basic_istream<char, _Traits>&, unsigned char*)'
  803 |     operator>>(basic_istream<char, _Traits>& __in, unsigned char* __s)
/usr/local/include/c++/9.2.0/istream:803:5: note:   template argument deduction/substitution failed:
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/istream:808:5: note: candidate: 'template<class _Traits> std::basic_istream<char, _Traits>& std::operator>>(std::basic_istream<char, _Traits>&, signed char*)'
  808 |     operator>>(basic_istream<char, _Traits>& __in, signed char* __s)
/usr/local/include/c++/9.2.0/istream:808:5: note:   template argument deduction/substitution failed:
                 from try.cpp:1:
/usr/local/include/c++/9.2.0/istream:980:5: note: candidate: 'template<class _Istream, class _Tp> typename std::enable_if<std::__and_<std::__not_<std::is_lvalue_reference<_Tp> >, std::__is_convertible_to_basic_istream<_Istream>, std::__is_extractable<typename std::__is_convertible_to_basic_istream<_Tp>::__istream_type, _Tp&&, void> >::value, typename std::__is_convertible_to_basic_istream<_Tp>::__istream_type>::type std::operator>>(_Istream&&, _Tp&&)'
  980 |     operator>>(_Istream&& __is, _Tp&& __x)
/usr/local/include/c++/9.2.0/istream:980:5: note:   template argument deduction/substitution failed:
/usr/local/include/c++/9.2.0/istream: In substitution of 'template<class _Istream, class _Tp> typename std::enable_if<std::__and_<std::__not_<std::is_lvalue_reference<_Tp> >, std::__is_convertible_to_basic_istream<_Istream>, std::__is_extractable<typename std::__is_convertible_to_basic_istream<_Tp>::__istream_type, _Tp&&, void> >::value, typename std::__is_convertible_to_basic_istream<_Tp>::__istream_type>::type std::operator>>(_Istream&&, _Tp&&) [with _Istream = std::basic_ostream<char>&; _Tp = const char (&)[15]]':
try.cpp:5:15:   required from here
/usr/local/include/c++/9.2.0/istream:980:5: error: no type named 'type' in 'struct std::enable_if<false, void>'
Thu Oct 17, 2019 1:10 am
Finally the world catches up with me!
Towards the end of last century I was contracted to build a program to translate the file format of one electronics design package to the format of another. Of course I had to detect errors in the input and produce appropriate messages. I thought it would be neat to point out where the error is exactly, like so:
foo = 123
Error XXX, filename: blabla, line: 123: colum: 7
The client company thought I had been frivolous is adding that unspecified feature and discussed asking me to remove it!
It's nice to see gcc catching up with me 25 years later :)
Seems GCC got the idea from the Rust which does it really nicely:
$ cat temp.rs
fn main () {
    println!("Hello world);
$ rustc temp.rs
error: unterminated double quote string
 --> temp.rs:2:14
2 |       println!("Hello world);
  |  ______________^
3 | | }
4 | |
  | |_^
error: aborting due to previous error
Here it shows where it detected the error when it discovered mismatched braces, but then points back to where you actually forgot to close the string.
Which looks even better with the colour highlighting they use.
Paeryn
Thu Oct 17, 2019 2:59 am
I take it you held your ground, especially if you had already implemented it!
GCC has been printing a caret showing the start position of the error on the line for quite a while but it used to be just that. I think it was in 6 that they added tildes with it to highlight the extent of the error rather than just the character where it happened.
They've improved the error reports in GCC at lot, but I agree Rust has very good error reports, I think that was important to them from the start.
ejolson
Thu Oct 17, 2019 3:06 am
Is there any way to turn off all that ASCII art? It's filling my screen and causing the error messages to scroll off the top.
Return to “C/C++”
