kirspaum
UART interfacing with "pigpio"
Sun Sep 01, 2019 6:15 pm
Hey there!
Im working on a project where i want to use the UART Pins. Therefore I want to use the "pigpio"-library.
I am just not able to receive bytes from the UART device.
For trying out I "shortcutet" the TxD and RxD of one Raspberry (3B+), wrote that little code to send letters
#include<iostream>
#include<pigpio.h>
using namespace std;
int x = gpioInitialise();
int main()
char p[] = "/dev/ttyS0";
int port = serOpen(p, 9600, 0);
char buf[] = {'a','b','c'};
serWrite(pot, buf, 3);
serClose(port);
return 0;
and with minicom I could verify that those letters where sent and received.
Same thing with another Raspberry (Zero WH). So this worked fine.
But now if I connect the TxD of one Raspberry with the RxD of another, run the code on one and minicom on the other Pi, this doesn't work anymore. And I just can't get my head around why this wouldn't work.
Maybe someone can give me a little hint. Thanks!
markkuk
Re: UART interfacing with "pigpio"
Mon Sep 02, 2019 5:56 am
Did you connect the ground pins in addition to TxD and RxD? Remember that electricity flows in circuits.
kirspaum
Mon Sep 02, 2019 4:39 pm
Oh my god, the ground pins. thank you so much!
Return to “C/C++”
