ear9mrn
Compiling Canon printer driver?
Mon Jul 29, 2019 2:17 pm
I am trying to compile the canon printer drivers for use with my raspberry pi and CUPS and getting stuck. Any help would be appreciated
I downloaded the drivers from the canon website
https://www.canon-europe.com/support/co ... =en&os=all
[Linux] UFRII LT Printer Driver Ver.1.50
They have 32bit and 64bit deb and redhat packages already created but the deb packages are only for i386 and amd64 but no arm.
There is a source directory within the package so I am attempting to compile from source but it keeps failing.
linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90 $ make gen
With the following results...
Now type `make' to compile.
make[1]: Entering directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp'
make  all-recursive
make[2]: Entering directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp'
Making all in po
make[3]: Entering directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp/po'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp/po'
Making all in src
make[3]: Entering directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp/src'
/bin/bash ../libtool  --tag=CC   --mode=link gcc -O2 -Wall -g -O2 -rpath /usr/local/lib  -o cngplp main.o mainwnd.o printerinfo.o load.o options.o -lglade-2.0  -lcups
libtool: link: gcc -O2 -Wall -g -O2 -o cngplp main.o mainwnd.o printerinfo.o load.o options.o  -lglade-2.0 -lcups -Wl,-rpath -Wl,/usr/local/lib
/usr/bin/ld: main.o: undefined reference to symbol 'gtk_init'
//usr/lib/arm-linux-gnueabihf/libgtk-x11-2.0.so.0: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
Makefile:445: recipe for target 'cngplp' failed
make[3]: *** [cngplp] Error 1
make[3]: Leaving directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp/src'
Makefile:421: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp'
Makefile:353: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/home/pete/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp'
Makefile:24: recipe for target 'gen' failed
make: *** [gen] Error 1
Clearly there is something amiss with either gtk or x11... Could this be a missing library or dev package?
Any guidance or suggestion would be good.
Thanks,
Pete.
Re: Compiling Canon printer driver?
Mon Jul 29, 2019 7:15 pm
make  all-recursive
Making all in po
Making all in src
Thanks,
Pete.
Gutenprint support many printers:
http://gimp-print.sourceforge.net/
ear9mrn
Tue Jul 30, 2019 12:29 pm
many thanks, but sadly my printer is not supported
Mine is LBP6230dw
Canon GP 335
Canon LBP-4sx
Canon LBP-430
Canon LBP-1000
Canon LBP-1260
Canon LBP-1760
Canon LBP-3360
Canon LBP-5360
Canon LBP-5390
Canon imageRunner 330s
Canon imageRunner C2550
swampdog
Tue Jul 30, 2019 4:43 pm
Grgh! Libtool! Had no end of problems with that over the years!
I'm not going to fix the build but you can link it manually.. Run your "make gen" then once it fails..
$ pwd
/wrk/linux-UFRIILT-drv-v150-uken/Sources/cndrvcups-common-3.90/cngplp/src
gcc -o cngplp main.o mainwnd.o printerinfo.o load.o options.o -lgtk-x11-2.0 -lgdk-x11-2.0 -lpangocairo-1.0 -latk-1.0 -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lpangoft2-1.0 -lpango-1.0 -lgobject-2.0 -lglib-2.0 -lfontconfig -lfreetype  -lglade-2.0 -lgmodule-2.0 -lcups -Wl,-rpath -Wl,/usr/local/lib
..basically GLADE_PACKAGE_LIBS out of the generated Makefile (plus gmodule-2.0).
Yes. You were correct. Undefined symbols due to incorrect link.
Return to “C/C++”
