Mr_
Problem using wiringPiISR (c++)
Thu Jun 27, 2019 9:13 am
I began to use c++ two weeks ago with QT Creator and a Raspberry Pi.
I'm struggling with wiringPiISR (wiringPi Library) and I didn't found any answer for my problem on this forum, so I'm asking you some help :)
I'm trying to configure wiringPiISR to trigger an interrupt (on both rising and falling edge) and call a method in the same class called here "void visualisation::traitement(void()".
I call wiringPiISR here at the launch of my visualisation.cpp, and in the same .cpp I have my method : "void visualisation::traitement(void)".
Here is the part of my .cpp (I erased the content of my visualisation::traitement because I think it's not the point of my question, I Don't use any return, I just modify some global variables and set text in widgets)
#include<iostream>
#include<QMessageBox>
#include<QDebug>
#include<math.h>
#include<functional>
#include"visualisation.h"
#include"ui_visualisation.h"
#include"wiringPi.h"
using namespace std;
visualisation::visualisation(QWidget *parent) :
    QDialog(parent),
    ui(new Ui::visualisation)
wiringPiISR(G_conv1, INT_EDGE_BOTH,&visualisation::traitement());
void visualisation :: traitement(void){
And the .h:
#ifndef VISUALISATION_H
#define VISUALISATION_H
#include <QDialog>
namespace Ui {
class visualisation;
class visualisation : public QDialog
    Q_OBJECT
public:
    explicit visualisation(QWidget *parent = 0);
    ~visualisation();
private slots:
    void traitement(void);
private:
    Ui::visualisation *ui;
#endif // VISUALISATION_H
I Don't understand how to use my method as a void(*)(), I tried to use std::bin, but it didn't work.
I have those messages in the output:
"lvalue required as unary '&' operand"
with static_cast:
static_cast<void*>(visualisation::traitement())
"invalid static_cast from type 'void' to type 'void*'
I think that I Don't really understand what to put in wiringPiISR.
I'm trying to be clear, thank you for your help, I will update my post if there isn't enough information :)
deepo
Re: Problem using wiringPiISR (c++)
Thu Jun 27, 2019 9:24 pm
According to your code:
you are trying to take the output of:
which is void and cast that to void * which won't work, as the traitement() function does not return anything.
Apart from that you can't call visualisation::traitement() as you do because it's not a static function.
But I don't know anything about Qt, so I'm afraid I can't help you with that.
Does this function:
require you to provide a function that returns a "void *" ?
/Mogens
deepo
Thu Jun 27, 2019 9:30 pm
This thread seems to have info on the function:
https://www.raspberrypi.org/forums/view ... p?t=184388
There may be help to find here:
https://stackoverflow.com/questions/308 ... a-function
And more code here:
https://gist.github.com/antimodular/b1f ... a0bdb30d67
/Mogens
Mr_
Fri Jun 28, 2019 6:13 am
Thank you for your reply deepo :)
It requires a void(*function)(void) (WiringPi website) or &function for Qt.
I will read the links you gave me!!:)
Return to “C/C++”
