eoin_oc
Issue communicating with /dev/ttyUSB1
Tue Jun 25, 2019 12:34 pm
Hi all,
I have cellular modem Ublox SARA-R410 plugged into my Pi Model B. Using the command screen /dev/ttyUSB1 I can send and receive AT commands no problem.
Now I am trying to access /dev/ttyUSB1 from C and it is not working.
I tried in Python and it worked great.
import time
import serial
ser=serial.Serial(
    port='/dev/ttyUSB1',
    baudrate=115200,
    parity=serial.PARITY_NONE,
    stopbits=serial.STOPBITS_ONE,
    bytesize=serial.EIGHTBITS,
    timeout=1
while 1:
    ser.write(str.encode("AT+URAT?\r\n"))
    x=ser.readline()
    print(x)
    time.sleep(1)
In C I have tried 2 different approaches and neither of them read back correctly, but the port does seem to open ok.
This was my first attempt:
    if(wiringPiSetup()==-1)
        printf("wiring pi failed");
        return 1;
    serialPort=serialOpen("/dev/ttyUSB1",115200);
    if(serialPort==-1)
    	return -1;
    serialFlush(serialPort);
    serialPrintf(serialPort,"AT+URAT?\r\n");
while(serialDataAvail(serialPort))
    printf("%c",serialGetchar(serialPort));
This code does not receive any characters from the USB port.
This was C attempt #2:
    int  init_modem()   /* I - Serial port file */
  char buffer[255];  /* Input buffer */
  char *bufptr;      /* Current char in buffer */
  int  nbytes;       /* Number of bytes read */
  int  tries,serialPort;        /* Number of tries so far */
  struct termios options;
    memset(&options,0,sizeof(options));
    serialPort=open("/dev/ttyUSB1", O_RDWR | O_NOCTTY | O_NDELAY);
    fcntl(serialPort, F_SETFL, 0);
    if(serialPort==-1)
        return -1;
     * Get the current options for the port...
    cfsetospeed(&options, B115200);
    cfsetispeed(&options, B115200);
     * Enable the receiver and set local mode...
    options.c_cc[VMIN]=0;
    options.c_cc[VTIME]=5;
    options.c_cflag = (B115200 | CS8 |CLOCAL | CREAD);
    options.c_iflag =IGNPAR;
    options.c_oflag=0;
    options.c_lflag=0;
    tcflush(serialPort, TCIFLUSH);
     * Set the new options for the port...
    if(tcsetattr(serialPort, TCSANOW, &options)==-1)
        printf("error setting uart params\r\n");
        return-1;
  for (tries = 0; tries < 3; tries ++)
   /* send an AT command followed by a CR */
    if (write(serialPort, "AT\r\n", 4) < 4)
      continue;
   /* read characters into our string buffer until we get a CR or NL */
    bufptr = buffer;
    while ((nbytes = read(serialPort, bufptr, 1)) > 0)
        printf("%c\r\n",bufptr);
      bufptr += nbytes;
      //expect a \r\n together
      if ((bufptr[-1] == '\r' && bufptr[0] == '\n'))//&& (bufptr-buffer)>=4)
        break;
   /* nul terminate the string and see if we got an OK response */
    *bufptr = '\0';
    if (strncmp(buffer, "OK", 2) == 0)
      return (serialPort);
  return (-1);
Does anybody know where I am going wrong? I am running the code as sudo.
topguy
Re: Issue communicating with /dev/ttyUSB1
Tue Jun 25, 2019 2:33 pm
I think the first attempt will just exit the while loop at once because you don't wait for the modem to reply.
Wrap the while in a 20 iterations "for"-loop that sleep for 100ms every loop.
eoin_oc
Tue Jun 25, 2019 3:29 pm
Thanks, you were right 1 does work I just need a delay when checking the first available characters
Return to “C/C++”
