ezbroken
change data type using C/C++
Fri Jun 21, 2019 9:27 am
hI , I am recently using 3B+ developing connection between 3B+ and zigbee, zigbee require a certain hex communication type frame. I am wondering how to transform a file (txt, jpg) into hex datatype so that it can be sent and received sequentially by frame and frame.
Does anyone have experience on it or similar example. I am a little bit confused at all.
Re: change data type using C/C++
Fri Jun 21, 2019 9:49 am
What is the specific format required? Depending on that you may need to write something, or there maybe a standard linux command line app that can do what you want.
jahboater
Fri Jun 21, 2019 10:41 am
Yes,
Perhaps see the "od" command (type "man od" for details).
Or, as you are using C/C++, this may be trivial to code by hand.
That is, as you read in the file, hexify the text and split it into frames
topguy
Tue Jun 25, 2019 3:48 pm
I find it unlikely that a system like ZigBee would use such an inefficient method for sending data. Sending "7e" instead of one byte of value 0x7e just wastes half the bandwidth,
Return to “C/C++”
