ksharindam
using dynamically loaded libraries causes segmentation fault
Sat Jun 15, 2019 4:15 pm
I am trying to use dynamically loaded libraries to get mp3 file duration.
But when I am trying to clean allocated memory. It causes segfault.
#include <stdlib.h>
#include <stdio.h>
#include <dlfcn.h>
typedef void TagLib_File;
typedef void TagLib_AudioProperties;
TagLib_File* (*taglib_file_new)(char*);
int (*taglib_file_is_valid)(TagLib_File*);
TagLib_AudioProperties* (*taglib_file_audioproperties)(TagLib_File*);
int (*taglib_audioproperties_length)(TagLib_AudioProperties*);
void (*taglib_tag_free_strings)();
void (*taglib_file_free)(TagLib_File*);
int main()
    void* taglib = dlopen("libtag_c.so.0.0.0", RTLD_LAZY);
    taglib_file_new = dlsym(taglib, "taglib_file_new");
    taglib_file_audioproperties = dlsym(taglib, "taglib_file_audioproperties");
    taglib_audioproperties_length = dlsym(taglib, "taglib_audioproperties_length");
    // now use functions normally
    TagLib_File *TL_file = taglib_file_new( "/home/me/Music/Lilabali.mp3" );
    TagLib_AudioProperties *TL_props = taglib_file_audioproperties( TL_file );
    int length = taglib_audioproperties_length( TL_props );
    printf("%d\n", length);
    taglib_tag_free_strings(); // causes segfault
    taglib_file_free( TL_file ); // this also causes segfault
    dlclose(taglib);
Why it causes segfault?
EDIT:
But When I use Dynamically Linked library no segfault occurs.
#include <stdlib.h>
#include <stdio.h>
#include <taglib/tag_c.h>
int main()
    taglib_tag_free_strings();  // no segfault
    taglib_file_free( TL_file );  // no segfault
    dlclose(taglib);
My Qt projects at ... https://github.com/ksharindam
Re: using dynamically loaded libraries causes segmentation fault
Sat Jun 15, 2019 4:53 pm
You're missing the dlsym calls for the two functions that get the segfaults.
If you use RTLD_LAZY you have to register (with dlsym()) every function you want to use from the dynamically loaded library.
This is a doctor free zone.
ksharindam
Sat Jun 15, 2019 5:26 pm
uff...what a silly mistake!
Problem solved.
Thanks.
Return to “C/C++”
