marcellatwin
Trouble with GCC compiling
Thu Jun 06, 2019 6:33 pm
Hello everyone.
I am working on a CAN bus project using a RPi 3B with Raspian Stretch (9.9). It has a CAN shield, PiCan2, to connect to the CAN bus thru an OBD2 port on a car. I have a custom program built from code provided by the linux-can-utils which has programs such as candump, cansniffer, cansend, etc. I've gotten my program to compile, run, and read CAN messages just fine. However, I'm starting to move forward with my project where I need to send messages as well. So I included the code for sending messages from the cansend source code and included the additional libraries that cansend had
#include "lib.h"
Also during compiling I have tried to include the location of the lib.h
gcc -Wall -Wextra -O3 /home/pi/jc_volvo.c -lwiringPi -lcurses -lpthread -I/home/pi/linux-can-util -llib -o /home/pi/jc_volvo
And this is what I get:
/usr/bin/ld: cannot find -llib
collect2: error: ld returned 1 exit status
I feel like the code is fine but something with the library or compiling is not working. Any ideas? Thanks in advance anyone's help.
PeterO
Re: Trouble with GCC compiling
Thu Jun 06, 2019 6:43 pm
Should that be -Llib (note the first L is a capital)
PeterO
marcellatwin
Thu Jun 06, 2019 7:11 pm
PeterO
So I tried that, even though I didn't think it would work cause all the other libraries included in the compilation are -l "lowercase". Why would this one be different? So I did that and got the following error:
/tmp/ccqdvsBH.o: In function 'can_send_thread':
undefined reference to 'parse_canframe'
So something changed. But 'parse_canframe' is one of the functions that is included by the lib.h. So I'm not sure what's going on.
PeterO
Thu Jun 06, 2019 7:24 pm
Where did you get the compile options from ?
PeterO
marcellatwin
Thu Jun 06, 2019 8:08 pm
PeterO
-Wall - is all the compiler warnings turned on, these aren't errors but warnings
-Wextra - extra compiler warnings that are not included in Wall
-O3 - is all optimizations turned on, like inlining, it takes longer to compile but only by a few seconds for me.
Is this what you mean?
PeterO
Thu Jun 06, 2019 8:10 pm
where has the -llib come from ?
I doubt there is a library called "liblib.so"
PeterO
PeterO
Thu Jun 06, 2019 10:04 pm
Now I'm on a machine which has the can-utils installed on it so I can see how it is supposed to be working.
~/CAN/linux-can-utils$ ls -l lib*
-rw-r--r-- 1 petero petero 11770 Mar 15  2015 lib.c
-rw-r--r-- 1 petero petero  5800 Mar 15  2015 lib.h
-rw-r--r-- 1 petero petero 10400 Mar 15  2015 lib.o
So there is no library called "lib", just lib.c which is compiled to lib.o
The original make files has all the targets depending on lib.o so that will get included in the link command. as just "lib.o"
Since it isn't a propper library (.so or .a) I would suggest just moving lib.c and lib.h into the directory with your other source code and use it like the original can uttils makefile does.
PeterO
marcellatwin
Fri Jun 07, 2019 3:54 pm
PeterO
First off, thank you for looking into this and being patient with me. I really don't understand libraries that well.
So should I do what I've done with the other libraries I use when I just have the ".h" file in the same directory as the .c file I'm compiling?
Should I move the .c AND .h?
Do I compile with -llib like the other libraries or -lib?
bzt
Sun Jun 09, 2019 5:57 pm
That's simple. There're two kinds of libraries: statically linked and dynamically linked.
Statically linked libraries have the extension .a (stands for object archive), and you link with them at compile time. The library will be included in your executable, growing it's size.
Dynamically linked libraries on the other hand have the extension .so (shared object), and are typically located in /lib or /usr/lib. At compilation time, the linker just creates a reference to them. You can list those references with the "ldd" command, for example try "ldd /bin/bash". Those libraries are linked when the user executes the binary, therefore they must exists on the target machine (exactly like DLLs on Windows. As a matter of fact, DLL stands for Dynamically Linked Library).
Now -L (uppercase) specifies the directory in which the linker should look for libraries, so for example -L/usr/lib. This is usually already set up for you correctly, no need to use.
The -l (lowercase) specifies the name of the library to load, prefixed and suffixed by (-L agrument)"lib"(the -l argument)(".so" or ".a"). For example in case of -lm your executable will be linked with /lib/libm.so. That all.
As @PeterO suggested, don't think of it as a library. Just copy the .c and .h into your source directory and compile with the rest of your code. Then when you link, list lib.o with the rest of your object files. For example:
gcc -Wall -Wextra -O3 -c /home/pi/jc_volvo.c -o jc_volvo.o
gcc -Wall -Wextra -O3 -c /home/pi/lib.c -o lib.o
gcc jc_volvo.o lib.o -o jc_volvo -lwiringPi -lcurses -lpthread
Some caveats: always use "-c" on individual .c files if you have more, then another gcc command to link the ".o"s together. This will save you lots of trouble later. Second, you must specify the libraries on the command line AFTER the -o argument, some gcc versions are very strict in this regard.
To automate the compilation and linking, here's a very simple GNU make Makefile:
TARGET = jc_volvo
SRCS = $(wildcard *.c)
OBJS = $(SRCS:.c=.o)
all: $(TARGET)
%.o: %.c
        gcc -Wall -Wextra -O3 -c $< -o DOLLARAT
$(TARGET): $(OBJS)
        gcc $(OBJS) -o $(TARGET) -lwiringPi -lcurses -lpthread
You should replace DOLLARAT with a $ and an @ sign, but this forum replaces that with an "[email protected]" link so I couldn't wrote those directly in the code block. Also there's a TAB character in front of gcc and not 8 spaces (important).
Now to compile your project, you just type "make all" and hit Enter. If you create a new .c file, no need to modify anything, it will be automagically compiled into your binary :-) This will considerably speed up your compilation time, because it will only compile the .o files for the .c sources you have modified, and not all of them.
Cheers,
bzt
PeterO
Sun Jun 09, 2019 6:26 pm
Sorry, I missed the last post from marcellatwin.
PeterO
Return to “C/C++”
