juvf
cURL
Sun Jun 02, 2019 4:49 pm
I can't configure the IDE to build an application using libcurl.
what packages do I need to install? what libraries to include when linking?
topguy
Re: cURL
Mon Jun 03, 2019 8:58 am
libcurl can be a little bit tricky I guess.. you have some options.
For header files you have either:
- https://packages.debian.org/stretch/libcurl4-gnutls-dev
- or https://packages.debian.org/stretch/lib ... penssl-dev
But I think you should install the last one.
For linker option I think it should be enough to just add "-lcurl"
Return to “C/C++”
