dsyleixa123
code for UART comm from Pi to Arduino hangs up
Thu May 30, 2019 2:14 pm
hi,
I am despairing, my code for UART comm from Pi to Arduino hangs up.
I am trying to send strings built by
strcpy(formatstr, "§");
strcat(formatstr, "&i0=%d;&i1=%d;&i2=%d;&i3=%d;\n");
sprintf(mbuf, formatstr, i0,i1,i2,i3);
to my Arduino and receive similar ones.
At least I get it started, but it seems to hang up after the first 1 or 2 loops. The codes for Pi and Arduino are quite similar:
for the Pi (updated code):
   UART communication
   send/receive string of tokens
   Raspberry Pi  master
   ver 0701
  * change log
  * 0701:
  * Serial Read delimiter
  * 0700
  * first adjustments
  * 0669:
  * UART 115200 baud  *
  * 0667:
  * Arduino via USB = ACM0
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <sys/ioctl.h>
#include <stdint.h>
#include <time.h>
#include <sys/time.h>
#include <errno.h>
#include <pthread.h>
#include <wiringPi.h>
#include <wiringSerial.h>
#define  byte  uint8_t
char   uart[256]  =  "/dev/ttyACM0";
int    Serial;
const uint32_t UARTclock = 115200;
int i0, i1, i2, i3, i4, i5, i6;             // int (common)
int a0,a1,a2,a3,a4,a5,a6,a7,a8,a9,a10,a11;  // int for analogRead(pin): a0=analogRead(A0), a1=analogRead(A1),...
double f0, f1, f2, f3, f4, f5;              // double (common)
#define TOKLEN 30
#define MSGLEN 1024
#define iINVALID -29999
std::string  inputString="";
char   cval[TOKLEN];  // number as cstring
char   mbuf[MSGLEN];  // cstring msg buffer
// debug monitor
void displayvalue(char c[TOKLEN]) {
// token tools
int16_t  strstrpos(char * haystack,  char * needle)   // find 1st occurance of substr in str
   char *p = strstr(haystack, needle);
   if (p) return (int16_t) (p-haystack);
   return -1;   // Not found = -1.
char * cstringarg( char* haystack, char* vname, char* carg ) {
   int i=0, pos=-1;
   unsigned char  ch=0xff;
   const char*  kini = "&";       // start of varname: '&'
   const char*  kin2 = "?";       // start of varname: '?'
   const char*  kequ = "=";       // end of varname, start of argument: '='
   char  needle[TOKLEN] = "";     // complete pattern:  &varname=abc1234
   strcpy(carg,"");
   strcpy(needle, kini);
   strcat(needle, vname);
   strcat(needle, kequ);
   pos = strstrpos(haystack, needle);
   if(pos==-1) {
      needle[0]=kin2[0];
      if(pos==-1) return carg;
   pos=pos+strlen(vname)+2; // start of value = kini+vname+kequ
   while( (ch!='&')&&(ch!='\0') ) {
      ch=haystack[pos+i];
      if( (ch=='&')||(ch==';')||(ch==' ')||(ch=='\0') ||(ch=='\n')
        ||(i+pos>=(int)strlen(haystack))||(i>TOKLEN-1) ) {
           carg[i]='\0';
           return carg;
      if( (ch!='&') ) {
          carg[i]=ch;
          i++;
   return carg;
// serial TCP
void loop() {
  while(1) {
     static bool stringComplete = false;
     // send
     char formatstr[MSGLEN];
     // debug, cut-down:
     strcpy(formatstr, "§");                                                    // initial key
     for(uint8_t i=0; i<strlen(mbuf)-1; i++) {                 //
        serialPutchar( Serial, mbuf[i]);                      // Send values to the slave
     strcpy(mbuf, "");
     //delay?
     delay(1);
     // receive
     inputString="";
     char cstr[TOKLEN];
     int  n=0;
     char inChar;
     while (serialDataAvail( Serial ) && n<MSGLEN-1) {
       if(n==MSGLEN-2) inChar='\n'; // emergency brake
       else
       inChar = serialGetchar( Serial );
       inputString += inChar;
       if (inChar == '\n')  {
         stringComplete = true;
       n++;
     if (stringComplete)  {
       //inputString.to_str(mbuf, len-1);
       strcpy (mbuf, inputString.c_str() );
       strcat(mbuf, "\0");
       fprintf(stderr,mbuf); fprintf(stderr,"\n");
       // cstringarg( char* haystack, char* vname, char* carg )
       // haystack pattern: &varname=1234abc;  delimiters &, \n, \0, SPACE, EOF
       cstringarg(mbuf, "i0", cval); //
       if(strlen(cval)>0) {
          sprintf (cstr,  "i0=%d \n", atoi(cval));
          fprintf(stderr, cstr);
       cstringarg(mbuf, "i1", cval); //
          sprintf (cstr,  "i1=%d \n", atoi(cval));
       cstringarg(mbuf, "i2", cval); //
          sprintf (cstr,  "i2=%d \n", atoi(cval));
       cstringarg(mbuf, "i3", cval); //
          sprintf (cstr,  "i3=%d \n", atoi(cval));
       cstringarg(mbuf, "i4", cval); //
          sprintf (cstr,  "i4=%d \n", atoi(cval));
       inputString="";
       //delay?
       delay(1);
int main() {
    printf("initializing..."); printf("\n");
    // UART Serial com port
    Serial = serialOpen (uart, UARTclock);
    printf("starting UART loop..."); printf("\n");
    loop();
    serialClose( Serial);
    exit(0);
// eof
for the Arduino (updated):
// Arduino COM to Borland C++ Builder form
// (C) 2018 by dsyleixa
/// history:
// 0701   Serial.read delimiters
// 0700   ported to RPi comm
// 0.0.9
// 0.0.8  analog aX=analogRead(AX) (X=0...11), syntax "&AX=%d",aX
// 0.0.7  pin-loop, 6x out-pins OUTn(I/O/pwm), &_ALLPINS_=0 when BCB-close
// 0.0.6  output pins DPINn
// 0.0.3  send/receive strings
// 0.0.2  receiving strings, pattern: &varname1=value1;
// 0.0.1  receiving simple Serial char
// BCB-Arduino: Arduino to Rpi
// ver 0701
// notice:
// on Mega2560 the anaolgWrite() pwm function works on all pins 2...13 (thus also for LED_BUILTIN) plus some evtra ones.
// on ATmega168 or ATmega328P the anaolgWrite() pwm function works on pins 3, 5, 6, 9, 10, and 11
// thus (not for LED_BUILTIN).
// (thus also for LED_BUILTIN) plus some evtra ones.
// #define _DUE_MEGA_    // <<<<<<<<<<< outcomment/uncomment acc. to board type for available GPIO pins!
// i2c
#include <Wire.h>   // Incl I2C comm, but needed for not getting compile error
#define TOKLEN 30
#define MSGLEN 1024
String  inputString="";
// tools
   if (p) return (int16_t)(p - haystack);
   int i=0, pos=-1;
   strcpy(carg,"");
   if(pos==-1) {
      needle[0]=kin2[0];
      ch=haystack[pos+i];
           carg[i]='\0';
           return carg;
      if( (ch!='&') ) {
          carg[i]=ch;
          i++;
   return carg;
void writeDPin(int pin, int ival) {
  pinMode(pin, OUTPUT);  // safety
  if(ival==0)   { digitalWrite(pin, LOW); }
  else
  if(ival==255) { digitalWrite(pin, HIGH); }
  else {
     analogWrite(pin, ival);
// setup
void setup() {
  Serial.begin(115200);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  #define _DEBUG_      // <<<<<<<<<<< outcomment/uncomment for testing !!
  #ifdef _DEBUG_
  i0=0;
  i1=1;
  i2=-22;
  i3=33;
  i4=-444;
  i5=5555;
  i6= B10101010*256;
  i6+=B10101010;
  f0=0;
  f1=10.1;
  f2=-20.22;
  f3=300.333;
  f4=-4000.4444;
  f5=50000.55555;
  a0=0;
  a1=1;
  a2=2;
  a3=3;
  a4=4;
  a5=5;
  a6=6;
  a7=7;
  a8=8;
  a9=9;
  a10=10;
  a11=11;
  #endif
// loop
void loop() {
  // receive
  int  n=0;
  char inChar;
  while (Serial.available() && n<MSGLEN-1) {
       else
       inChar = (char)Serial.read();
       n++;
    inputString.toCharArray(mbuf, MSGLEN-1);
    cstringarg(mbuf, "LEDBI", cval); // LEDBI: LED_BUILTIN
      writeDPin(LED_BUILTIN, atoi(cval) );
    inputString="";
    //delay?
    delay(1);
  // send
  strcat(formatstr, "&i0=%d;&i1=%d;&i2=%d;&i3=%d;&i4=%d;&i5=%d;&i6=%d;");
  strcat(formatstr, "&A0=%d;&A1=%d;&A2=%d;&A3=%d;&A4=%d;&A5=%d;&A6=%d;&A7=%d;&A8=%d;&A9=%d;&A10=%d;&A11=%d;");
  sprintf(mbuf, formatstr, i0,i1,i2,i3,i4,i5,i6, a0,a1,a2,a3,a4,a5,a6,a7,a8,a9,a10,a11 );
  for (int i=0; i<strlen(mbuf); i++ ) Serial.print(mbuf[i]);
  strcpy(mbuf, "");
  i0++;
  //delay?
  delay(1);
// end of file
output at the Pi console:
sometimes it does not even get a connection (not before restarting anew), but sometimes then it shows:
initializing...
§&i0=0;&i1=1;&i2=-226;&A0=0;&A1=1;&A2=2;&A3=3;&A4=4;&A5=5;&A6=6;&A7=7;&A8=8;&A9=9;&A�11;
§&i0=331;&i1=1;&i2=-22;&i3=33;&i4=-444;&i5=5555;&i6=-21846;&A0=0;&A1=1;&A2=2;&A3=3;&A4=4;&A5=5;&A6=6;&A7=7;&A8=8;&A9=9;&A�11;
i0=0
i1=1
i2=-226
i3=33
i4=-444
and by that it's stalling...
(no idea BTW about how the � chars appear)
I'm afraid the increment of the i0 value in the Arduino code is not made resp not transmitted repetetively to the Pi.
I actually think that my simple comm program is not failsafe - is there a better way to send such "complete" strings there and back, using wiringPi?
dsyleixa123
Re: code for UART comm from Pi to Arduino hangs up
Thu May 30, 2019 8:45 pm
any idea anybody why it's stalling?
scruss
Thu May 30, 2019 9:19 pm
it might help to cut down your examples to the bare minimum that still shows the problem. It took me too long to find the serial open commands.
dsyleixa123
Fri May 31, 2019 8:18 am
yes, thank you,
I cut it down to the basic essentials, but now again it stalls after a couple of loops sending there and back:
Raspi code:
   UART communication
   Raspberry Pi  master
   ver 0101
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <stdint.h>
#include <time.h>
#include <errno.h>
int    Serial;
int i0;
#define TOKLEN 30
#define MSGLEN 1024
// serial TCP
void loop() {
  while(1) {
     // send
     // debug, cut-down:
     strcat(formatstr, "message from Raspi: %d;\n");
     sprintf(mbuf, formatstr, i0);
     for(uint8_t i=0; i<strlen(mbuf); i++) {           //
     //delay?
     delay(1);
     // receive
     inputString="";
     char cstr[TOKLEN];
     int  n=0;
     char inChar;
       else
       n++;
       // process mbuf !
       inputString="";
       //delay?
       delay(1);
int main() {
    loop();
    exit(0);
// eof
Arduino code:
// Arduino COM to Raspi
// ver 0101
// i2c
#include <Wire.h>
int i0 = 0;
#define TOKLEN 30
#define MSGLEN 1024
// setup
void setup() {
// loop
void loop() {
  // receive
  int  n=0;
  char inChar;
       else
       n++;
    // process mbuf !
    inputString="";
    //delay?
    delay(1);
  // send
  strcat(formatstr, "message from Arduino: %d;\n");
  i0++;
  //delay?
  delay(1);
// end of file
console output:
initializing...
§message from Arduino: 0;
§message fr211;
§message from Arduino: 2212;
§message from Arduino: 2213;
§message from Arduino: 221�no: 2210;
§message from Arduino: 2211;
then stopping...
restart, new output:
initializing...
§message from Arduino: 0gno: 618;
§message fr��message from Arduino: 615;
§message from Arduino: 616;
§message from Arduino: 617;
§message from Arduino: 618;
§message fr
then again stopping...
dsyleixa123
Fri May 31, 2019 6:18 pm
update:
adding delay(10) instead of (1) doesn't change anything, UART clock 19200 instead neither.
But:
uploading to a Arduino Due (SAM3X8E) it works like a charm, at either clock or delays! :shock:
replugging to the Mega: again always hangs up... :shock:
is that normal to the Mega ? :?
LdB
Sun Jun 02, 2019 1:45 am
Looking at your code there is an obvious problem
Follow what happens if Serial.available() returns false :-)
The Pi is very fast it will see the gap between characters when the next character is incoming but not yet received, and I would expect that it returns false at times.
I suspect you need to stay in the loop until stringComplete rather than serialDataAvail( Serial ). The alternative bail from that loop needs to be a timeout or keypress, like on any well designed comms setup. So my guess is your code fails on a fast CPU because it is wrong and badly designed.
If you want to bail from that loop on a timer simply get the system timertick and add a timeout tickcount before entering. On each loop along with the stringComplete check if you current timertick is greater than the timeout tick number you calculated. So when you come out the loop you can check if you got stringComplete, if not then your code timed out.
dsyleixa123
Sun Jun 02, 2019 7:24 am
thank you very much for your hints!
Actually the original code was derived from an original Arduino-to-Arduino-Code which already worked fine, and now one Arduino code had been substituted by a Raspi-wiringPi portation.
But yes, indeed by the following changes it now works much better:
    if (serialDataAvail(Serial)) {
        while(!stringComplete && n<MSGLEN-1) {
          else
            inChar = serialGetchar(Serial);
          if(inChar=='\n' || inChar>=' ') inputString += inChar;
          n++;
Just now it just was running about 2000-3000 loops, but then again it stalled.
Making similar changes to the Arduino code didn't make it better though.
(OTOH, all communication code is running at 115200 baud, and the Arduino Due doesn't stall as far as I observed, already >80000 loops right now... )
edit, corrected: stalled then later at >130000, too.
As to the timer: I honestly do not understand how I should write that code. Do you or anybode else have or know a code which works better than mine, just reading complete strings until '\n', and acting more failsafe for Arduino <-> Raspi communication?
Finally Arduinos and Raspis exist already a decade, I can't imagine that I am supposed to be the first one who is looking for such a communication code.
LdB
Mon Jun 03, 2019 4:10 am
Still wrong the serialDataAvail(Serial) is problematic .. don't use it.
Okay I am going to a guess at the code and I look up arduino and it has a millis() function which I will use for timeout
https://www.arduino.cc/reference/en/lan ... me/millis/
So here is my guess .. will report 2 errors buffer overrun or timeout (over 1 sec wait).
void loop() {
  while(1)
     // send
     // debug, cut-down:
     //delay?
    //delay(1);
    // Suspect you had to have the delay is because it dropped straight
    // thru the next section because your loop had serialDataAvail(Serial)
    // If the other end hasn't sent the response it would drop straight thru
     // receive
     inputString="";
     char cstr[TOKLEN];
     int  n=0;
     char inChar = 0;
     unsigned long timeout = millis() + 1000;   /* 1 second in the future */
     while (inChar != '\n' && n < MSGLEN-2
	        && millis() < timeout)
           n++;
     if (inChar == '\n')  // termonated correctly
          // process mbuf !
           inputString="";
     } else {
	   if (n == MSGLEN-1)
		fprintf(stderr,"Buffer error %i characters sent\n", n);
                else fprintf(stderr, "Timeout error no data for 1 sec\n", n);
dsyleixa123
Mon Jun 03, 2019 7:53 am
thank you, I'll try it immediately!
what I hadn't understood at first is that a timeout is needed at all, because the Arduino Serial class (providing available()) has got a built-in timeout and probably many more built-in features, opposite to the wiringPi/wiringSerial thing; tbh, I assumed both were working quite similar what wiringSerial probably doesn't (which is confusing because the wiringPi namings suggest that it would).
dsyleixa123
Mon Jun 03, 2019 11:21 am
update:
I just let it run about 40 min, and it was fine, not showing either error!
Now with an advanced message string from Arduino constructed by
int32_t i0=0,i1=0,i2=0,i3=0,i4=0,i5=0,i6=0,i7=0,i8=0,i9=0;
// test
  i0=0;
  i1=1;
  i2=-22;
  i3=33;
  i4=-444;
  i5=5555;
  i6= B10101010*256;
  i6+=B10101010;
  strcat(formatstr, "&i0=%d;&i1=%d;&i2=%d;&i3=%d;&i4=%d;&i5=%d;&i6=%d;\n");
  sprintf(mbuf, formatstr, i0,i1,i2,i3,i4,i5,i6 );
the Raspi received ~7200 loops, and then again it hung up.
(additionally, the string was faulty by it's values, but that's another issue I guess)
Raspi code:
   UART communication
   Raspberry Pi  master
   ver 0701
  * change log
  * 0701:
  * 0700
  * first adjustments
  * 0669:
  * 0667:
// (C) dsyleixa 2015
// freie Verwendung für private Zwecke
// für kommerzielle Zwecke nur nach Genehmigung durch den Autor.
// Programming language: gcc C/C++
// protected under the friendly Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License
// http://creativecommons.org/licenses/by-nc-sa/3.0/
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <stdint.h>
#include <time.h>
#include <errno.h>
char   uart[128]  =  "/dev/ttyACM0";
int    Serial;
volatile static int32_t i0=0,i1=0,i2=0,i3=0,i4=0,i5=0,i6=0,i7=0,i8=0,i9=0;          // int (general)
volatile static int16_t a0=0,a1=0,a2=0,a3=0,a4=0,a5=0,a6=0,a7=0,a8=0,a9=0,a10=0,a11=0;  // int for analogRead(pin): a0=analogRead(A0)=0, a1=analogRead(A1),...
volatile static double  f0=0,f1=0,f2=0,f3=0,f4=0,f5=0,f6=0,f7=0,f8=0,f9=0;          // double (general)
#define TOKLEN 30
#define MSGLEN 512
// debug monitor
// token tools
   int i=0, pos=-1;
   strcpy(carg,"");
   if(pos==-1) {
      needle[0]=kin2[0];
      ch=haystack[pos+i];
           carg[i]='\0';
           return carg;
      if( (ch!='&') ) {
          carg[i]=ch;
          i++;
   return carg;
// serial TCP
void loop() {
  while(1) {
     // send
     // debug, cut-down:
     // receive
     inputString="";
     char cstr[TOKLEN];
     int  n=0;
     char inChar = 0;
           n++;
     if (inChar == '\n')  // terminated correctly
        if(1) {
        // process mbuf !
        inputString="";
     } else {
	     if (n == MSGLEN-1)
int main() {
    loop();
    exit(0);
// eof
Arduino code:
// Arduino Serial to Raspi USB
// history:
// 0703  simple msg str
// 0702
// 0700
// 0101   ported for RPi USB
// 0009
// 0008  analog aX=analogRead(AX) (X=0...11), syntax "&AX=%d",aX
// 0007  pin-loop, 6x out-pins OUTn(I/O/pwm), &_ALLPINS_=0 when BCB-close
// 0006  output pins DPINn
// 0003  send/receive strings
// 0002  receiving strings, pattern: &varname1=value1;
// 0001  receiving simple Serial char
// BCB-Arduino: Arduino to RPi
// ver 0701
#define TOKLEN 30
#define MSGLEN 512
// tools
   int i=0, pos=-1;
   strcpy(carg,"");
   if(pos==-1) {
      needle[0]=kin2[0];
      ch=haystack[pos+i];
           carg[i]='\0';
           return carg;
      if( (ch!='&') ) {
          carg[i]=ch;
          i++;
   return carg;
  else
  else {
// setup
void setup() {
  Serial.begin(UARTclock);
  #ifdef _DEBUG_
  i0=0;
  i1=1;
  i2=-22;
  i3=33;
  i4=-444;
  i5=5555;
  i6= B10101010*256;
  i6+=B10101010;
  #endif
// loop
void loop() {
  // receive
  int  n=0;
  char inChar;
  while(Serial.available() && !stringComplete && n<MSGLEN-1) {
       else
       inChar = inChar = (char)Serial.read();
       n++;
    // process mbuf!
    inputString="";
    //delay?
    delay(1);
  // send
   //delay?
  delay(1);
  i0++;
// end of file
Raspi console output:
i0=7157
i1=0
i2=1
i3=0
i4=-22
§&i0=7158;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
i0=7158
i1=0
i2=1
i3=0
i4=-22
§&i0=7159;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
i0=7159
i1=0
i2=1
i3=0
i4=-22
§&i0=7160;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
PS,
last int values and cstring instead are expected to be
i0=7159;
i1=1;
i2=-22;
i3=33;
i4=-444;
§&i0=7160;&i1=1;&i2=22;&i3=33;&i4=-44;&i5=5555;&i6=43690;
which is actually performed correctly by my Arduino Due...
LdB
Mon Jun 03, 2019 11:43 am
FYI "stringComplete" is no longer in use stop putting back the lines with it .. it does nothing now on the RASPI code cut them all out.
Testing:
1.) Fire the RASPI end but don't send anything from the audrino end and check it times out properly on serialGetChar .
If it doesn't timeout it means we need to put the timeout deeper actually in the loop code for "serialGetchar".
If you don't know how to code that, then find the serialGetChar code and post it for us to modify. Actually you might
as well do serialPutchar at same time because both really need timeouts.
FYI your audrino end code has same issues of not having proper timeouts etc and it is actually highly likely it has stopped sending which is why you get stuck.
Usually the RX/TX is done on interrupts, it is a bit clunky doing it like this because you can get stuck in loops without timeouts.
dsyleixa123
Mon Jun 03, 2019 11:59 am
as stated (IIRC) the Serial class on Arduino has integrated timeouts, and people who use UART from Arduino to Arduino by Serial() never needed extra ones... (i used that Arduino code to another Aduino already successfully, also from an Arduino to a PC running Borland C++ Builder, just for the Raspi it don't work).
dsyleixa123
Mon Jun 03, 2019 12:01 pm
firing the Raspi without sending from Arduino:
  //for (int i=0; i<strlen(mbuf); i++ ) Serial.print(mbuf[i]);
initializing...
LdB
Mon Jun 03, 2019 12:05 pm
Ok now try it without the audrino conencted and see if it gets stuck in send loop.
If it still loops correctly with the timeout error the problem is on audrino end.
Essentially what you are checking is the RASPI cant get stuck anywhere, it should just circulate with timeout errors.
The more I look at however I would like to see the code for serialGetchar & serialPutChar :-)
dsyleixa123
Mon Jun 03, 2019 12:16 pm
I unplugged the Arduino from USB, then again restarted the program from Geany by F5
now it says the same, very quickly no 1 sec delay in between:
dsyleixa123
Mon Jun 03, 2019 12:20 pm
the code for serialGetchar & serialPutChar I don't know, it's somewhere in wiringSerial I guess...
LdB
Mon Jun 03, 2019 12:25 pm
I found it .. try this now has a timeout on both send and recieve
void loop() {
  while(1)
     unsigned long timeout;
     // send
     // debug, cut-down:
     uint8_t i, len;
     len = strlen(mbuf);
     for(i=0; i<len && millis() < timeout; i++) {
     if (i  != len)
            fprintf(stderr, "Timeout TX error send took over 1 sec\n", n);
     // receive
     inputString="";
     char cstr[TOKLEN];
     int  n=0;
     char inChar = 0;
	    if (Serial.available())
			n++;
          // process mbuf !
           inputString="";
     } else {
	   if (n == MSGLEN-1)
                else fprintf(stderr, "Timeout RX error no data for 1 sec\n", n);
dsyleixa123
Mon Jun 03, 2019 12:34 pm
compile error: there is no
for the Pi
dsyleixa123
Mon Jun 03, 2019 12:38 pm
using serialDataAvailable(Serial):
§&i0=1362;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=1363;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=1364;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=1365;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=1366;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=1367;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=1368;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=1369;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
restarting,
§&i0=3251;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3252;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3253;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3254;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3255;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3256;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3257;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3258;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3259;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3260;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3261;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3262;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3263;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3264;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3265;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3266;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
LdB
Mon Jun 03, 2019 12:47 pm
Yep serialDataAvailable(Serial) was correct substitute
The audrino is handshaking it off by look, possibly can't process fast enough because it starts okay and than seems to catch it.
You need to fix arduino end .. the RASPI end is now correct :-)
What you could do is take the send timeout up to something like 3 seconds short term.
timeout = millis() + 3000;   /* 3 second in the future */
dsyleixa123
Mon Jun 03, 2019 12:58 pm
same thing for 3000ms send timeout :(
§&i0=3967;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3968;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3969;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3970;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3971;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3972;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
Timeout TX error send took over 3000 msec
§&i0=3973;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3974;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=3975;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
LdB
Mon Jun 03, 2019 1:24 pm
You might have to ask Gordon if you are allowed to sit in loops like this with wiringPi, it almost looks to me like the linux serial device is blocking.
Out of interest lets sleep the thread for a 10ms after each character send .. so yield back to linux
void loop() {
  while(1)
     // send
     // debug, cut-down:
     uint8_t i, len;
     len = strlen(mbuf);
        usleep(10000);  // sleep 10ms
     if (i  != len)
     // receive
     inputString="";
     char cstr[TOKLEN];
     int  n=0;
     char inChar = 0;
	    if (serialDataAvailable(Serial))
			n++;
          // process mbuf !
           inputString="";
     } else {
	   if (n == MSGLEN-1)
dsyleixa123
Mon Jun 03, 2019 1:39 pm
now it's
initializing...
§&i0=0;&i1;3;
§&i0=803;&&i5=-1;&i6=33;
§&i0=801;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
§&i0=802;&i1=0;&i2=1;&i3=0;&i4=-22;&i5=-1;&i6=33;
LdB
Mon Jun 03, 2019 1:56 pm
Sorry that does not mean anything to me, what is happening.
From what I can work out the RASPI is looping waiting for data from the other device which isn't sending.
You can tell it is looping still because of the timeout messages.
So I am guessing the attached device is not responding ... any way to know if the other device is actually sending ????
If the other end is code just Arduino you can just follow the same thing with timeouts so it never locks up.
dsyleixa123
Mon Jun 03, 2019 2:12 pm
I have no idea, I'm afraid
Return to “C/C++”
