nishu2901
std::thread not working with clang in rpi3
Wed Apr 10, 2019 1:48 pm
I have below code :
#include <iostream>
#include <thread>
int main()
    std::thread th([]() {
        std::cout << "Hello, World!" << std::endl;
    th.join();
    return 0;
and i am compiling with : clang++ -o demo demo.cpp -lpthread -std=c++11
and when i execute it i get below unexpected output :
[email protected] ~ $ ./demo
pure virtual method called
terminate called without an active exception
Aborted
my clang version is :
Raspbian clang version 3.5.0-10+rpi1 (tags/RELEASE_350/final) (based on LLVM 3.5.0)
Target: arm-unknown-linux-gnueabihf
Thread model: posix
Can anyone help me with how to resolve this ?
topguy
Re: std::thread not working with clang in rpi3
Wed Apr 10, 2019 4:27 pm
Since its CLang 3.5 it matches my Raspbian Jessie installation. Raspbian stretch should have CLang 3.8 and 4.0 so maybe an upgrade to the newest Raspbian version helps.. ( I dont have a way to test that, but someone else might have. )
swampdog
Wed Apr 10, 2019 11:23 pm
I don't know much about clang. However, I needed to build LLVM and built clang (6.01) as most of the work was done. Mine isn't "installed" properly and thus requires LD_LIBRARY_CONFIG which *might* help with your problem. I also have multiple "gcc" versions and for this I used gcc (8.2.0) and they again are not "installed" properly. "c.cc" is your posted code.
[email protected]:/wrk/T $ /usr/local/GCC/8.2.0/bin/g++ -o c c.cc -lpthread
[email protected]:/wrk/T $ LD_LIBRARY_PATH=/usr/local/GCC/8.2.0/lib ./c
Hello, World!
Okay, now try clang..
[email protected]:/wrk/T $ LD_LIBRARY_PATH=/usr/local/GCC/8.2.0/lib /usr/local/QT/clang/bin/clang++ -o cl c.cc -lpthread
[email protected]:/wrk/T $ LD_LIBRARY_PATH=/usr/local/GCC/8.2.0/lib ./cl
Hello, World!
Initially I did this..
[email protected]:/wrk/T $ ./cl
Aborted (core dumped)
..'cos it had linked against "/usr/lib/arm-linux-gnueabihf/libstdc++.so.6" rather than "/usr/local/GCC/8.2.0/lib/libstdc++.so.6".
Maybe you have a similar issue?
There are bugs posted though..
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=65255
viewtopic.php?t=131856
Paeryn
Thu Apr 11, 2019 12:31 am
Clang 6.0.1 is in the Raspbian Stretch repo (did this get added at some point? I had 4.0 installed, I'm sure I wouldn't have installed that if 6.0 was there).
[email protected]:~/Programming/asm/thr $ clang++-6.0 --version
clang version 6.0.1-10+rpi1~bpo9~rpt1 (tags/RELEASE_601/final)
Anyway, compiling with this version works out-of-the-box (it did with 4.0 too though 4.0 has to be told to use the c++11 standard, 6.0 defaults to c++14)
[email protected]:~/Programming/asm/thr $ clang++-6.0 -o hello hello.cc -pthread
[email protected]:~/Programming/asm/thr $ ./hello
Hello, World!
Return to “C/C++”
