Zili
How to use libssh2 in C
Mon Mar 18, 2019 3:32 pm
I'm trying to make a C program to connect to an ssh server. I used an
apt-get install libssh2-1
but the linker can't find the libraries!
Can someone help me ?
Thank you.
rpdom
Re: How to use libssh2 in C
Mon Mar 18, 2019 4:41 pm
You'll probably need libssh2-1-dev for building programs. libssh2-1 (no -dev) is used just for running them.
Unreadable squiggle
PeterO
Mon Mar 18, 2019 5:00 pm
A useful command to use is "apt-cache search package-name-here" I'm not in fornt of a PI right now, but my MINT linux machine produced this output...
$ apt-cache search  libssh2-1
libssh2-1 - SSH2 client-side library
libssh2-1-dbg - SSH2 client-side library (debug package)
libssh2-1-dev - SSH2 client-side library (development headers)
PeterO
Zili
Sun Mar 24, 2019 11:28 am
Thanks to rpdom and PeterO.
The problem was trivial.
simply the library is not called libssh2.lib but ssh2 !
The compilation command is:
gcc -Wall -Wno-unused-function myProgram.c -o myProgram.exe -l ssh2
jahboater
Sun Mar 24, 2019 1:15 pm
No, the library is called libssh2.lib
The C compiler driver fills in the full name for you.
For example, the math library is called "libm.so" but to use it in C you simply give "-lm"
The compiler added the "lib" at the front and the ".so" at the back.
CanteoCantineo
Mon Mar 25, 2019 3:33 pm
Can we import any C library using this method?
jahboater
Mon Mar 25, 2019 5:14 pm
As far as I know that's how C compilers have worked since the dawn of time.
Mon Mar 25, 2019 5:36 pm
jahboater,
Indeed. On Unix anyway.
On other systems the C compilers would sensibly accept whatever name the library had. No "lib" prefix required. It is kind of weird is it not?
I recall being mightily puzzled by this when discovering Linux in 1997 or so.
PeterO
Mon Mar 25, 2019 6:36 pm
libiberty is amusing :-)
PeterO
Return to “C/C++”
