RogerW
CodeBlocks and pigpio
Tue Mar 12, 2019 11:15 am
I am learning to use codeblocks to develop an application that uses the pigpio library. the using the pigpio library means the application needs to run as sudo.
I can do this by running codeblocks as sudo but then all the files it creates need sudo privileges if I want to delete them.
Is there a way to change the command that codeblocks uses to run the app?
Re: CodeBlocks and pigpio
Tue Mar 12, 2019 12:03 pm
pigpio does NOT need sudo. It's the pigpiod daemon that runs privileged.
Most GPIO access doesn't need sudo.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
RogerW
Tue Mar 12, 2019 4:32 pm
True for the daemon but I am not using it. I link direct to the C library. I may have missed something but the first time I ran the program I was told I needed sudo.
Tue Mar 12, 2019 5:37 pm
With WiringPi you can set an environment variable to allow it to run without sudo.
You have clearly caught a dose of sudoitis. That's a nasty disease where Raspberry users assume the answer to all problems is sudo.
export WIRINGPI_GPIOMEM=1 in bash.
Or do it in C programs with
  setenv ("WIRINGPI_GPIOMEM", "1", 1);
RogerW
Tue Mar 12, 2019 5:46 pm
Again true but I am not using wiringpi. I am using the pigpio C interface library.
Tue Mar 12, 2019 5:48 pm
What version of pigpiod?
RogerW
Tue Mar 12, 2019 5:55 pm
I am not using pigpiod. I am using the C pigpio library which controls the gpios directly.
Tue Mar 12, 2019 5:58 pm
What version of that are you using?
Where did it come from?
RogerW
Tue Mar 12, 2019 6:05 pm
Its there as standard, compile with -lpigpio. See http://abyz.me.uk/rpi/pigpio/cif.html
[email protected]
Wed Mar 13, 2019 10:54 am
This hasn't been needed for a few years now. It's the default. wiringPi checks if it can access /dev/gpiomem first. Sadly this breaks pwm and some clock codes, but hey ho.
However, the sudo'itis is indeed, a nasty disease, I'd suggest that people stop using sudo unless it's really needed, then again, I've basically given up - it's their computer after all and if someone wants to tell them to sudo a wget/curl script into bash then who am I to stop them.
-Gordon
Last edited by [email protected] on Wed Mar 13, 2019 11:36 am, edited 1 time in total.
joan
Wed Mar 13, 2019 11:30 am
If you link in the pigpio library (-lpigpio)you need to run the resulting program with root privileges. The library uses various hardware peripherals (e.g. DMA, PWM, PCM, SPI) in a way which is not permitted to a standard userland process.
This is not necessary for programs which use the pigpio daemon (e.g. the Python module, pigs, programs linked with -lpigpiod_if, -lpigpiod_if2).
RogerW
Wed Mar 13, 2019 11:42 am
joan - thanks for the clarification.
I could compile with codeblocks and then run the app from a console but that would be clumsy and I could not use the debugger built into codeblocks.
For the moment I have modified the desktop entry for file manager to run that sudo as well as codeblocks which does mean I can access files if needs be but I don't like using sudo without a good reason.
So my question remains - can I change the command that codeblocks uses to run my program.
Return to “C/C++”
