The best library for a 3D game?
Posted: Sat Dec 29, 2018 11:18 pm
by WillBoxOwO
Hello there.
I just finished a series of tutorials on how to program in C++!
I learned a ton of things. For example, I know how to make a calculator. Thats so exciting!
I learned all of this with one goal in mind: id like to make a Minecraft clone.
Cool, right?
But theres one big problem: Everytime I try to import glub or opengl libraries, it just throws me an error saying that none of them are installed.
I searched pretty much everywhere, im aswell unshure of what I should type to get the missing files I need.
So my questions are:
- Are those libraries the best to develop on a raspberry pi 3B?
- Were could I find them?
- How can I install them?
- Will I be able to create standalone builds to publish on github?
And to finish this up:
- Will I be able to add material properties similar of the ones you can find in Quake 3 (for example, reflexions and shiny effects)?
Re: The best library for a 3D game?
Posted: Sun Dec 30, 2018 2:18 am
by Gavinmc42
Pi's basically have a OpenGLES rendering GPU ie Android type chips.
So PC world OpenGL examples need conversion down to OpenGLES.
The next level after rendering a 3D triangle is usually 3D cubes with textures.
In OpenGL a cube is 6 squares, in OpenGLES it is 12 triangles, that is the main point to understand.
Textured cubes in OpenGLES - try Android examples?
Unless you use Gentoo64 which has a working OpenGL driver ;)
I find the Mesa3D demos useful.
https://www.mesa3d.org/repository.html
google will find stuff like this
https://github.com/fogleman/Craft
https://www.minetest.net/
Cube Worlds are just a pile of textured cubes, so if you can do one, many is just a bunch more ;)
http://www.opengl-tutorial.org/beginner ... ured-cube/
Most games use the SDL library as it is portable across most OS's.
https://www.libsdl.org/
Posted: Thu Jan 03, 2019 1:56 am
by Gavinmc42
Relevant?
Gaming on Kodi?
https://kodi.wiki/view/Libretro
3D looks new, NX engine for 2D?
I have thought as settop boxes get more powerful why not play games on them.
Kodi and Retropie merging?
Add that new Steam link?
https://www.raspberrypi.org/blog/steam- ... pberry-pi/
Posted: Thu Jan 03, 2019 2:44 am
by WillBoxOwO
Just compiled SDL tough. Took 3 hours haha.
That libretro thing sounds nice tho, how can I install it?
Posted: Thu Jan 03, 2019 3:21 am
by WillBoxOwO
Found this code online (lightly edited it to add a background)
//Compile with : "g++ -o Prog main.cpp `sdl-config --cflags --libs` -lGL -lglut -lGLU" on linux !!!
#include <SDL/SDL.h>
#include <GL/gl.h>
#include <GL/glu.h>
//GLAPI void GLAPIENTRY gluOrtho2D (GLdouble left, GLdouble right, GLdouble bottom, GLdouble top);
//#include <GL/glut.h>
#define LARGEUR 640
#define LONGUEUR 480
void dessiner();
double angleX, angleZ;
int main(int argc, char *argv[])
	SDL_Init(SDL_INIT_VIDEO);
	SDL_WM_SetCaption("The 3D Cube of the dead !!!",NULL);
	SDL_SetVideoMode(LARGEUR, LONGUEUR, 32, SDL_OPENGL);
	SDL_EnableKeyRepeat(10,10);
	//SDL_ShowCursor(false);
	glMatrixMode(GL_PROJECTION);
	glLoadIdentity();
	gluPerspective(70,(double)LARGEUR/LONGUEUR,1,1000);
	glEnable(GL_DEPTH_TEST);
	dessiner();
	bool continuer = true;
	SDL_Event event;
	Uint32 last_time = SDL_GetTicks();
	Uint32 current_time,ellapsed_time, start_time;
	while (continuer)
		start_time = SDL_GetTicks();
        	while(SDL_PollEvent(&event))
        	switch(event.type)
			case SDL_QUIT:
				continuer = false;
				break;
			case SDL_KEYDOWN:
				switch(event.key.keysym.sym)
					/*case SDLK_RIGHT:
						angle = 1;
						break;
					case SDLK_LEFT:
						angle = -1;
						break;*/
					/*case SDLK_UP:
						posY += 5;
						break;
					case SDLK_DOWN:
						posY -= 5;
						break;*/
				break;
			/*case SDL_MOUSEMOTION:
				posX = event.motion.x-LARGEUR/2;
				posY = LONGUEUR/2-event.motion.y;
				break;*/
		current_time = SDL_GetTicks();
		ellapsed_time = current_time - last_time;
		last_time = current_time;
		angleZ += 0.05 * ellapsed_time;
		angleX += 0.05 * ellapsed_time;
		dessiner();
		ellapsed_time = SDL_GetTicks() - start_time;
		if (ellapsed_time < 10)
			SDL_Delay(10 - ellapsed_time);
	SDL_Quit();
	return 0;
void dessiner()
	glClear( GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
	glMatrixMode( GL_MODELVIEW );
	glLoadIdentity( );
	gluLookAt(3,4,2,0,0,0,0,0,1); // Caméra
	glRotated(angleX, 1, 0, 0);
	glRotated(angleZ, 0, 0, 1);
	glBegin(GL_QUADS); //Début pour le CUBEEEEE
	glColor3ub(255,0,0); //face rouge
	glVertex3d(11,11,11);
	glVertex3d(11,11,-11);
	glVertex3d(-11,11,-11);
	glVertex3d(-11,11,11);
	glColor3ub(0,255,0); //face verte
	glVertex3d(11,-11,11);
	glVertex3d(11,-11,-11);
	glColor3ub(0,0,255); //face bleue
	glVertex3d(-11,-11,11);
	glVertex3d(-11,-11,-11);
	glColor3ub(255,255,0); //face jaune
	glColor3ub(0,255,255); //face cyan
	glColor3ub(255,0,255); //face magenta
	glVertex3d(1,1,1);
	glVertex3d(1,1,-1);
	glVertex3d(-1,1,-1);
	glVertex3d(-1,1,1);
	glVertex3d(1,-1,1);
	glVertex3d(1,-1,-1);
	glVertex3d(1,1,-1);
	glVertex3d(1,1,1);
	glVertex3d(-1,-1,1);
	glVertex3d(-1,-1,-1);
	glVertex3d(1,-1,1);
	glVertex3d(-1,1,1);
	glVertex3d(1,1,-1);
	glVertex3d(1,-1,1);
	glVertex3d(1,1,1);
	glVertex3d(-1,1,1);
	glEnd();
	glFlush();
	SDL_GL_SwapBuffers();
Since it was asking for it, I compiled it with the following command (Removed -lglut)
g++ -o Prog main.cpp `sdl-config --cflags --libs` -lGL -lGLU
It gave the following result:
To render that scene tho, it uses 100% of the CPU! And id say the framerate is about 17fps... Not good. Its a simple scene. It should be the fluidiest thing ever... :?
What am I doing wrong?
Posted: Thu Jan 03, 2019 3:34 am
by Gavinmc42
Probably software rendered OpenGL not accelerated OpenGL.
glxinfo reports?
On my Gentoo64 Pi I get OpenGL VC4 V3D 2.1, Mesa 18.3.0-rc4
I also get OpenGLES 1.0 and 2.0
You could try compiling for OpenGLES instead of OpenGL?
Once you can texture that cube, Cube Worlds are next.
Posted: Thu Jan 03, 2019 4:04 am
by WillBoxOwO
Output of glxinfo:
[email protected]:~ $ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
    GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
    GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: VMware, Inc. (0xffffffff)
    Device: llvmpipe (LLVM 3.9, 128 bits) (0xffffffff)
    Version: 13.0.6
    Accelerated: no
    Video memory: 841MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 3.3
    Max compat profile version: 3.0
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.0
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.9, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 13.0.6
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
    GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
    GL_AMD_shader_trinary_minmax, GL_AMD_vertex_shader_layer,
    GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,
    GL_ANGLE_texture_compression_dxt5, GL_ARB_ES2_compatibility,
    GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
    GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
    GL_ARB_clear_buffer_object, GL_ARB_clip_control,
    GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_object,
    GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary,
    GL_ARB_get_texture_sub_image, GL_ARB_gpu_shader_fp64,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
    GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
    GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
    GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
    GL_ARB_multi_draw_indirect, GL_ARB_occlusion_query2,
    GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
    GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
    GL_ARB_shader_bit_encoding, GL_ARB_shader_objects,
    GL_ARB_shader_stencil_export, GL_ARB_shader_subroutine,
    GL_ARB_shader_texture_lod, GL_ARB_shading_language_420pack,
    GL_ARB_shading_language_packing, GL_ARB_stencil_texturing, GL_ARB_sync,
    GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
    GL_ARB_texture_buffer_range, GL_ARB_texture_compression_rgtc,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_float,
    GL_ARB_texture_gather, GL_ARB_texture_mirror_clamp_to_edge,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
    GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
    GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
    GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
    GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
    GL_ARB_transform_feedback_instanced, GL_ARB_uniform_buffer_object,
    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
    GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev,
    GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
    GL_ATI_blend_equation_separate, GL_ATI_texture_float,
    GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_blend_equation_separate,
    GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
    GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
    GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_shader_integer_mix, GL_EXT_texture_array,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_integer,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
    GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
    GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_KHR_context_flush_control, GL_KHR_debug,
    GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
    GL_MESA_texture_signed_rgba, GL_MESA_ycbcr_texture,
    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil,
    GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 3.0 Mesa 13.0.6
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
    GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3,
    GL_ANGLE_texture_compression_dxt5, GL_APPLE_packed_pixels,
    GL_APPLE_vertex_array_object, GL_ARB_ES2_compatibility,
    GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
    GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_occlusion_query2, GL_ARB_pixel_buffer_object,
    GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_shader_stencil_export, GL_ARB_shader_texture_lod,
    GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
    GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_stencil_texturing,
    GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_transform_feedback_instanced, GL_ARB_transpose_matrix,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
    GL_ATI_fragment_shader, GL_ATI_separate_stencil,
    GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
    GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
    GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
    GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
    GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
    GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
    GL_EXT_point_parameters, GL_EXT_polygon_offset,
    GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex,
    GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,
    GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
    GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
    GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_integer, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
    GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
    GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
    GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_KHR_context_flush_control, GL_KHR_debug, GL_MESA_pack_invert,
    GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
    GL_MESA_window_pos, GL_MESA_ycbcr_texture, GL_NV_blend_square,
    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
    GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_primitive_restart, GL_NV_texgen_reflection,
    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
    GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 13.0.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
    GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
    GL_APPLE_texture_max_level, GL_EXT_base_instance,
    GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
    GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float, GL_EXT_copy_image,
    GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,
    GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
    GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_polygon_offset_clamp, GL_EXT_read_format_bgra,
    GL_EXT_separate_shader_objects, GL_EXT_shader_integer_mix,
    GL_EXT_texture_border_clamp, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_format_BGRA8888, GL_EXT_texture_rg,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_type_2_10_10_10_REV,
    GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_KHR_debug,
    GL_MESA_shader_integer_functions, GL_NV_draw_buffers,
    GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,
    GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
    GL_OES_EGL_image_external, GL_OES_EGL_sync,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
    GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
    GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
    GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
    GL_OES_rgb8_rgba8, GL_OES_standard_derivatives, GL_OES_stencil8,
    GL_OES_surfaceless_context, GL_OES_texture_3D,
    GL_OES_texture_border_clamp, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_texture_stencil8, GL_OES_vertex_array_object
240 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x16e 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x16f 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x170 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x171 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x172 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x173 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x174 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x175 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x176 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x177 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x178 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x179 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x17a 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x17b 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x17c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x17d 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x17e 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x17f 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x180 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x181 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x182 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x183 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x184 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x185 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x186 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x187 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x188 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x189 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x18a 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x18b 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x18c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x18d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x18e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x18f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x190 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x191 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x192 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x193 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x194 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x195 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x196 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x197 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x198 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x199 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x19a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x19b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x19c 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x19d 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x19e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x19f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x1a0 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x1a1 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x1a2 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x1a3 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x1a4 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x1a5 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x1a6 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x1a7 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x1a8 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x1a9 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x1aa 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x1ab 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x1ac 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x1ad 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x1ae 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x1af 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x1b0 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x1b1 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x1b2 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x1b3 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x1b4 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x1b5 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x1b6 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x1b7 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x1b8 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x1b9 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x1ba 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x1bb 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x1bc 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x1bd 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x1be 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x1bf 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x1c0 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x1c1 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x1c2 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x1c3 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x1c4 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x1c5 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x1c6 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x1c7 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x1c8 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x1c9 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x1ca 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x1cb 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x1cc 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x1cd 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x1ce 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x1cf 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x1d0 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x1d1 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x1d2 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x1d3 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x1d4 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x1d5 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x1d6 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x1d7 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x1d8 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x1d9 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x1da 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x1db 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x1dc 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x1dd 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x1de 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x1df 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x1e0 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x1e1 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x1e2 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x1e3 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x1e4 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x1e5 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x1e6 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x1e7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x1e8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x1e9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x1ea 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x1eb 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x1ec 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x1ed 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x1ee 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x1ef 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x1f0 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x1f1 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x1f2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x1f3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x1f4 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x1f5 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x1f6 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x1f7 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x1f8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x1f9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x1fa 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x1fb 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x1fc 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x1fd 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x1fe 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x1ff 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x200 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x201 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x202 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x203 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x204 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x205 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x206 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x207 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x208 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x209 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x20a 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x20b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x20c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x20d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x20e 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x20f 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x210 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x211 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x212 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x213 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x214 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x215 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x216 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x217 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x218 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x219 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x21a 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x21b 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x21c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x21d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x21e 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x21f 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x220 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x221 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x222 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x223 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x224 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x225 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x226 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x227 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x228 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x229 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x22a 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x22b 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x22c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x22d 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x22e 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x22f 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x230 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x231 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x232 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x233 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x234 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x235 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x236 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x237 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x238 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x239 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x23a 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x23b 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x23c 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x23d 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x23e 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x23f 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x240 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x241 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x242 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x243 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x244 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x245 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x246 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x247 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x248 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x249 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x24a 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x24b 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x24c 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x24d 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x24e 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x24f 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x250 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x251 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x252 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x253 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x254 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x255 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x256 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x257 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x258 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x259 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x25a 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x25b 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x041 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
300 GLXFBConfigs:
0x042 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x043 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x044 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x045 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x046 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x047 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x048 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x049 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x04a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x04b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x04c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x04d 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x04e 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x04f 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x050 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x051 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x052 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x053 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x054 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x055 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x056 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x057 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x058 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x059 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x05a 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x05b 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x05c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x05d 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x05e 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x05f 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x060 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x061 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x062 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x063 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x064 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x065 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x066 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x067 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x068 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x069 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x06a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x06b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x06c 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x06d 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x06e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x06f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x070 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x071 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x072 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x073 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x074 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x075 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x076 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x077 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x078 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x079 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x07a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x07b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x07c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x07d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x07e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x07f 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x080 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x081 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x082 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x083 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x084 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x085 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x086 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x087 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x088 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x089 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x08a 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x08b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x08c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x08d 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x08e 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x08f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x090 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x091 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x092 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x093 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x094 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x095 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x096 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x097 24 tc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x098 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x099 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x09a 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x09b 24 tc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x09c 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x09d 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x09e 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x09f 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x0a0 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x0a1 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x0a2 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x0a3 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x0a4 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x0a5 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x0a6 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x0a7 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x0a8 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x0a9 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x0aa 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x0ab 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x0ac 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x0ad 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x0ae 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x0af 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x0b0 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x0b1 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x0b2 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x0b3 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x0b4 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x0b5 24 tc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x0b6 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x0b7 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x0b8 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x0b9 24 tc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x0ba  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0bb  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0bc  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0bd  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0be  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0bf  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0c0  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0c1  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0c2  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0c3  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0c4  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0c5  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0c6  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0c7  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0c8  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0c9  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0ca  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x0cb  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x0cc  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0cd  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0ce  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0cf  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0d0  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x0d1  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x0d2  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 32  0  0  0  0  0  0 0 None
0x0d3  0 tc  0  16  0 r  . .   5  6  5  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x0d4  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0  0  0  0  0  0 0 None
0x0d5  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x0d6  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0  0  0  0  0  0 0 None
0x0d7  0 tc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x0d8 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0d9 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0da 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0db 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0dc 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x0dd 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x0de 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x0df 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x0e0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x0e1 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x0e2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x0e3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x0e4 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0e5 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0e6 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0e7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0e8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x0e9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x0ea 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0eb 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0ec 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ed 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0ee 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x0ef 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x0f0 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x0f1 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x0f2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x0f3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x0f4 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0  0  0  0  0  0 0 None
0x0f5 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 32  0 16 16 16 16  0 0 Slow
0x0f6 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0f7 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0f8 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0f9 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0fa 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x0fb 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x0fc 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0fd 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x0fe 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x0ff 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x100 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x101 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x102 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x103 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x104 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x105 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x106 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x107 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x108 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x109 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x10a 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x10b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x10c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x10d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x10e 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x10f 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x110 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x111 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x112 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0  0  0  0  0  0 0 None
0x113 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x114 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x115 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x116 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x117 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x118 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0  0  0  0  0  0 0 None
0x119 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0  0  0 16 16 16 16  0 0 Slow
0x11a 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x11b 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x11c 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x11d 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x11e 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0  0  0  0  0  0 0 None
0x11f 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 16  0 16 16 16 16  0 0 Slow
0x120 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x121 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x122 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x123 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x124 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0  0  0  0  0  0 0 None
0x125 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  0 16 16 16 16  0 0 Slow
0x126 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x127 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x128 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x129 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x12a 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8  0  0  0  0  0 0 None
0x12b 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 24  8 16 16 16 16  0 0 Slow
0x12c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x12d 24 dc  0  32  0 r  . .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x12e 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x12f 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x130 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0  0  0  0  0  0 0 None
0x131 24 dc  0  32  0 r  y .   8  8  8  8 .  s  0 32  0 16 16 16 16  0 0 Slow
0x132 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x133 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x134 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x135 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x136 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0  0  0  0  0  0 0 None
0x137 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0  0  0 16 16 16  0  0 0 Slow
0x138 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x139 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x13a 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x13b 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x13c 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0  0  0  0  0  0 0 None
0x13d 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 16  0 16 16 16  0  0 0 Slow
0x13e 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x13f 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x140 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x141 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x142 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0  0  0  0  0  0 0 None
0x143 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  0 16 16 16  0  0 0 Slow
0x144 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x145 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x146 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x147 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x148 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8  0  0  0  0  0 0 None
0x149 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 24  8 16 16 16  0  0 0 Slow
0x14a 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x14b 24 dc  0  24  0 r  . .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x14c 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x14d 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x14e 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0  0  0  0  0  0 0 None
0x14f 24 dc  0  24  0 r  y .   8  8  8  0 .  s  0 32  0 16 16 16  0  0 0 Slow
0x150  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x151  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x152  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x153  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x154  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0  0  0  0  0  0 0 None
0x155  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x156  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x157  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x158  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x159  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x15a  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0  0  0  0  0  0 0 None
0x15b  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x15c  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x15d  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x15e  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x15f  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x160  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0  0  0  0  0  0 0 None
0x161  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x162  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x163  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x164  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x165  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x166  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8  0  0  0  0  0 0 None
0x167  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x168  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 32  0  0  0  0  0  0 0 None
0x169  0 dc  0  16  0 r  . .   5  6  5  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x16a  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0  0  0  0  0  0 0 None
0x16b  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0 16 16 16  0  0 0 Slow
0x16c  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0  0  0  0  0  0 0 None
0x16d  0 dc  0  16  0 r  y .   5  6  5  0 .  .  0 32  0 16 16 16  0  0 0 Slow
How could I compile it to OpenGLES? I really dont know what arguments I should add in there.
Posted: Thu Jan 03, 2019 4:41 am
by jdonald
WillBoxOwO congrats on getting your cube rendered. Did you enable the full OpenGL driver? Run sudo raspi-config, select Advanced, and choose OpenGL with Full KMS.
To confirm if it took effect, after rebooting run lsmod | grep vc4. Also try glxgears. It should have three gears in clear red, green, and blue and run at 60 fps but this will require a Pi 2 or newer. I should also mention that the driver is not compatible with BerryBoot, which unfortunately I think I saw in one of your screenshots.
One quick way to run your program through GLES (and the legacy driver) would be to use gl4es, but that is unlikely to improve the performance. Let's make sure you have GPU acceleration working properly with OpenGL first.
Posted: Thu Jan 03, 2019 4:46 am
by WillBoxOwO
I dont want to touch those options. Its going to mess up my Berryboot configuration! Thanks tho. :mrgreen:
Posted: Thu Jan 03, 2019 5:11 am
by Gavinmc42
Are you running this on a Pi?
glxinfo report does not look like it
QEMU on AMD box, VMware, LLVM?
On Gentoo64 on Pi, my glxgears is the normal 60fps
It should look like that window with the blue, red , green gears.
viewtopic.php?f=54&t=188448
Posted: Thu Jan 03, 2019 5:54 am
by jdonald
That's too bad Berryboot is in the way. If you're running the legacy driver this not only hinders testing GL/GLUT/GLFW applications, but you can't write standard GLES either. You would instead have to look at the VideoCore examples under /opt/vc like hello_triangle. I hope you can get a second SD card as that would open up a lot more possibilities including but not limited to Gentoo or just Raspbian with the open-source driver.
If you're truly restricted to Berryboot and the legacy driver, another option is to use gl4es which will likely get that cube running at 60 fps.
sudo apt install cmake libx11-dev
cd ~ && git clone https://github.com/ptitSeb/gl4es.git
cd gl4es
cmake -DBCMHOST=1 -DCMAKE_BUILD_TYPE=Release . && make
cd path/to/your/cube
LIBGL_FB=1 LD_LIBRARY_PATH=~/gl4es/lib ./your-program
Posted: Thu Jan 03, 2019 7:16 am
by Gavinmc42
Never used Berryboot so I have no idea if this is the issue.
Lost count of the SD/uSD cards I have for Pi stuff.
These days I mostly use 16 or 32GB Sandisk A1 uSD cards, with the 16's being good value if you shop around.
A1 rated cards are good for the many small read/writes the Pi's OS's can do.
Copy/extract the mesa-demos to a folder on your Pi then do a "sudo chmod -x configure" in the root directory of that folder
When you run it "./configure" it will check and report what your OS has in the way of GL, EGL, GLES, DRM etc
Pay attention to what it reports.
Then run "make" this should compile a whole bunch of examples.
Expect some warning messages and a long wait.
This will work in Raspbian or Gentoo64 or most other Pi distributions if the GCC C compiler etc is already installed.
You can edit each example and recompile by going "make "example" ".
Geany is the editor I use simple stuff like this, it should recognize your C compiler and make it a one button recompile .
You won't be doing any 3D games unless you can get OpenGL or OpenGLES working.
Posted: Thu Jan 03, 2019 7:33 am
by Gavinmc42
I have been playing with Rust the last few days.
Did a google and found this.
http://kiss3d.org/
Wonder if it works?
Posted: Wed Jan 09, 2019 12:22 pm
by Brian Beuken
Well, library is a term that refers to a specific subset of pre-coded features, many games require a number of features that require you to either write code, or include a library that has the features you want. So You might need to include a large number of libs to build a game.
On the basis, there are a number of things you might need, maths, physics, graphics, model loading, file handling, etc
Game engines, usually present a shell of a game, where you have access to all these features and can switch them in an out as you need.
There are literlaly dozens of different libraries out there that will give you the above mentioned maths, physics graphics etc....
There are not so many game engines on the Raspberry, its rather a limited system and can't really handle the overhead on memory and speed that most engines need.
There is http://blog.giderosmobile.com/2015/12/g ... ry-pi.html which I've not tried yet, but I'm told is getting close to being a really usable system.
UIltimately though if you want to write games on a Raspberry, its best to do it from the ground up, learn how to use its graphic features (OpenGLES2.0) work with its limits and build up your own framework rather than an engine.
I cover this approach in my book (details www.scratchpadgames.net) but pretty much any basic tutorial on C++ will take you through the steps needed to build code, select and use the correct libraries and build your own so that you can write games with confidence in your own code.
Posted: Wed Jan 09, 2019 10:58 pm
by WillBoxOwO
okay...
I took a peek at the OpenGLES example at /opt/vc.
Theyre great!
Sadly, theyre all coded in C, a language that I dont know.
Is it possible to use the libraries used in /opt/vc in my C++ programs, and perhaps, make a 3D cube spin?
Cheers.
Posted: Thu Jan 10, 2019 12:08 am
by Brian Beuken
sure you can use C libs in C++, its not too hard.
Posted: Thu Jan 10, 2019 2:31 am
by Gavinmc42
I'm learning OpenGL on my Gentoo64 Pi as it is similar to my Linux Mint.
I then intend to port down to OpenGLES starting from these examples
https://github.com/ultibohub/Examples/t ... ideoCoreIV
Been using C for decades which is why I am trying in Free Pascal, I hate debugging C ;)
Rust, GO, Pony, Free Pascal, I prefer any of them over C/C++ :D
We have 4 Arm Cores, so native multicore languages mean no need to mess about with OpenMP in C++.
Someone might be close to making a game on Pi's as opposed to just porting one.
All the pieces are now there to do it.
Making games is probably the Everest of coding, so much needs to be known and learned.
What I want to do is do everything on the Pi, all the artwork, music, graphics, AI game engine etc.
Dug out my first post, June 2017 is when I started thinking and learning about this.
Which is the best library? is a question that assumes there is an answer and that someone is using it.
Castle Game Engine if you know Delphi/Pascal.
Godot looks interesting.
Learn how to do everything or learn just how to use the engine?
Doom, Quake, Unity etc engines, needs to allow for the weird Pi hardware.
General Purpose engines are big because they are to run on all hardware.
A Pi specific engine?
Google, read, learn, code,, rinse, repeat?
I like Sascha's stuff - https://github.com/SaschaWillems?tab=repositories
He has moved on to Vulkan which I think is where we should head or be ready for when Pi4 comes out.
Once we have Vulkan on Pi's then we will see lots of games and tools.
Blender for Artists I did get going on my Gentoo64 Pi, good enough to do simple stuff, lots to learn to make game content.
Posted: Thu Jan 10, 2019 9:42 pm
by jdonald
Yes, and don't forget that gl4es does exactly that without requiring changes to your C++ GL code.
Posted: Fri Jan 11, 2019 4:59 am
by Gavinmc42
WebGL is based on OpenGLES.
Would learning how to make WebGL games be of any use?
Could you set up a Pi as a server for WebGL games?
You could make multiplayer games and play them on your smart phones.
Posted: Sun Jan 27, 2019 7:47 pm
by TeaBoy
You could try Irrlicht and Urho3D
http://irrlicht.sourceforge.net/
https://urho3d.github.io/
Both work well on the Raspberry Pi 3.
Posted: Sun Jan 27, 2019 9:49 pm
by Gavinmc42
I noticed when I installed Minetest on Gentoo64 that it installed and is using irrlicht.
So I can verify that works well on Gentoo64 which is using the OpenGL driver.
But I did not play for long so there may still be bugs?
Posted: Sun Jan 27, 2019 10:14 pm
by TeaBoy
I can confirm both successfully build using Raspberry Pi 3, most of the example
programs work very well, however, some examples do have a few issues
but it's certainly possible to create a decent game using those engines.
