sbaratheon
Compiling for c++11
Wed Nov 14, 2012 11:13 pm
I just updated to gcc 4.7 but I'm struggling to compile with the c++11 flag.
My command was:
g++ test.c -std=c++11 -o test.o
but I get:
-bash: -std=gnu++0x: command not found
Any help would be great.
sbaratheon
Re: Compiling for c++11
Wed Nov 14, 2012 11:26 pm
Urgh. I thought I updated gcc but it's still 4.6.3.
How do I update it?
joan
Wed Nov 14, 2012 11:36 pm
sudo apt-get install g++-4.7
Perhaps you did install 4.7 but the system is defaulting to an earlier version.
Try
g++-4.7 test.c -std=c++11
sbaratheon
Wed Nov 14, 2012 11:48 pm
Hmm. When I use sudo apt-get install it says g++ is at the latest version (4.7) but g++ -- version says the version is 4.6.3.
sbaratheon
Thu Nov 15, 2012 12:04 am
I want to do this BTW:
         int x[4];
	           x = {1,2,3,4};
joan
Thu Nov 15, 2012 8:26 am
sbaratheon wrote:Hmm. When I use sudo apt-get install it says g++ is at the latest version (4.7) but g++ -- version says the version is 4.6.3.
Use the command
g++-4.7
not
g++
joan
Thu Nov 15, 2012 8:29 am
sbaratheon wrote:I want to do this BTW:
         int x[4];
	           x = {1,2,3,4};
I thought in standard C you could do
int x[4]={1, 2, 3, 4};
BlackJack
Thu Nov 15, 2012 8:48 am
@joan: You can, but it is not the same if there is code to be executed between the declaration and assigning an „array constant” to it.
int xs[4];
// Some code goes here…
if (condition) {
    xs = {1, 2, 3, 4};
} else {
    xs = {42, 23, 4711, 0};
while not self.asleep():
    sheep += 1
coyotebush
Wed May 01, 2013 6:19 am
Try the following:
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.6 60 --slave /usr/bin/g++ g++ /usr/bin/g++-4.6
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-4.7 40 --slave /usr/bin/g++ g++ /usr/bin/g++-4.7
sudo update-alternatives --config gcc
funkyguy4000
Sat May 23, 2015 5:17 am
Wow this is an old thread
Still helped me out greatly! Thanks!
Accelerate to 88 miles per hour
Return to “C/C++”
