Seb.26
Raspistill -s signal mode
Sat Sep 29, 2018 3:08 pm
Hi world,
I'm trying to use the raspistill signal mode to trigger frame grab from my c++ program.
Question : how could I know that raspistill have finish to grab the frame after sending USR1 signal to it ??
= the jpeg file is ready to be read from my program and raspistill is ready for next USR1 signal.
Thanks.
Re: Raspistill -s signal mode
Sat Sep 29, 2018 4:00 pm
Why not pull the source code for raspistill and add your new function to it rather than trying to write a wrapper?
git clone https://github.com/raspberrypi/userland
cd userland
./buildme
Source code is here: https://github.com/raspberrypi/userland ... spiStill.c
Note:Having anything remotely humorous in your signature is completely banned on this forum.
Seb.26
Sun Sep 30, 2018 9:33 am
thanks for your answer.
Mainly because I'm too lazy to start deep study of userland code ... :oops:
But, after quick read, looks like raspistill use temp file name for writting and them renaming the file when donde :
[u]RaspiStill.c :: 1660[/u]
MMAL_STATUS_T create_filenames(char** finalName, char** tempName, char * pattern, int frame)
   *finalName = NULL;
   *tempName = NULL;
   if (0 > asprintf(finalName, pattern, frame) ||
       0 > asprintf(tempName, "%s~", *finalName))
      if (*finalName != NULL)
         free(*finalName);
      return MMAL_ENOMEM;    // It may be some other error, but it is not worth getting it right
   return MMAL_SUCCESS;
So when file is here, it must be ready ... :mrgreen:
Seb.26
Tue Oct 16, 2018 12:26 pm
Hello world,
since my last post, I have wrote my program and it works fine, but it's slow to write a file from raspiyuv, then open this file from my program, edit it and write it again ...
It's time to go deeper ... yes DougieLawson : you said it :mrgreen:
I have copy 'userland-master' from GIT onto my PI and launch 'buildme', all looks fine.
Now I want to edit raspistill.c / raspiyuv.c and rebuild them, but how could I compile only modified apps and not all 'userland' project ?
Thanks.
Wed Oct 17, 2018 6:57 pm
I think there's a CMake file in there that generates a Makefile. With that you'll only recompile code that's changed.
Read the buildme script to see what it's doing.
Return to “C/C++”
