ggarg118
Problem while accessing /dev/mem
Mon Aug 20, 2018 1:43 pm
folks... i got a source code for accessing GPIO of rpi through library "mmapGpio". Somewhere in this c++ file, it is trying to open "/dev/mem".
The problem is i can't access it. Please find the snapshot.
I am sure the problem is related to access permission.. What should i do?
can't access _dev_mem.png (145.26 KiB) Viewed 1235 times
n67
Re: Problem while accessing /dev/mem
Mon Aug 20, 2018 2:00 pm
In general, you will need to be running as root in order to access /dev/mem.
0 crw-r----- 1 root kmem 1, 1 Jun 16 21:44 /dev/mem
(Or be in group kmem; pi is not in that group [by default])
So, you have a few choices:
1) Run the program via "sudo" (this will be the most common advice given on this forum)
2) Make the program setuid root - or setgid kmem
3) Make pi be in the kmem group (and reboot to make it take effect)
"L'enfer, c'est les autres"
Epmu Sn!
ggarg118
Mon Aug 20, 2018 2:19 pm
I am pretty new to the linux environment. Could u help more? How to do that?? any link suggesting the same?
PeterO
Mon Aug 20, 2018 4:29 pm
Or use /dev/gpiomem which doesn't need root permissions.
PeterO
n67
Mon Aug 20, 2018 5:43 pm
Probably the simplest (if it works) is to follow the advice of another thread responder and use /dev/gpiomem instead.
But if you want to follow item 3 from the above list, here's how:
0) run "groups" - see that kmem is not in the list.
1) Become root (sudo bash)
2) Edit /etc/group with your favorite editor, say the "vigr" program.
Find this text:
proxy:x:13:
kmem:x:15:
dialout:x:20:pi
fax:x:21:
See how the "dialout" line has "pi" at the end. This makes pi be a member of the dialout group.
If you put "pi" at the end of the "kmem" line, then you will be in the kmem group as well.
3) Save and exit
4) reboot
5) Log in as pi and run "groups" - see that kmem is now in the list.
Epmu Sn!
Return to “C/C++”
