read() is blocked forever on raspberry pi 3 UART
Posted: Tue Aug 14, 2018 8:44 pm
by jefferson_palheta
The C read() function frequently get blocked, especially if there is nothing connected on the Gpio pins (tx / rx), but I just hoped it would stop for itself when there is no conection, the same when there is wire conection but no data to read, but it just get blocked until I force it to finish.
Open
fd = open("/dev/serial0", O_RDWR | O_NDELAY | O_NOCTTY | O_NONBLOCK);
Read
n = read( fd, value, 1 );
if (n < 0) {
printf ( "Error = %s\n", strerror( errno ) );
else if (n == 0) {
  printf ( "Read Nothing...\n");
Set attribs
int setAttr(int fd)
    //Read the configureation of the port
    struct termios options;
    tcgetattr( fd, &options );
    //Set Baud Rate
    cfsetispeed( &options, B9600 );
    cfsetospeed( &options, B9600 );
    //Setting other Port Stuff
    options.c_cflag &= ~PARENB; /*Make 8n1 */
    options.c_cflag &= ~CSTOPB;
    options.c_cflag &= ~CSIZE; /* Mask the character size bits */
    options.c_cflag |= CS8;    /* Select 8 data bits */
    options.c_cflag &= ~CRTSCTS;  /* No flow control */
    options.c_cc[VMIN] = 0; /*READ doesn't block */
    options.c_cc[VTIME] = 1; /* 0.1 seconds read timout */
    options.c_cflag |= CREAD | CLOCAL; /* Turn on READ & ignore crtl lines */
    cfmakeraw(&options);
    //Flush port, then applies attributes
    tcflush(fd, TCIOFLUSH);
    return tcsetattr( fd, TCSANOW, &options );
Re: read() is blocked forever on raspberry pi 3 UART
Posted: Wed Aug 15, 2018 12:24 pm
I just add the code below, after open() and it's not blocked anymore when tx/rx pins are not connected. Probably the port was going blocked after open().
if (fd == -1)
           * Could not open the port.
          perror("open_port: Unable to open /dev/serial0 - ");
else fcntl(fd, F_SETFL, O_NONBLOCK);
Posted: Wed Aug 15, 2018 12:46 pm
by scotty101
Why not try the serial port functions included in the WiringPi library. You may have more luck with that.
http://wiringpi.com/reference/serial-library/
Posted: Thu Aug 16, 2018 6:23 am
by wernermeurer
Hi!
Your code does not check return-values of read() which are positive.
read() returns the number of charaters which are read, negative on errors and zero if no characters are there.
So I would check like:
n=read(....)
if (n<0) /* error */
{ printf("error\n"); }
else if (n==0) /* nothing read */
{ printf ("Nothing there\"); }
else /* normal read */
{ printf ("normal read\"); }
And of course - first check if the filedescriptor was opened without error!
Hope this helps....
Regards
Werner
