isan98
get first number that read from serialGetchar()
Sun Jul 29, 2018 4:51 pm
#include <stdio.h>
#include <string.h>
#include <errno.h>
#include <wiringSerial.h>
int main ()
  int fd,value ;
  if ((fd = serialOpen ("/dev/ttyACM0", 115200)) < 0)
    fprintf (stderr, "Unable to open serial device: %s\n", strerror (errno)) ;
    return 1 ;
// Loop, getting and printing characters
  for (;;)
    value=serialGetchar (fd) ;
    fflush (stdout) ;
  serialClose(fd);
I get the serialGetchar as int
for example the data that recieve is:
81,2018/07/29,18:21:34
34,2018/07/29,18:21:34
102,2018/07/29,18:21:35
how can I cast only the first number (81,34,102,.....,not date and time) in the other int?
int first;
first <----81
first<-----34
first<----102
danjperron
Re: get first number that read from serialGetchar()
Sun Jul 29, 2018 5:49 pm
First create a function to capture on line to a char * array. Check for new line to end.
Then use Maybe sscanf(buffer,"%d,",&intvalue)
Or replace the comma character to NULL and use atoi.
isan98
Fri Aug 03, 2018 10:12 am
can you show me the code?or example
jahboater
Fri Aug 03, 2018 11:32 am
I think the ASCII character NUL ('\0') was meant, not the pointer.
Avoids a nasty warning from the compiler ...
Atoi() will stop when it finds a comma by the way, no need to end the string.
see "man atoi" and "man scanf" for the details.
Return to “C/C++”
