jahboater
GCC 8.2 released
Fri Jul 27, 2018 11:24 am
Bug fix release.
See script here to download, build, and optionally install it:
viewtopic.php?f=33&t=212636&p=1310910#p1310910
The Traveler
Re: GCC 8.2 released
Fri Jul 27, 2018 11:56 am
+1
Thanks for the heads up. :)
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
lianergoist
Sat Jul 28, 2018 8:48 am
Also +1 from me!
Maybe this is a stupid question, but why do we need the extra options to configure? Isn't it supposed to auto-detect that? Sure, things like --enable-languages=c,c++ makes sense, but the rest of it looks like it could/would/should be auto-detected.
I ask because I plan to install gdb. 'Show configuration' in gdb says:
(gdb) show configuration
This GDB was configured as follows:
   configure --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
             --with-auto-load-dir=$debugdir:$datadir/auto-load
             --with-auto-load-safe-path=$debugdir:$datadir/auto-load
             --with-expat
             --with-gdb-datadir=/usr/share/gdb (relocatable)
             --with-jit-reader-dir=/usr/lib/gdb (relocatable)
             --without-libunwind-ia64
             --with-lzma
             --with-python=/usr (relocatable)
             --without-guile
             --with-separate-debug-dir=/usr/lib/debug (relocatable)
             --with-system-gdbinit=/etc/gdb/gdbinit
             --with-babeltrace
("Relocatable" means the directory can be moved with the GDB installation
tree, and GDB will still find it.)
(gdb)
So, should I pass these options to configure? Maybe other things I should include?
BTW - it takes 17+ hours for a rpi zero to compile the kernel... :-)
Thomas Jensen
There are two types of people.
1) Those who can extrapolate from incomplete data
jahboater
Sat Jul 28, 2018 9:08 am
I'm not sure - they were needed some time ago, but maybe now that native works properly ...
It takes hours to build so I have not experimented. Maybe now is the time as it would be nice not to have to edit the script. For GCC, "gcc -v" shows the config.
It takes around 50 hours to compile GCC on a Pi Zero :) which is why I cross compile it on a Pi3B+ (around 4.5 hours).
Just set the config for the Pi Zero, run the script - say no to the install question at the end of course.
Tar up the entire build tree (tar Jcf gcc.tar.xz gcc-8.2.0) then untar it on the Pi Zero, "cd gcc-8.2.0/obj" then "sudo make install".
The tar to xz takes ages though - gzip is probably better.
echmain
Sun Jul 29, 2018 3:04 am
Also +1 from me!
I tried doing the configure with only 2 options, languages (c,c++) and prefix(/usr/local/...) but the compile fails after about an hour (on the 3B+). I don’t remember the error exactly, but clearly some more stuff needs to be spcified.
Using Jahboater’s syntax works perfectly so I’m sticking with that.
AbhiTronix
Tue Sep 04, 2018 5:34 am
I also have created Latest Set of Precompiled Raspberry Pi GCC Cross-Compilers (Easiest Method) here:
https://github.com/abhiTronix/raspberry ... -compilers
5mins Build/Compile time, No more Compiling/Error Handing !!! Good luck :)
jahboater
Tue Sep 04, 2018 6:22 am
Perhaps the examples for wget etc should have 8.2 in rather than 6.3 so people can just cut and paste them?
I assume installing 8.2 native is the most common usage by far. On the Pi, 6.3 comes pre-installed.
AbhiTronix
Tue Sep 04, 2018 4:24 pm
Correct. Thanks for suggesting, I've updated readme. But be sure to check out that 6.3.0 binary is for cross-compiler only (not native) which means it is for Linux x64 machine(As Raspberrypi GCC Cross-Compiler) not for installing in raspberry pi. That's why I've highlighted the Binaries Description in the repo. which points out the use of each binary. Hope this will help. ;)
Return to “C/C++”
