vikrant_ap
GPIO ouput pin giving High & Low output in Raspberry Pi 3
Fri Jul 13, 2018 7:46 am
Greetings!
I have to generate some signals, so I used GPIO pins as Output pins.
Everything was working fine then suddenly most of those pins started giving high and low random values.
I checked on MSO and I got following pattern
SO can anyone tell me what will be the problem exactly and how can I solve it?
Z80 Refugee
Re: GPIO ouput pin giving High & Low output in Raspberry Pi 3
Fri Jul 13, 2018 9:10 am
My guess: your GPIO pins are now inputs, so the lines are floating and giving misleading results when you use logic-level rather than analogue monitoring.
Check your code initialises everything at the start, so that pins you intend to be outputs are specified as outputs. From power-up, they will be inputs.
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
Return to “C/C++”
