srjacob
Mutex format for C++
Sun Jul 08, 2018 7:55 pm
I am a newbe to linux.
I want to synchronize several threads with mutex (or some other semaphore) in C++. All the references I have found show a slightly different format of the syntax. So far, I haven't found a good C++ reference for Raspian. It is somewhat maddening.
Could some kind soul please give me an example of using mutex in a C++ program on Raspian. Either that, or point to a good reference.
Thanks in advance.
Steve
joan
Re: Mutex format for C++
Sun Jul 08, 2018 8:53 pm
Raspbian is one of many Linux/GNU distributions. It doesn't make sense to look for Raspbian documentation for C++ or mutexes. Look for Linux mutexes.
Sun Jul 08, 2018 9:10 pm
Note:Having anything remotely humorous in your signature is completely banned on this forum.
C++ the language has no idea about threads. Not even in its standard library. Or at least the last time I checked that was so.
Raspbian is Linux. The standard threads library in Linux is pthreads (POSIX threads). See here: https://docs.oracle.com/cd/E19120-01/op ... index.html and a billion other places on the web.
If you happen to be using the Qt graphical user interface libraries then that wraps pthreads up nicely in a QThread class: http://doc.qt.io/qt-5/qthread.html
In fact I have written non-graphical applications using the Qt threads library with success.
No wait: C++ does have treads in its standard library: http://www.cplusplus.com/reference/thread/thread/
And mutexes and stuff http://www.cplusplus.com/reference/mutex/
Amazing what google can find now a days. http://www.bogotobogo.com/cplusplus/C11 ... thread.php
jahboater
Sun Jul 08, 2018 9:40 pm
I think the presumption with C++ should be that it has the feature ....
There is also std::async (simple threads), std::memory_order (atomics) and probably lots of other stuff.
srjacob
Mon Jul 09, 2018 1:35 am
Thank you for your responses. I am familiar with the CPP site. I tried some of those examples, and they don't compile on my PI.
I would like to think that C++ on all Linux distributions is the same, but it appears that there are some differences. I have several C++ reference texts, and they all differ somewhat when it comes to mutex.
The C++ implementation of threads is composed of class wrappers for the basic Linux (Posix) threads. The flavor of the wrappers seems to differ somwhat between flavors of Linux.
All I am asking for is this: I would like to see a mutex class definition (constructor) usage, and a usage of a mutex in a program. That's it. That's all I am asking for. The rest I can handle myself.
I am VERY familiar with threading on Windows. I am a newbe to Linux, however. Documentation on Windows is excellent, primarily because MS pays big bucks to develop it, so I guess I am spoiled. No one is going to pay big bucks to document Linux.
Mon Jul 09, 2018 4:42 am
srjacob,
If you were to show your code here, along with your compile command and it's error messages no doubt I or someone here could help you fix it.
C++ is very well standardized and the usual C++ compiler on Linux is GCC which implements that statndard very well. Any platform differences, 32 or 64 bit, bigendian or little endian, etc, should not make any difference for your threading example.
I doubt it. If you are talking about the threads as in the C++ standard library, std::thread, I'm very sure it's the same on all Linux distros. It all comes with the same GCC and it's all from the same ISO standard.
Oh but they do. pthreads is POSIX threads is an IEEE standard. posix threads work on Windows as well as Unix/Linux. The C++ standards thread library is part of an ISO standard. Which in turn is supported by the likes of Microsoft, IBM, etc.
This is an example of using the C++ threads library, including mutexs, which works:
#include <iostream>
#include <thread>
#include <list>
#include <algorithm>
#include <mutex>
using namespace std;
// a global variable
std::list<int>myList;
// a global instance of std::mutex to protect global variable
std::mutex myMutex;
void addToList(int max, int interval)
	// the access to this function is mutually exclusive
	std::lock_guard<std::mutex> guard(myMutex);
	for (int i = 0; i < max; i++) {
		if( (i % interval) == 0) myList.push_back(i);
void printList()
	for (auto itr = myList.begin(), end_itr = myList.end(); itr != end_itr; ++itr ) {
		cout << *itr << ",";
int main()
	int max = 100;
	std::thread t1(addToList, max, 1);
	std::thread t2(addToList, max, 10);
	std::thread t3(printList);
	t1.join();
	t2.join();
	t3.join();
	return 0;
Compile like so:
$ g++ -std=c++11 -o thread-example thread-example.cpp -lpthread
Note the "-std" option that selects use of the C++ 11 standard which is when threads were introduced to C++. And the -lpthread option to pull in the pthreads library.
And run like so:
$ ./thread-example
0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,0,10,20,30,40,50,60,70,80,90,
This code will no doubt build and run on Windows as well so all your C++ on Windows experience can be brought over to Linux and the Pi.
The above example is from here: http://www.bogotobogo.com/cplusplus/C11 ... Memory.php
srjacob
Mon Jul 09, 2018 1:15 pm
OK. Here is my problem:
std::mutex TopButton, BottomButton; // sync mutex for top and bottom button
ERROR: ]/home/pi/DRHE/main.cpp:64:6: error: ?mutex? in namespace ?std? does not name a type
Mon Jul 09, 2018 1:17 pm
I presume you have
#include <mutex>
at the top of the file?
Return to “C/C++”
