botpeddler
OpenCV / Aruco / RaspiCam errors
Mon Jul 02, 2018 6:35 am
I am trying to detect Aruco markers using OpenCV. At first I tried a logitech USB webcam and it worked ok, but the resolution was small and the framerate was slow. I couldn't set the resolution higher even though the camera natively supports it. Anyway, I tried a Raspberry Pi Camera 2 with the RaspiCam C++ library. I'm having two issues:
One is I'm having these errors on compile time:
/usr/bin/ld: /usr/local/lib/libraspicam_cv.so: invalid string offset 4558 >= 4040 for section `.strtab'
/usr/bin/ld: /usr/local/lib/libraspicam_cv.so: invalid string offset 4543 >= 4040 for section `.strtab'
/usr/bin/ld: /usr/local/lib/libraspicam_cv.so: invalid string offset 4531 >= 4040 for section `.strtab'
/usr/bin/ld: /usr/local/lib/libraspicam_cv.so: invalid string offset 4569 >= 4040 for section `.strtab'
/usr/bin/ld: /usr/local/lib/libraspicam_cv.so: invalid string offset 4577 >= 4040 for section `.strtab'
/usr/bin/ld: /usr/local/lib/libraspicam_cv.so: invalid string offset 4524 >= 4040 for section `.strtab'
/usr/bin/ld: /usr/local/lib/libraspicam_cv.so: invalid string offset 4557 >= 4040 for section `.strtab'
It still runs for a bit, but then crashes with this error:
OpenCV Error: Assertion failed ((((objectPoints) != __null && (((const CvMat*)(objectPoints))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(objectPoints))->cols > 0 && ((const CvMat*)(objectPoints))->rows > 0) && ((const CvMat*)(objectPoints))->data.ptr != __null) && (((imagePoints) != __null && (((const CvMat*)(imagePoints))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(imagePoints))->cols > 0 && ((const CvMat*)(imagePoints))->rows > 0) && ((const CvMat*)(imagePoints))->data.ptr != __null) && (((A) != __null && (((const CvMat*)(A))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(A))->cols > 0 && ((const CvMat*)(A))->rows > 0) && ((const CvMat*)(A))->data.ptr != __null) && (((rvec) != __null && (((const CvMat*)(rvec))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(rvec))->cols > 0 && ((const CvMat*)(rvec))->rows > 0) && ((const CvMat*)(rvec))->data.ptr != __null) && (((tvec) != __null && (((const CvMat*)(tvec))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(tvec))->cols > 0 && ((const CvMat*)(tvec))->rows > 0) && ((const CvMat*)(tvec))->data.ptr != __null)) in cvFindExtrinsicCameraParams2, file /home/pi/opencv/modules/calib3d/src/calibration.cpp, line 996
terminate called after throwing an instance of 'cv::Exception'
  what():  /home/pi/opencv/modules/calib3d/src/calibration.cpp:996: error: (-215) (((objectPoints) != __null && (((const CvMat*)(objectPoints))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(objectPoints))->cols > 0 && ((const CvMat*)(objectPoints))->rows > 0) && ((const CvMat*)(objectPoints))->data.ptr != __null) && (((imagePoints) != __null && (((const CvMat*)(imagePoints))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(imagePoints))->cols > 0 && ((const CvMat*)(imagePoints))->rows > 0) && ((const CvMat*)(imagePoints))->data.ptr != __null) && (((A) != __null && (((const CvMat*)(A))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(A))->cols > 0 && ((const CvMat*)(A))->rows > 0) && ((const CvMat*)(A))->data.ptr != __null) && (((rvec) != __null && (((const CvMat*)(rvec))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(rvec))->cols > 0 && ((const CvMat*)(rvec))->rows > 0) && ((const CvMat*)(rvec))->data.ptr != __null) && (((tvec) != __null && (((const CvMat*)(tvec))->type & 0xFFFF0000) == 0x42420000 && ((const CvMat*)(tvec))->cols > 0 && ((const CvMat*)(tvec))->rows > 0) && ((const CvMat*)(tvec))->data.ptr != __null) in function cvFindExtrinsicCameraParams2
I'm on the Raspberry Pi 3 B+, has anyone else worked with the RaspiCam C++ API?
Here is the code I tried to convert from the Aruco sample to using RaspiCam:
int main(int argc, char *argv[]) {
    raspicam::RaspiCam_Cv Camera;
    CommandLineParser parser(argc, argv, keys);
    parser.about(about);
    if(argc < 2) {
        parser.printMessage();
        return 0;
    int i=0;
    foundCounter = 0;
    int dictionaryId = parser.get<int>("d");
    bool showRejected = parser.has("r");
    bool estimatePose = parser.has("c");
    float markerLength = parser.get<float>("l");
    Ptr<aruco::DetectorParameters> detectorParams = aruco::DetectorParameters::create();
    if(parser.has("dp")) {
        bool readOk = readDetectorParameters(parser.get<string>("dp"), detectorParams);
        if(!readOk) {
            cerr << "Invalid detector parameters file" << endl;
            return 0;
    detectorParams->cornerRefinementMethod = aruco::CORNER_REFINE_SUBPIX; // do corner refinement in markers
    int camId = parser.get<int>("ci");
    String video;
    if(parser.has("v")) {
        video = parser.get<String>("v");
    if(!parser.check()) {
        parser.printErrors();
        return 0;
    Ptr<aruco::Dictionary> dictionary =
        aruco::getPredefinedDictionary(aruco::PREDEFINED_DICTIONARY_NAME(dictionaryId));
    Mat camMatrix, distCoeffs;
    if(estimatePose) {
	bool readOk = readCameraParameters(parser.get<string>("c"), camMatrix, distCoeffs);
        if(!readOk) {
            cerr << "Invalid camera file" << endl;
            return 0;
	//Camera.set( CV_CAP_PROP_FORMAT, CV_8UC1 );
	Camera.set( CV_CAP_PROP_FORMAT, CV_8UC3 );
	if (!Camera.open()) {cerr<<"Error opening the camera"<<endl;return -1;}
    VideoCapture inputVideo;
    inputVideo.set(CV_CAP_PROP_FRAME_WIDTH,1920);
    inputVideo.set(CV_CAP_PROP_FRAME_HEIGHT,1080);
    int waitTime;
    if(!video.empty()) {
        inputVideo.open(video);
        waitTime = 0;
    } else {
        inputVideo.open(camId);
        waitTime = 10;
    double totalTime = 0;
    int totalIterations = 0;
    //while(inputVideo.grab()) {
    while(Camera.grab()){
        Mat image, imageCopy;
        Camera.retrieve ( image);
        //inputVideo.retrieve(image);
        double tick = (double)getTickCount();
        vector< int > ids;
        vector< vector< Point2f > > corners, rejected;
        vector< Vec3d > rvecs, tvecs;
        // detect markers and estimate pose
        aruco::detectMarkers(image, dictionary, corners, ids, detectorParams, rejected);
        if(estimatePose && ids.size() > 0)
            aruco::estimatePoseSingleMarkers(corners, markerLength, camMatrix, distCoeffs, rvecs,
                                             tvecs);
        double currentTime = ((double)getTickCount() - tick) / getTickFrequency();
        totalTime += currentTime;
        totalIterations++;
        // draw results
        image.copyTo(imageCopy);
        if(ids.size() > 0) {
            aruco::drawDetectedMarkers(imageCopy, corners, ids);
        double x = tvecs[0][0];
        double y = tvecs[0][1];
        double z = tvecs[0][2];
            if(estimatePose) {
                for(unsigned int i = 0; i < ids.size(); i++)
                    aruco::drawAxis(imageCopy, camMatrix, distCoeffs, rvecs[i], tvecs[i],
                                    markerLength * 0.5f);
        if(showRejected && rejected.size() > 0)
            aruco::drawDetectedMarkers(imageCopy, rejected, noArray(), Scalar(100, 0, 255));
        imshow("out", imageCopy);
        char key = (char)waitKey(waitTime);
        if(key == 27) break;
    return 0;
Nanaki
Re: OpenCV / Aruco / RaspiCam errors
Thu Jul 12, 2018 3:28 pm
Howdy,
I can have a guess. Without knowing the API inside out it looks to me like you are not checking the images that are being returned from the stream. I'd add something like
if(!image.empty())
Just where you think you have an image from your stream as its possible that there might be no image when you check for one.(assuming threads and queues etc)
I wanna tell you to assume nothing while I'm making assumptions. That's where I'd start!
Return to “C/C++”
Who is online
Users browsing this forum: No registered users and 6 guests
