LONGJA
Using Hex value in a Calculation
Tue Jun 12, 2018 10:27 am
Hi there,
I'm trying to build a program that calculates the difference, in seconds, between two times. I want to read the time from an I2C realtime clock and convert the time into a total in seconds. For example, for 11:18:58, I want to be able to do (11x3600) + (18x60) + (58) = 40738. However the reading I get back from the realtime clock are hex values and when I try to convert them to a decimal the values change accordingly, for example 11 changes to 17. This then messes up the calculations. Please see below:
int total
int sum
Readtime();
printf("%02x:%02x:%02x", buf[2], buf[1], buf[0]);
total = (buf[2])*3600;
printf("total = %d", total);
I've seen various bits of code for converting from a hex to a decimal but nothing that will allow me to use the raw hex value. Any suggestions greatly appreciated, thanks.
James
buja
Re: Using Hex value in a Calculation
Tue Jun 12, 2018 11:08 am
If you already have a number as an integer (int), there is no need to convert between decimal and hexadecimal.
The only thing you have to do is decide in which format you want to print the number:
int a = 0x10;
printf("%02x", a); => this prints 10
printf("%02d", a); => this prints 16
The numerical value of a does not change, only the printed output.
hippy
Tue Jun 12, 2018 11:28 am
Correct but values from an RTC are usually BCD encoded bytes rather than hex. For example 0x19 BCD represents 19 decimal.
decimal = bcd - ( ( bcd >> 4 ) * 6 );
hippy
Tue Jun 12, 2018 11:47 am
Untested -
#define BcdToBin(bcd) ( bcd - ( ( bcd >> 4 ) * 6 ) )
Readtime();
total = BcdToBin(buf[2]) * 3600
      + BcdToBin(buf[1]) * 60
      + BcdToBin(buf[0]);
Return to “C/C++”
