LONGJA
Running multiple functions at the same time
Sun Apr 08, 2018 10:49 am
I'm building a data logging system (in C) that sends data from a series of sensors via GSM but also has a 16x2 LCD screen. The data logging program loops every minute and but I would like the LCD program to loop much faster so it can respond quickly to changes. For example, if an extra device was plugged into the load, you would see the information on the screen react immediately, rather than having to wait a minute for the rest of the program to loop. I've read about a number of ways to run several programs at the same time including pipe, fork and pthread. pthread appears to be the one favoured by most but I wanted to check that it was still suitable for an application of this kind.
So my question is, is pthread a suitable way to achieve the outcome mentioned above? If not, perhaps you could suggest an alternative to look into.
Any thoughts greatly appreciated, thanks.
ghans
Re: Running multiple functions at the same time
Sun Apr 08, 2018 11:09 am
You want to write a multithreaded program. So yes, you need to use pthreads.
ghans
PeterO
Sun Apr 08, 2018 11:44 am
While threading is a possibility, it sounds like overkill for your application. If you want the the LCD to respond say every ten seconds, and the GSM once a minute then...
forever
	do six times
		wait 10 seconds
		do LCD code
	do GSM code
PeterO
LONGJA
Mon Apr 09, 2018 8:45 am
PeterO - I assume the 'do' function here will run both simultaneously? Both programs, LCD and GSM query an AtD at some point, will this be a problem if the two try to query the AtD at the same time?
jahboater
Mon Apr 09, 2018 9:07 am
That is pseudo code ...
In a C like syntax ...
for(;;)
   for( int i = 0; i < 6; ++i )
      sleep(10);
      LCD_code();
   GSM_code();
PeterO
Mon Apr 09, 2018 9:13 am
for(;;)
      sleep(10);
      LCD_code();
   GSM_code();
Exactly...
The point is you don't have to actually run things together or in parallel for them to appear to be running together or in parallel.
PeterO
Return to “C/C++”
