LONGJA
Trouble printing integer on I2C LCD in C
Wed Mar 28, 2018 4:21 pm
I'm relatively new to RPi and have used a tutorial on Sunfounder to connect an LCD to a RPi3 via I2C. The program runs fine but I'm struggling to print the output from a sensor (via MCP3008 AtD). I've tried a number of configurations but the program will always print "%d" on the LCD instead of an integer. I imagine it's a simple fix but as I said, new to Pi and C so would appreciate some help.
The tutorial can be found here...
https://www.sunfounder.com/learn/lesson ... -plus.html
Many thanks
James
Paeryn
Re: Trouble printing integer on I2C LCD in C
Wed Mar 28, 2018 6:58 pm
It helps if you give examples of code that doesn't work otherwise we can only guess at what code you used.
From your explanation it sounds like you are passing a formatting string directly to the write() function (bad choice of function name by whoever wrote that example code) but write() will just display the string exactly as is. I don't know how you tried to give the variable to be substituted in that string. You need to use something like snprintf() to fill in a buffer according to a given format string, just like printf() except you have two extra parameters at the start, the first is a pointer to the buffer where the string will be written and the second is the size of the buffer snprintf() will trunctate the string so that it doesn't overrun the buffer, the terminating null char will always be added.
    int number = 4; // variable we are going to print
    char buffer[40]; // buffer to hold string
    snprintf(buffer, 40, "Value = %d", number);
    write(1, 1, buffer);
Wed Mar 28, 2018 7:31 pm
The rest of the code is identical to the sample at https://www.sunfounder.com/learn/lesson ... -plus.html, I've changed the main routine to.
void main(){
        fd = wiringPiI2CSetup(LCDAddr);
        init();
        write(0, 0, "Greetings!");
        write(1, 1, "From SunFounder");
        delay(200);
        clear();
        int i;
        for (i=0; i<1000; i++)
                char strA[40];
                sprintf(strA,"%04d", i);
                write(0,0,strA);
                delay(200);
                clear();
That counts up from 0001 to 1000 on my PCF based LCD.
I'll do your homework for you for a suitable fee.
Paeryn
Wed Mar 28, 2018 8:00 pm
                char strA[40];
                write(0,0,strA);
                delay(200);
                clear();
Surely it would count from 0000 to 0999. :roll:
Wed Mar 28, 2018 11:57 pm
                char strA[40];
                write(0,0,strA);
                delay(200);
                clear();
I only ran it for a minute until I was convinced the leading zeros were working. I can fix the 0 to 999 versus 1 to 1000 later.
LONGJA
Thu Mar 29, 2018 3:46 pm
Many thanks for all your responses. I'll have a go and let you know have it goes.
LONGJA
Thu Mar 29, 2018 9:41 pm
Worked perfectly - many thanks!
Return to “C/C++”
