bazza
GCC 6 Cross Compiler
Fri Mar 09, 2018 8:17 pm
Does anyone know of where there is a prebuilt gcc-6 cross compiler toolchain.
I have found (after a while away) that gcc-4xx no longer generates code that will link against the current libraries in Raspbian Stretch.
LdB
Re: GCC 6 Cross Compiler
Sat Mar 10, 2018 1:10 am
The official arm toolchain has mac, windows & 64 bit linux cross versions
https://developer.arm.com/open-source/g ... /downloads
You didn't say which O/S you wanted the cross from :-)
bazza
Sat Mar 10, 2018 11:17 am
Thanks. I also found crosstools-ng has a RPi3 configuration for gcc-6. Built OK.
qsrc
Wed Oct 03, 2018 10:34 pm
Note that the "official ARM toolchain" pointed to by @LdB is for bare-metal applications (arm-none-eabi).
Linaro provides pre-built cross-compilation toolchain releases for Linux targets (armv8l-linux-gnueabihf) here:
https://www.linaro.org/latest/downloads/
Return to “C/C++”
