emmi
while loop does not stop [solved]
Mon Mar 05, 2018 6:22 am
I put the following loop into my code:
while((tempAbs = -1000) || (tempAbs = 1000))
	tempAbs = measure_temp(0);
The temperature is set to 1000 or -1000 when the temperature is outside the data sheet range of the thermoelement (above 100 or below 0 degrees Celsius respectively). So I those cases I want the temperature to be measured again as in most cases those results will be a measuring mistake.
Now I get absolutely realistic values of around 20 degrees Celsius. However, the loop measures the temperature again and again although the tempAbs is neither 1000 nor -1000.
Can someone spot the mistake? Thanks!
piense
Re: while loop does not stop
Mon Mar 05, 2018 6:34 am
use ==
emmi
Mon Mar 05, 2018 6:37 am
piense wrote:use ==
Right. One of these easy things you don't see anymore when you have looked for too long on your own code. Thanks!
n67
Mon Mar 05, 2018 9:35 am
piense wrote:use ==
The compiler (presumably, gcc) should have caught this for you.
And it would have, had you compiled with the usual warnings flags:
-W -Wall -Werror
"L'enfer, c'est les autres"
Epmu Sn!
jahboater
Re: while loop does not stop [solved]
Mon Mar 05, 2018 9:55 am
A common (but horrid) idiom is:
while((-1000 == tempAbs) || (1000 == tempAbs))
It doesn't read well though, so as n67 points out, turn on the compiler warnings - always.
I use :) :)
WARN = -Wfatal-errors -Wall -Wextra -Wconversion -Wunused -Wundef -Wcast-qual \
       -Wredundant-decls -Wunreachable-code -Wwrite-strings -Warray-bounds \
       -Wstrict-aliasing=3 -Wstrict-overflow=1 -Wstrict-prototypes -Winline \
       -Wshadow -Wswitch -Wmissing-include-dirs -Woverlength-strings -Wpacked \
       -Wdisabled-optimization -Wmissing-prototypes -Wformat=2 -Winit-self \
       -Wmissing-declarations -Wunused-parameter -Wlogical-op -Wuninitialized \
       -Wnested-externs -Wpointer-arith -Wdouble-promotion -Wunused-macros \
       -Wunused-function -Wunsafe-loop-optimizations -Wnull-dereference \
       -Wduplicated-cond -Wshift-overflow=2 -Wnonnull -Wcast-align -Warray-bounds=2
of which -Wall -Wextra -Wconversion are the most useful IHMO.
Return to “C/C++”
