J.Bryan
Plotting "live" or "realtime" graph in C
Fri Mar 02, 2018 1:30 am
Hi all,
I am trying to generate a live graph in C where my y-axis's data is measured realtime/live to debug my robot. Does anyone know how to create a "live" plot? I tried gnuplot as below, however the graph is only showing 1 point. I am open to any other method to generate the live chart too. Currently, my raspberry pi is setup as a wifi server, so it is not possible for me to dump all my x and y axis to the cloud or services online to plot the graph.
My data is always 2 float value for the x and y-axis. Will the while(1) cause any problem since I am not able to know the maximum value of my x-axis's value?
Thank You.
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <sys/time.h>
#define DT 0.005  //5ms
int mymillis();
int timeval_subtract(struct timeval *result, struct timeval *t2, struct timeval *t1);
void plot_graph(FILE* p, float x, float y);
int main() {
	int startInt = mymillis();
	struct  timeval tvBegin, tvEnd, tvDiff;
	gettimeofday(&tvBegin, NULL);
	int i = 1;
	float x = 0.0;
	float y = 0.0;
	FILE *f = fopen("file.dat", "w");
	if (f == NULL)
	    printf("Error opening file!\n");
	    exit(1);
  	FILE *p = popen("gnuplot", "w");
	fprintf(p, "plot - with lines\n");
	while (1)
                //Do somethings over here e.g read sensor and filtering
		y = generateX();//Function to generate y-axis data
		x = (float i) * DT;//x-axis
		plot_graph(p, x, y);
		//Each loop should be at least 5ms.
		while (mymillis() - startInt < (DT * 1000))
			usleep(100);
		i++;
	return 0;
int mymillis()
	struct timeval tv;
	gettimeofday(&tv, NULL);
	return (tv.tv_sec) * 1000 + (tv.tv_usec) / 1000;
	long int diff = (t2->tv_usec + 1000000 * t2->tv_sec) - (t1->tv_usec + 1000000 * t1->tv_sec);
	result->tv_sec = diff / 1000000;
	result->tv_usec = diff % 1000000;
	return (diff<0);
void plot_graph(FILE *p, float x, float y) {
	fprintf(p,"plot '-'\n");
	fprintf(p, "%f %f\n", x, y); // plot `a` points
	fprintf(p,"e\n");    // finally, e
	fflush(p);   // flush the pipe to update the plot
droleary
Contact: Website Skype
Re: Plotting "live" or "realtime" graph in C
Fri Mar 02, 2018 4:15 pm
Not sure how live-live you'd like, but I came across this article a while ago and found it to be a pretty interesting approach: Render Multimedia in Pure C
bazza
Fri Mar 09, 2018 8:20 pm
Try Qwt it supports a range of plot options.
Bazza
Return to “C/C++”
