lemon_aiden
wiringPi in C Language
Sat Feb 24, 2018 2:43 pm
Hi guys,
I recently bought a Raspberry Pi 3 Model B and I'm trying to figure out how to use the GPIO headers with C language. (Not C++!)
I successfully installed the wiringPi library but I very time a use the setup function, the complier says, 'undefined reference, 'wiringPiSetup'
Here's the code:
#include <stdio.h>
#include <wiringPi.h>
int main()
	wiringPitSetup();
	pinMode(18, OUTPUT);
	for(;;)
		digitalWrite(18, HIGH);
		delay(500);
		digitalWrite(18, LOW);
	return 0;
Please help and thanks!
FTrevorGowen
Re: wiringPi in C Language
Sat Feb 24, 2018 2:57 pm
Hi guys,
Here's the code:
#include <stdio.h>
int main()
	wiringPitSetup();
	for(;;)
		delay(500);
	return 0;
In the code posted there's a typo: you have wiringPitSetup(); not wiringPiSetup ie. there's an extra 't' there (if the code posted was copy and pasted re-check the original).
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
lemon_aiden
Sat Feb 24, 2018 11:31 pm
Yeah, thanks for reminding me the typo.
But still, after I fixed the typo, it keep says undefined reference to 'wiringPiSetup'
joan
Sun Feb 25, 2018 3:23 am
Perhaps you are not linking in the wiringPi library? We can't tell, as you are not saying what you are doing.
[email protected]
Wed Feb 28, 2018 12:17 pm
As well as the typo (compile with -Wall -Werror) you need to link in the library. Same way you'd link in the math library with -lm, link in wiringPi with -lwiringPi. wiringPi is not really intended for noobs to C programming though.
Also type: gpio readall to list the pin numbers - wiringPiSetup(); uses wiringPi pin numbers and pin 18 is almost certainly not what you want there. Also read this: https://projects.drogon.net/wiringpi-pin-numbering/
-Gordon
Gordons projects: https://projects.drogon.net/
Return to “C/C++”
