crosscompiling and librt.so.1
Posted: Thu Oct 11, 2012 2:23 pm
by panik
Hello smart people,
I'm succesfully crosscompiling OpenGL ES applications for the Raspberry Pi on my 32-bit Ubuntu machine. Setting it up was easy. I cloned the 'tools' and 'firmware' directories from github, and told cmake where to look for headerfiles, libraries and the hard-fp compiler/linker. Works great.
Now I need to do some timekeeping to spawn particles. That's where things go wrong. Relevant code from the timer-class (timer.cpp):
#include <time.h>
timespec tS;
clock_gettime(CLOCK_REALTIME, &tS);
On the Raspberry Pi, it compiles and works without problems. But when crosscompiling, timer.cpp compiles but doesn't link:
/home/panik/code/raspberrypi/tools/arm-bcm2708/arm-bcm2708hardfp-linux-gnueabi/bin/../lib/gcc/arm-bcm2708hardfp-linux-gnueabi/4.7.1/../../../../arm-bcm2708hardfp-linux-gnueabi/bin/ld: ../../lib/libgametools.a(timer.cpp.o): undefined reference to symbol '[email protected]@GLIBC_2.4'
/home/panik/code/raspberrypi/tools/arm-bcm2708/arm-bcm2708hardfp-linux-gnueabi/bin/../lib/gcc/arm-bcm2708hardfp-linux-gnueabi/4.7.1/../../../../arm-bcm2708hardfp-linux-gnueabi/bin/ld: note: '[email protected]@GLIBC_2.4' is defined in DSO /home/panik/code/raspberrypi/tools/arm-bcm2708/arm-bcm2708hardfp-linux-gnueabi/bin/../arm-bcm2708hardfp-linux-gnueabi/sysroot/lib/librt.so.1 so try adding it to the linker command line
/home/panik/code/raspberrypi/tools/arm-bcm2708/arm-bcm2708hardfp-linux-gnueabi/bin/../arm-bcm2708hardfp-linux-gnueabi/sysroot/lib/librt.so.1: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [demo/particle/particle] Error 1
make[1]: *** [demo/particle/CMakeFiles/particle.dir/all] Error 2
make: *** [all] Error 2
The errormessage is pretty clear, so I tried adding the path to librt.so.1 in cmake with 'link_directories("all/paths/to/librt.so.1/that/could/possibly/be/correct")', but no cigar.
The file librt.so.1 is actually a symbolic link to librt-2.13.so. Could that have something to do with it? It's hard to google, because the word 'link' in combination with 'ld' has different meanings, but is always relevant. My google-fu fails spectacularly on this one. Any ideas?
Re: crosscompiling and librt.so.1
Posted: Thu Oct 11, 2012 2:42 pm
by panik
Derp! Nevermind.
When compiling on the Raspberry Pi it somehow didn't need the '-lrt' flag. When crosscompiling, it does.
I don't know why it works on the Pi without it, but it works in all cases now. Sorry for wasting your time.
Posted: Thu Oct 11, 2012 2:45 pm
by jackokring
Someone had a similar thing https://github.com/Bumblebee-Project/Bu ... /issues/76 not sure how relevant it is, but the google search was
librt.so linking symbols
Posted: Thu Oct 11, 2012 3:01 pm
by panik
Thanks! Your post crossed with my second post. I really appreciate your time to reply, but it's fixed now. I misinterpreted the (otherwise very clear) error message.
It just needed the '-lrt' flag. Thanks again!
Edit: And yes, it was the same fix. I better start working on that google-fu.
Posted: Fri Mar 20, 2015 10:12 am
by vassiskansa
sorry for my bad english... how can i set this flag into my building command?
I need to build ZoneMinder 1.28.x ... and this is my problem...
[email protected]:/usr/local/src/ZoneMinder-1.28.1# make install
Making install in src
make[1]: ingresso nella directory "/usr/local/src/ZoneMinder-1.28.1/src"
g++ -D__STDC_CONSTANT_MACROS -g -O2  -L/usr/bin/lib -L/usr/lib/  -L/usr/lib/mysql -L/usr/lib/mariadb  -o zmc zmc.o zm_box.o zm_buffer.o zm_camera.o zm_comms.o zm_config.o zm_coord.o zm_curl_camera.o zm.o zm_db.o zm_logger.o zm_event.o zm_exception.o zm_file_camera.o zm_ffmpeg_camera.o zm_image.o zm_jpeg.o zm_libvlc_camera.o zm_local_camera.o zm_monitor.o zm_ffmpeg.o zm_mpeg.o zm_poly.o zm_regexp.o zm_remote_camera.o zm_remote_camera_http.o zm_remote_camera_rtsp.o zm_rtp.o zm_rtp_ctrl.o zm_rtp_data.o zm_rtp_source.o zm_rtsp.o zm_rtsp_auth.o zm_sdp.o zm_signal.o zm_stream.o zm_thread.o zm_time.o zm_timer.o zm_user.o zm_utils.o zm_zone.o  -lz -lavformat -lavcodec -lavutil -lz -lpcre -lgnutls-openssl -lgnutls -lgcrypt -ldl -lpthread -ljpeg -lmysqlclient
/usr/bin/ld: zm_mpeg.o: undefined reference to symbol '[email protected]@GLIBC_2.4'
//lib/arm-linux-gnueabihf/librt.so.1: error adding symbols: DSO missing from command line
collect2: ld returned 1 exit status
Makefile:481: set di istruzioni per l'obiettivo "zmc" non riuscito
make[1]: *** [zmc] Errore 1
make[1]: uscita dalla directory "/usr/local/src/ZoneMinder-1.28.1/src"
Makefile:445: set di istruzioni per l'obiettivo "install-recursive" non riuscito
make: *** [install-recursive] Errore 1
Thank you.
Posted: Fri Mar 20, 2015 3:37 pm
by panik
Wow, that 'bug in upstream ld' must still be there after 3 years. I'm not a cmake wizard and don't know how to do it 'properly', so I would just 'hack it' in there.
Searching for 'target_link_libraries(...)', found a couple in 'ZoneMinder/src/CMakeLists.txt' (with zmc on line 20). I'm probably showing my ignorance here, but I would try adding it to that line.
target_link_libraries(zmc zm ${ZM_EXTRA_LIBS} ${ZM_BIN_LIBS} rt)
Since that's the one that generated the error and the compiling stopped, you may need to add it to the other lines as well (if it works for zmc in the first place).
Posted: Sun Apr 12, 2015 6:36 am
by scar75
Hi all,
I am not much into cross compiling unfortunately. I am experiencing the same problems and it is not clear from your posts how to solve the problem. Where exactly shall I add the CFLAG? I am trying to compile a ROS package. I understand these flag should be added to the MakeFile file is it? Please help me out.
Thank you
Posted: Sun Apr 12, 2015 4:11 pm
by panik
In a Makefile, see if you can find an existing "LDFLAGS" entry (or "LDLIBS" maybe) and add '-lrt' to that.
Adding it to "CFLAGS" would only add it to the options for the compiler (gcc), not the linker (ld). In my case, it compiled correctly and only the linker was complaining.
Posted: Sun Apr 12, 2015 7:11 pm
by scar75
Thank you for your prompt reply.
I am trying hard and yet I don't caome across the problem.
Given my error message:
/usr/bin/ld: CMakeFiles/rplidarNode.dir/sdk/src/arch/linux/timer.cpp.o: undefined reference to symbol '[email protected]@GLIBC_2.4'
CMakeFiles/rplidarNode.dir/build.make:204: recipe for target 'devel/lib/rplidar_ros/rplidarNode' failed
make[2]: *** [devel/lib/rplidar_ros/rplidarNode] Error 1
CMakeFiles/Makefile2:403: recipe for target 'CMakeFiles/rplidarNode.dir/all' failed
make[1]: *** [CMakeFiles/rplidarNode.dir/all] Error 2
Makefile:123: recipe for target 'all' failed
****  Installation failed. Aborting package creation.
I added:
LDFLAGS=-lrt
CFLAGS=-lrt
basically everywhere:
in MakeFile:
# CMAKE generated file: DO NOT EDIT!
# Generated by "Unix Makefiles" Generator, CMake Version 2.8
LDFLAGS=-lrt
CFLAGS=-lrt
# Target rules for targets named rplidarNode
# Build rule for target.
LDFLAGS=-lrt
CFLAGS=-lrt
In MakeFile2:
LDFLAGS=-lrt
CFLAGS=-lrt
In build.make:
LDFLAGS=-lrt
CFLAGS=-lrt
I am completely lost.
Thanks again for your help
Posted: Sun Apr 12, 2015 7:40 pm
by panik
Are you trying to compile this? https://github.com/robopeak/rplidar_ros That's also a cmake project, so adding LDFLAGS in a Makefile will not work here.
In the root CMakeLists.txt (on line 26) it says:
target_link_libraries(rplidarNode ${catkin_LIBRARIES})
Does it work if you make that:
target_link_libraries(rplidarNode ${catkin_LIBRARIES} rt)
Or if it doesn't:
target_link_libraries(rplidarNode ${catkin_LIBRARIES} -lrt)
The Makefiles you're editing are generated by cmake (and the CMakeLists.txt file), so you'll have to run 'cmake .' again.
Even better would be to create a separate build directory (inside the directory where the root CMakeLists.txt file is):
mkdir build
cd build
cmake ..
make
Then -to regenerate the Makefiles- you'll only have to delete the build directory or its contents. It'll keep your source directory clean from auto-generated files.
Posted: Mon Apr 13, 2015 8:11 am
by scar75
Panik,
thank you soooo much, you really got me out of panic! :)
It worked with both 'rt' and '-lrt' options.
I just used the default catkin build folder and add build and install prefix to cmake in order to comply with the workspace folder structure but for the rest worked like a charm.
I sincerily appreciated your help.
Warm regards,
Marcello
Posted: Mon Apr 13, 2015 5:29 pm
by panik
Good to know it worked out for you. Thanks for reporting back with the results!
