andrum99
Problem with Geany - 'execute' command displays blank terminal window
Fri Oct 27, 2017 10:04 pm
I'm trying to use Geany on the Pi to learn C++. When I use the 'execute' command, the terminal window that opens is blank. I've not changed the default execute command - it is still set to "./%e". I have tried this on 2 different Pi's with the same result. Is this is a known problem? How can I fix it?
Paeryn
Re: Problem with Geany - 'execute' command displays blank terminal window
Sat Oct 28, 2017 12:36 am
It depends, has your program written anything to stdout or stderr (std::cout or std::cerr)? If it has, did it have a newline ('\n', std::endl) at the end (not usually needed for stderr, but usually is for stdout)? Is your program sat waiting for input or looping doing nothing?
If you wrote something to stdout but never wrote a newline or flushed it then it would still be in a buffer waiting to be displayed, if your program never exits or is waiting for input you won't see the final message the geany prints to let you know the program finished. When your program exits the following should appear in the terminal window that was opened (the exit code could be different if you return non-zero from main or call exit with a non-zero value).
(program exited with code: 0)
Press return to continue
She who travels light — forgot something.
buja
Sat Oct 28, 2017 6:38 am
I think you will find the solution here: viewtopic.php?f=66&t=191818#p1203549
1dot0
Sat Oct 28, 2017 10:31 am
buja, the link you posted is about Python.
@andrum99:
try what Paeryn implied, perhaps something simple like
printf("here I am");
int c=getchar();
or perhaps
fprintf(stderr, "here I am");
BTW, which are your settings to compile and build?
buja
Sat Oct 28, 2017 10:37 am
No, it's not. While the original poster had this problem with Python, I had the same problem with C after upgrading to Raspbian Stretch. The solution worked.
1dot0
Sat Oct 28, 2017 10:41 am
ok, I see...
your suggested solution was not clearly visible as you just posted a link with mutiple posts, not just the solution.
Nonetheless, as I once tried the standard installation of Stretch with a simple C program and Geany, it worked for me remarkably ( I dropped stretch meanwhile because openVG did not install).
andrum99
Sat Oct 28, 2017 12:25 pm
That fixed it - many thanks!
dmcallister
Fri May 03, 2019 8:29 pm
Hi
I came across this posts (and replies) because I had the same problem trying to execute C++ programs from Geany on my Pi.
I even followed the instructions in suggested solution in another post: viewtopic.php?f=66&t=191818#p1203549 but that didn't fix. Sometimes clicking the Execute button or following the menu command worked, but on the majority of occasions it didn't.
I tried to find out why it worked on occasions - but the behaviour seemed completely random!
After further internet research I found solution to run the programs from within terminal https://raspberry-projects.com/pi/progr ... g-your-exe
A little annoying, but it works every time,
dmcallister
Tue May 07, 2019 10:42 pm
Clarifying my post from few days ago:
Open a terminal window, and navigate to the folder which holds you C++ programs and associated exes are stored
type ./programname (the "./" indicates in this folder)
If you are not in the relevant directory type (full path)/programname
g_kantak
Mon Feb 03, 2020 12:41 pm
hiii m also getting blank screen when executing python program but my program doesnot consist std::cout or std::cerr .
Return to “C/C++”
