bigtrumpet
pigpio nanosecond pulse generation
Fri Aug 25, 2017 8:36 pm
http://abyz.co.uk/rpi/pigpio/code/nanopulse_c.zip
I was able to run on a RPI3, the python code wave_PWM.py, and get square waves on GPIO23 ( pin 16)
however, i cannot get any output from same pin , if I run the nanopulse.c program...
Did I miss anything?
joan
Re: pigpio nanosecond pulse generation
Fri Aug 25, 2017 8:47 pm
I seem to remember the code was a sort of one-shot. Do you have a good oscilloscope attached to the GPIO? Can the 'scope see very short pulses?
bigtrumpet
Sat Aug 26, 2017 3:26 pm
Hello Joan,
I believe mine is good enough. I was checking on GPIO18 ( pin 12).
sudo ./nanopulse 1000 10000 2000
which reports:
10000 pulses of 1000 nanos with gap of 2000 nanos (div=4 bits=125)
joan
Sat Aug 26, 2017 5:44 pm
That code was written before such as the Pi3 which uses a different memory addressing scheme for the GPIO. If you are using it on a recent Pi model you will have to update the code to reflect the new GPIO peripheral address.
bigtrumpet
Sat Aug 26, 2017 9:11 pm
I changed
#define GPIO_BASE 0x20200000
to
#define GPIO_BASE 0x3F000000
besides this define, is there any other thing I need to bear in mind?
thanks
Joseph
joan
Sat Aug 26, 2017 10:05 pm
I think that's the base address of all the peripherals. The GPIO address will be offset from there.
Have a look at http://abyz.co.uk/rpi/pigpio/examples.h ... _tiny_gpio which I did update to work on all Pi models.
bigtrumpet
Mon Aug 28, 2017 12:03 am
Thanks Joan
I will take use this new example.
I just took a quick look at both, a lot of updates has been done. That's really big step forward from the previous one.
:D
zmalsberg
Sun May 12, 2019 6:16 am
Sorry for necroposting, but after trying both of the listed solutions on my 3B+ (changing base address value, swapping header definitions with joan's linked updated file) I simply cannot get 'nanopulse.c' to work on any GPIO. Been having a tough time with pigpio in general trying create a sub-pulse waveform with 'wvcha'; the first time I called this command on GPIO4, it seemed to permanently insert a ceaseless wave pattern onto the pin. No amount of clearing, stopping, killing pigpiod, restarting or unplugging seems to make stop it. "pigs s 4 0" makes it halt briefly, but then the pattern resumes on my oscilloscope within seconds. I remember reading Raspbian Lite has issues... Is an OS wipe in order, or are there any solutions for such things?
Regards,
-Zach M.
joan
Mon May 13, 2019 5:22 pm
Regards,
-Zach M.
Have you code with compile and run instructions?
As to GPIO 4 it sounds like you have a 1-wire bus running (which defaults to GPIO 4).
zmalsberg
Mon May 13, 2019 8:16 pm
So it was 1-wire making the mystery waveform!... I hadn't checked GPIO4 with my oscilloscope until after attempting to generating a similarly shaped waveform with wavechain command, so I confused myself big time by turning on that option a while back without understanding what it did. :oops: Thanks for pointing that out.
As for nanopulse.c, I found a solution here http://www.pieter-jan.com/node/15
#define BCM2708_PERI_BASE       0x20000000
#define GPIO_BASE               (BCM2708_PERI_BASE + 0x200000)
Swapped the 'BCM2708_PERI_BASE' value with the new one for RPi 2-3 and voilà, it works. Doesn't work without the '0x200000' offset.
Return to “C/C++”
