jlongstreet
Profiling on the Pi?
Wed Oct 03, 2012 8:40 pm
What if any profiling tools have people had success with?
I'd like to do some performance optimizations for emulators running on the Pi. I've never done CPU profiling in Linux before, but I'm intermediate-level experienced with Linux. I'm perfectly comfortable recompiling or making intrusive source changes if necessary, but I'd like as simple of a workflow as possible.
Sampling-based profiling tools are fine, as well as instrumentation-based tools. Doing a quick search on the forums it seems that some people have done profiling on various applications, but there's no mention of the tools they used (other than valgrind not working).
Narishma
Re: Profiling on the Pi?
Thu Oct 04, 2012 7:51 pm
Have you tried OProfile?
jlongstreet
Tue Oct 09, 2012 4:04 pm
I got oprofile building yesterday, but when I try to run operf:
[email protected]:~/oprofile-0.9.8/pe_profiling$ operf
Unexpected error running operf: No such device
Please use the opcontrol command instead of operf.
main() calls _check_perf_events_cap(), which does a __NR_perf_event_open syscall. It returns ENODEV, which apparently was not expected by oprofile. I'm guessing this means that the kernel doesn't provide support for perf_events, although /proc/sys/kernel/perf_event_paranoid exists.
Any idea how I can add support for this? I'm not opposed to recompiling my kernel.
jamieiles
Tue Oct 09, 2012 4:57 pm
jlongstreet wrote:I got oprofile building yesterday, but when I try to run operf:
The ARM PMU should have an IRQ that needs to be wired up to an "arm-pmu" platform device, see arch/arm/mach-bcmring/arch.c as an example. I can't see the PMU IRQ in the arm peripherals datasheet though so it's either not wired up to the controllers or just not documented...
Jamie
dom
Wed Oct 10, 2012 9:31 am
jamieiles wrote:The ARM PMU should have an IRQ that needs to be wired up to an "arm-pmu" platform device, see arch/arm/mach-bcmring/arch.c as an example. I can't see the PMU IRQ in the arm peripherals datasheet though so it's either not wired up to the controllers or just not documented...
Unfortunately the interrupt is not available.
I believe the wraparound time for the PMU resisters is quite high, so it may be possibly to get the same effect from a timer.
robquant
Wed Oct 10, 2012 1:58 pm
What about the gpertools: http://code.google.com/p/gperftools/
They contain a sampling profiler that seems to work nicely on the Pi.
jlongstreet
Wed Oct 10, 2012 4:22 pm
Yeah, it looks like OProfile is too much trouble for the moment. I'm building gperftools now.
I needed to add "-march=armv7-a" to CFLAGS and CXXFLAGS to get it compiling, because Debian armhf apparently targets ARMv4 out of the box. I'm going to post a bug on the google code page about that.
Assuming gperftools works, it looks like it'll do what I want. I'll post back here with updates.
jlongstreet
Wed Oct 10, 2012 5:06 pm
Hmm, it seems that the memory barriers are still not supported, even after compiling for -march=armv7-a:
[email protected]:~/profiletest$ LD_LIBRARY_PATH=/usr/local/lib gdb ./test
GNU gdb (GDB) 7.4.1-debian
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "arm-linux-gnueabihf".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /home/pi/profiletest/test...(no debugging symbols found)...done.
(gdb) run
Starting program: /home/pi/profiletest/test
Program received signal SIGILL, Illegal instruction.
Acquire_CompareAndSwap (new_value=1, ptr=0x11024, old_value=0)
    at ./src/base/atomicops-internals-arm-v6plus.h:138
138       MemoryBarrier();
(gdb)
dom
Wed Oct 10, 2012 5:12 pm
jlongstreet wrote:Hmm, it seems that the memory barriers are still not supported, even after compiling for -march=armv7-a:
Why are you building for armv7-a? We're an armv6.
cleverca22
Thu Oct 11, 2012 12:54 am
ive gotten oprofile to work before, i think i had to compile the kernel module for it to work
but sadly, all the performance monitoring stuff didnt work, the irq never triggered
i had to force a module option to make it use the timer tick irq
robquant
Thu Oct 11, 2012 11:30 am
I use gperftools from the Arch repos and this works nicely:
[mypi] ~ %CPUPROFILE=ls.prof LD_PRELOAD=/usr/lib/libprofiler.so /bin/ls -R >| /dev/null
[mypi] ~ %pprof --text /bin/ls ls.prof | head
Using local file /bin/ls.
Using local file ls.prof.
Total: 324 samples
      81  25.0%  25.0%       81  25.0% __getdents64
      66  20.4%  45.4%       66  20.4% __openat_nocancel
      55  17.0%  62.3%       55  17.0% strcoll_l
       8   2.5%  64.8%        8   2.5% _int_malloc
       7   2.2%  67.0%        7   2.2% __fxstat64
       5   1.5%  68.5%        5   1.5% _int_free
       5   1.5%  70.1%        5   1.5% closedir
       5   1.5%  71.6%        5   1.5% [email protected]@GLIBC_2.4
       4   1.2%  72.8%        4   1.2% __aeabi_read_tp
dozencrows
Sun Oct 28, 2012 3:25 pm
It seems there have been problems building tcmalloc (used in gperftools) for ARM in the past - e.g. http://code.google.com/p/chromium-os/is ... l?id=34620. So it may not be in complete working order for all ARM CPUs.
There is an implementation with gperftools but it doesn't seem to be working for all flavours of ARM (hence the 'dmb' instruction compilation error).
After some inspection of the code, I was able to make a small kludge that got tcmalloc to build for ARMV5, which enabled me to successfully profile a small executable on my Pi running Raspbian. BTW This isn't a recommended kludge for public consumption, really just a proof-of-concept to help track down the issue.
Building for ARMV7 stops the compiler complaining, but then generates instructions that the Pi CPU doesn't understand, as it is the wrong version.
The right thing to do would be post a bug against tcmalloc to get a proper fix. A possible workaround in the meantime would be to try getting a proper ARMV5 build of gperftools going.
hermanhermitage
Sun Oct 28, 2012 10:53 pm
I'm using linux-tools-3.2 on raspbian.
install with:
sudo apt-get linux-tools
Record profile:
perf record -g "path-to-executable"
report profile:
perf report -g
Better than a poke in the eye with a sharp stick -- but not much. I'm going to have to add my own instrumentation I think to suit my needs.
paffinity
Mon Nov 05, 2012 5:12 pm
Thanks for the information on using perf record.
I'd also like to use perf stat to query the hardware counters but I keep getting the error:
Error: open_counter returned with 19 (No such device). /bin/dmesg may provide additional information.
Fatal: Not all events could be opened.
Does anyone know how to fix this?
I'm guessing that I'll need to recompile a kernel with support for this enabled.
If there's another way to get around this, please let me know.
MAA1612
Mon Jan 21, 2013 9:59 am
robquant wrote:I use gperftools from the Arch repos and this works nicely:
However, the current tarball did not compile on raspbian, because it used armv7 instructions even when compiling for armv6. Fortunately, a patch has been committed recently which solves this issue:
http://code.google.com/p/gperftools/iss ... ail?id=493
Still compiling, but it seems to work now ...
Return to “C/C++”
