richardcgiroux
Controlling OMXPlayer via dbus from c or c++
Wed May 03, 2017 9:31 pm
I am trying to control OMXPlayer from my c/c++ program in order to speed up communication with the player. The batch file isn't fast enough for what I need.
Has anyone used c or c++ to send dbus commands to OMXPlayer?
topguy
Re: Controlling OMXPlayer via dbus from c or c++
Wed May 03, 2017 10:01 pm
How fast do you need to be ?
And you have used dbus from bash ?
richardcgiroux
Wed May 03, 2017 10:16 pm
I have used the control.sh batch file and sent commands directly from a shell terminal.
Pause command:
dbus-send --print-reply=literal --session --dest=org.mpris.MediaPlayer2.omxplayer /org/mpris/MediaPlayer2 org.mpris.MediaPlayer2.Player.Action int32:35 >/dev/null
What I need to do use a slider bar to scroll through the video. The dbus-send command is a little sluggish in instances like this.
If I could get it to respond quickly enough, I might even be able to present a preview window like in the YouTube player app on Android.
gkreidl
Thu May 04, 2017 5:32 am
This won't work because omxplayer won't follow it: it will show the new time (position), but not start the video in each new position.
Simple test: run a video and keep the right arrow key pressed.
Minimal Kiosk Browser (kweb)
topguy
Thu May 04, 2017 8:52 am
If you are considering going down the C/C++ path you might as well try to rewrite omxplayer itself and bypass dbus completely.
richardcgiroux
Thu May 04, 2017 8:29 pm
I guess I was asking of anyone has sent dbus commands to OMXPlayer from code.
I don't think I need to rewrite OMXPlayer (that would take a while) since it has everything I need. I can call control.sh from my main code to control OMXPLayer and the setposition command does work. It is just a little sluggish.
I just need to learn dbus is guess.
Any examples of using dbus would be helpful.
paulslocum
Sat May 13, 2017 8:38 pm
It's likely that the lag you're experiencing is from Omxplayer seeking and rebuffering rather than from dbus itself. You might be able to improve performance by reducing the buffer sizes. The Omxplayer main loop also has some sleep commands that may be slowing down dbus response time, or causing commands to pile up if you're sending them at a high rate.
Return to “C/C++”
