midnx
Sending a terminal command through C
Thu Mar 16, 2017 11:48 pm
I want to hook up a buttons to the GPIO pins on the Pi, and then when it is pressed, it will send a simple command that I can see on the terminal.
So If I press the button, it will send this to terminal:
echo hello world
I need to do this in C/C++
I am not sure how to do it, so far I have done the tutorial on wiringpi GPIO which makes a led blink, but this is a little different and I don't know how to proceed. Can anyone help me? Eventually I plan to hook up many buttons and run more complex commands but I want to get the basics down to get me going.
stderr
Re: Sending a terminal command through C
Fri Mar 17, 2017 1:59 am
midnx wrote:So If I press the button, it will send this to terminal:
echo hello world
printf should be able to output any text to the terminal you need.
ElEscalador
Fri Mar 17, 2017 2:24 am
printf or cout will work. cout is much easier, but printf can do much more later on. I learned cout first and thus, never made myself really learn printf...which slows me down sometimes. Still..if you're in a hurry:
cout << "Hello world" << endl;  // "endl" starts a new line
Above is the basics. Below is how your code might look:
int button=0;
button=yourgpioreadfunction(yourGPIOpin);
if(button == 1){
return 0;
This does nothing if the variable named button does not equal one when it gets to the if statement.
Robotics tips, hacks, book extras https://youtube.com/practicalrobotics
midnx
Fri Mar 17, 2017 4:12 am
Thanks, but I need it to do the actual command, not just print the raw text.
To put it another way. For example, in linux the "date" commands prints out the date.
But in C++ if you do
cout << "date" << endl
It will just print the word date. I need it to send the COMMAND called date to the terminal, which the terminal will then interpret and show as month/day/hours/etc.
buja
Fri Mar 17, 2017 5:40 am
Use the system() function:
system("date");
The string can be any command you would give on the command line.
woodystanford
Fri Mar 17, 2017 5:55 am
This code will do it:
      if ((ppid=fork())==0)
         printf("Child process\n");
         execlp("bash","bash","./your_shell_script.sh","",NULL);
         return; //terminates child process
      //does this block? YES!
//      printf("Parent process %d\n",ppid);
      wait(&status);
If you need to fully specify the contents of your shell script, you can write it explicitly and I think you might be able chmod it the same way. If not this will run a static shell script.
Here is supporting code for it:
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#include <math.h>
#include <sys/types.h>
#include <sys/wait.h>
#include <dirent.h>
        int ppid;
        int status;
        FILE *fptr;
        char c;
Fri Mar 17, 2017 9:38 am
woodystanford wrote:This code will do it:
      wait(&status);
#include <stdio.h>
#include <unistd.h>
#include <string.h>
#include <math.h>
#include <dirent.h>
        int ppid;
        int status;
        FILE *fptr;
        char c;
Or you could just use the system call as mentioned above? Saves all that boiler plate code.
midnx
Sun Mar 19, 2017 9:26 am
Thanks, this helped alot. I got the hang of it now.
midnx
Sat Mar 25, 2017 7:12 pm
I have another question if you don't mind.
How can I store the output of a system command into a C string?
Say I do:
 system("date");
And let's say that prints out
JAN 01 00:00:00 2017
Now I want to store "JAN 01 00:00:00 2017" into a string variable in the C code.
char date[] = "JAN 01 00:00:00 2017";
Except I want it to get the date from the output of the 1st system command, instead of typing it in.
Sat Mar 25, 2017 7:19 pm
If you're just trying to read the system date/time use
#include <time.h>
#include <stdio.h>
#include <string.h>
int main(int argc, char *argv[])
  time_t rawtime;
  struct tm * timeinfo;
  char time_of_day[21];
  time (&rawtime);
  timeinfo = localtime (&rawtime);
  strftime (time_of_day,21,"%T %b %d %Y",timeinfo);
  printf("%s\n", time_of_day);
  return 0;
You can change the format string to get it the way you want it.
jahboater
Sat Mar 25, 2017 7:23 pm
Look up popen( "date", "r" ) (man popen) which will return a FILE pointer which can be read. This is the output from your program, in this case date. Remember the pclose() at the end.
Edit: crossed with Dougie's post. If "date was just an example, use popen, if you really do want the date, use the proper code in the his post.
midnx
Sat Mar 25, 2017 7:38 pm
DougieLawson wrote:If you're just trying to read the system date/time use
#include <time.h>
[/quote]
I'm not, I just used date as an example.  I want to be able to take the output of any system/bash command and store it into a C string.
jahboater
Sat Mar 25, 2017 7:41 pm
midnx wrote: I'm not, I just used date as an example. I want to be able to take the output of any system/bash command and store it into a C string.
Then popen() is your friend!
Look carefully at the commands because lots of things have official Linux APIs to get the value from the system.
Also if you're just trying to run a sequence of commands and test results then a plain old bash script is better than a C program every time.
ab1jx
Sun Mar 26, 2017 3:29 am
This sounds dangerously like a homework assignment.
You could redirect the output of the command like:
command >& afile.txt
then in another terminal window watch afile.txt like
tail -f afile.txt
The tail should work even if command is being run from a program. See man (1) tail
afile.txt will contain a permanent record of output from command, you watch it growing with tail. I use this on problematic builds to catch all the error messages.
Return to “C/C++”
