holyhope
Can via C/C++ on Rasp Pi3
Thu Feb 09, 2017 3:25 pm
Hi to all,
I'm new to Raspberry Pi3, and I need to implement a CAN protocol developing with NetBeans 8.2
I know CAN protocol and I have already use it in several embedded uP (Pic16, Pic32,etc..)
I know a little of linux but I'm not an expert
I buy this board:
http://skpang.co.uk/catalog/pican2-canb ... -1475.html
And i configure CAN over SPI in this way:
http://skpang.co.uk/blog/archives/1165
I try to sniff several can packet (of other device) with wireshark, how write in this link:
http://skpang.co.uk/blog/archives/1141
and I sniff it very well!
So I try do download an example program and i found this:
http://skpang.co.uk/blog/archives/1199
it works and compile!
Now I'm creating a new "hello word" c program in CAN, starting from the example program downloaded before (that:
http://skpang.co.uk/blog/archives/1199 ) but I found several problems...
I add to my project only lib.h for compilem after that I Import all .h file for have the reference of the function inside my code. (I'm developing on NetBeans 8.2)
In the example code, references that are missing are this: setsockopt, ioctl, socket used in this way:
if (ioctl(s, SIOCGIFINDEX, &ifr) < 0)
socket(PF_CAN, SOCK_RAW, CAN_RAW))
setsockopt(s, SOL_CAN_RAW, CAN_RAW_FILTER, NULL, 0);
[Question-1] So the first question is where I can find them?!
So I can study this function and learn how to use it...
[Question-2] How to read a can message? In the example is not explaned (and no example provided for reading) how to read a can packet.... I have no idea how to do it with this library... I suppose I must set up an interrupt (or something similar...) where a new packet is aviable and a call to function (but I have no idea what function) for read packet.
Can someone help me?
Many thanks!!!!
Max
PeterO
Re: Can via C/C++ on Rasp Pi3
Thu Feb 09, 2017 3:36 pm
Use the "man" command to look up the manual pages for these library functions. The pages tell you which header files need including to use the functions.
IOCTL(2)                   Linux Programmer's Manual                  IOCTL(2)
NAME
       ioctl - control device
SYNOPSIS
       #include <sys/ioctl.h>        <---------------------  LOOK HERE
       int ioctl(int d, int request, ...);
SOCKET(2)                  Linux Programmer's Manual                 SOCKET(2)
NAME
       socket - create an endpoint for communication
SYNOPSIS
       #include <sys/types.h>          /* See NOTES */             <---------------------  LOOK HERE
       #include <sys/socket.h>                                     <---------------------  LOOK HERE
       int socket(int domain, int type, int protocol);
GETSOCKOPT(2)              Linux Programmer's Manual             GETSOCKOPT(2)
NAME
       getsockopt, setsockopt - get and set options on sockets
SYNOPSIS
       int getsockopt(int sockfd, int level, int optname,
                      void *optval, socklen_t *optlen);
       int setsockopt(int sockfd, int level, int optname,
                      const void *optval, socklen_t optlen);
PeterO
holyhope
Thu Feb 09, 2017 3:56 pm
Hi PeterO
Many thanks for your answer... I have not thinked that those instruction was system library...
Now on my "helloword.c" file in netbeans I have write that include but netbeans still not reference them with CTRL+D (navigate to definition, or to header , etc.)
Now I read the manual with the man command and search something usefull about it!!!
For "read" packet in can bus do you know any example using that library?
Very many thanks!
Max
PeterO
Thu Feb 09, 2017 4:09 pm
SKPang has links to examples on his web page for the PiCAN2 board
I used the source code from linux-can-utils as the starting point for my own applications.
See http://skpang.co.uk/blog/archives/1199 for download instructions.
PeterO
holyhope
Thu Feb 09, 2017 4:29 pm
Hi PeterO
Yes I started from it cantest.c file to build my own application!
what I not found on this example is read from can bus. Maybe I'm wrong: I will analyze more deeper all souce code.
I will keep you informed
many thanks and have a nice day!
Max
marcellatwin
Thu Jun 06, 2019 11:58 am
Not to resurrect an old thread, but in searching for a different but similar issue I came across this. Are you still having issues "reading" can bus messages? Cause I can totally help with that.
Thu Jun 06, 2019 12:57 pm
Except....you ressurected an old thread and the user in question hasn't logged in for two years...
Will leave open, just in case.
Return to “C/C++”
