tito-t
question about printf() in a pthread thread
Thu Oct 20, 2016 8:11 pm
hello,
I encountered an unexpected behaviour in a test program, writing a dot '.' each second in a proprietary pthread thread, just for monitoring that the program is still running:
volatile int running = 1;
void* thread1Go(void *) {
    unsigned long ms;
    ms = millis();
    while(running) {
        if ((millis()-ms) >=1000) {
            printf(".\n");
            ms=millis();
    return NULL;
in this case every second a dot is printed, one beyond the other, everything works fine.
but if I exchange
printf(".\n");
by printf(".");
this doesn't happen any more each second, but instead a long time nothing happens,and suddenly a line of several dots like "..........." is printed all at once, not monitoring each 1 sec by a single dot one behind the other.
Why is this so?
Is there a way to force a print-out even without the line feed '\n' in the print cmd?
- Tim
mutley
Re: question about ptintf() i a pthread thread
Thu Oct 20, 2016 8:20 pm
The stdout stream is buffered, so will only display what's in the buffer after it reaches a newline (or when it's told to).
So you can :-
1) Flush stdout after each print.
2) Print to stderr that's not buffered.
3) Turn off stdout buffering.
1) fflush(stdout);
2) fprintf(stderr, ".");
3) setbuf(stdout, NULL);
tito-t
Re: question about printf() in a pthread thread
Thu Oct 20, 2016 8:24 pm
wonderful, thank you very much! fflush(stdout); worked from the start! 8)
BTW, I meanwhile exchanged also the miilis() thing by sleep(1);
- Tim
Return to “C/C++”
