PeterO
How would you ...... in C ? (+ other C discussions)
Tue Oct 18, 2016 8:28 am
I often see the phrase "The Pythonic way" use to describe a python code fragment... Perl on the other hand is know for the phrase "Ther's more than one way to do it" which was on the front of an O'rilley Perl book.
But there seems to be no similar concepts for C. So , for a bit of fun, how about posting your favourite C idioms to solve some simple problems ?
So.... Given an integer "hours" which is guaranteed to have a value in the range 0 to 23, how would you print it in the form "12 AM", or " 1 PM".
GO !
PeterO
PS Updates the title to better reflect latest content.
JAVE
Re: How would you ...... in C ?
Tue Oct 18, 2016 8:35 am
Why would you mangle a perfectly good hour notation into the AM/PM abomination? :-P
PeterO
Tue Oct 18, 2016 8:40 am
JAVE wrote:Why would you mangle a perfectly good hour notation into the AM/PM abomination? :-P
I can only assume that since you didn't provide an answer then problem too hard for you ?
PeterO
B.Goode
Tue Oct 18, 2016 8:58 am
Because in the Real World 'Users' or their representatives in the project management process sometimes mandate solutions that we as developers think are sub-optimal. And the User is always right...
Also, without some other signifier to make it clear what representation is being employed an Hour field of, say, "11" is itself ambiguous.
And finally, it is just an exercise: I don't think Peter is trying to enforce a particular standard for displaying dates. The general class of problem of transforming data from an internal representation to something for display to a user is well worth study. Eg Master's courses in HCI and Design Patterns. It might be a useful 'kata' for Test Driven Design or Behaviour Driven Design.
jeanleflambeur
Tue Oct 18, 2016 9:10 am
tm time_data;
time_data.tm_hour = 21;
char buffer[10];
strftime(buffer, sizeof(buffer), "%I%p", &time_data);
gregeric
Tue Oct 18, 2016 9:14 am
if (hours==0) hours=24;
printf("%d %s\n", hours%12==0?12:hours%12, hours>12?"PM":"AM");
if (hours==24) hours=0;
PiGraham
Tue Oct 18, 2016 9:31 am
One way to do it in one line using I-line if ()?...:...:
#include "stdafx.h"
int _tmain(int argc, _TCHAR* argv[])
	for (int hours=0;hours<24;hours++)
		printf ("%2d %s\n",(hours>12)?(hours-12):(hours==0)?12:hours,(hours>=12)?"PM":"AM");
	return 0;
PeterO
Tue Oct 18, 2016 10:01 am
I would suggest you at least make sure your answer compiles and does what the specification asked for ! :roll: And you indicate any required header files/libraries.
PeterO
I must resist temptation to "mark the homework" ..
:lol: :lol: :lol: :lol: :lol:
rurwin
Tue Oct 18, 2016 10:12 am
if (h == 12)
    printf("%d pm", h);
else if (h >= 12 && h < 24)
    printf("%d pm", h-12);
else if (h == 0)
    printf("%d am", h+12);
else if (h >= 0 && h < 12)
    printf("%d am", h);
else
    printf ("invalid time: %d", h);
Because maintainability is always better than concise code.
OK, you twisted my arm.
printf ("%d %s", (h+11)%12+1, h < 12 ? "am" : "pm");
That demonstrates classic C-style perfectly: it's concise, elegant, there's no error checking and it's incomprehensible.
PiGraham
Tue Oct 18, 2016 10:28 am
[quote="PeterO"]I would suggest you at least make sure your answer compiles and does what the specification asked for ! :roll: And you indicate any required header files/libraries.
PeterO
Mine compiles in a console project in MSVC and outputs the required 12,1,2,3,4,5,6,7,8,9,10,11 AM, then PM.
I have added the include and a main() wrapper. The library could vary with system. MS default is vcrt.lib
Do you really want full boilerplate included?
I expected complaints about the poor readability of a single line, but sometime the in-line if can be useful. Not here though. Don't do that at home kids.
rurwin
Tue Oct 18, 2016 10:35 am
PiGraham wrote:
PeterO wrote:I would suggest you at least make sure your answer compiles and does what the specification asked for ! :roll: And you indicate any required header files/libraries.
PeterO
12 prints as 12AM ;)
PiGraham
Tue Oct 18, 2016 10:42 am
rurwin wrote:
PeterO
Yep, I missed an = from ">=12".
As you say, "classic c style" and incomprehensible (not really, once you know the operators). I suppose PeterO is really asking for best practice rather than "classic" style, but contrasts can be interesting.
topguy
Tue Oct 18, 2016 10:44 am
And 0 prints as ??
PiGraham
Tue Oct 18, 2016 10:47 am
Is use of library functions preferred?
PiGraham
Tue Oct 18, 2016 10:48 am
topguy wrote:And 0 prints as ??
12 AM
Here's the output for 0 to 23
12 AM
 1 AM
 2 AM
 3 AM
 4 AM
 5 AM
 6 AM
 7 AM
 8 AM
 9 AM
10 AM
11 AM
12 PM
 1 PM
 2 PM
 3 PM
 4 PM
 5 PM
 6 PM
 7 PM
 8 PM
 9 PM
10 PM
11 PM
PeterO
Tue Oct 18, 2016 11:00 am
PeterO
Don't worry, the comment wasn't aimed at you Graham.... I'll leave it to you to work out who's code dosen't compile :-)
Your's was fine, I just dropped it into my test harness and it worked, but your new version dosen't compile ! Did you try it before posting it :roll:
See later comments
PeterO
jahboater
rurwin wrote:
if (h == 12)
    printf("%d pm", h);
else if (h == 0)
    printf("%d am", h);
else
No error checking is needed see the question:
Given that, I quite like your short version. I don't normally like terse, "clever" code, but in this case its quite simple and I think there is less chance of bugs appearing in it than in your long code above. And you had to change the long version a couple of times.
printf ("%d %cM", (h+11)%12+1, h < 12 ? 'A' : 'P');
PeterO
Tue Oct 18, 2016 11:05 am
PiGraham wrote: As you say, "classic c style" and incomprehensible (not really, once you know the operators). I suppose PeterO is really asking for best practice rather than "classic" style, but contrasts can be interesting.
I'm more interested in the contrasts actually ! I was thinking about an example to use for explaining the "?:" operator, so my answer would have been a one liner like yours and rurwin's. But the more contrasting styles the merrier. There are no right or wrong answers , only those that work and those that don't compile :D :lol: :roll:
PeterO
PiGraham
Tue Oct 18, 2016 11:57 am
On the basis that reinventing the wheel is rarely time efficient here is a version using library function strftime
#include <time.h>
#include <stdio.h>
void main()
struct tm TimeValue;
        for (TimeValue.tm_hour = 0; TimeValue.tm_hour<24;TimeValue.tm_hour++)
                const size_t  maxsize=100;    // Lazy allocation of plenty of storage for the output string
                char TimeString[maxsize];
                size_t len;
                // strftime formats a tm structure representing a time
                // %I is hour in 12H format and %p is an AM, PM indicator
                len = strftime(TimeString, maxsize, "Time is : %I %p\n", &TimeValue);
                // len is length of the output string, or 0 if the buffer is too small
                if(len==0)
                    puts("Time string buffer too small\n");
                else
                    puts(TimeString);
PeterO
Tue Oct 18, 2016 12:07 pm
PiGraham wrote:On the basis that reinventing the wheel is rarely time efficient here is a version using library function strftime
Some "cut and paste" errors had crept in there, now fixed
PeterO
Paeryn
Tue Oct 18, 2016 12:16 pm
Not a nice example, but without using ?:
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
char *hour_str(int hour) {
  char *str;
  asprintf(&str, "%d %cm", hour-12*((hour>12)-(hour==0)), 'a'+(hour>11)*('p'-'a'));
  return str;
int main()
  int h;
  for(h = 0; h < 24; h++) {
    char *hstr = hour_str(h);
    printf("Hour = %d, string = %s\n", h, hstr);
    free(hstr);
  return 0;
PiGraham
Tue Oct 18, 2016 12:18 pm
Some "cut and paste" errors have crept in there.
PeterO
That's annoying. Cut and past between Edge and nano via putty doesn't work properly in either direction.
I have corrected the test in my previous post and it reads ok now, but copy and paste it back to the Pi and it gives lots of gcc errors. Maybe it's a Unicode thing.
gregeric
Tue Oct 18, 2016 12:24 pm
If your flight lands at either midday or midnight, you would be ill-advised to arrange for me to pick you up & quote me the time as 12AM or 12PM.
PeterO
Tue Oct 18, 2016 12:28 pm
Paeryn wrote:Not a nice example, but without using ?:
#define _GNU_SOURCE
It works so it must be allowed but I think because (to quote the man page) "These functions are GNU extensions, not in C or POSIX. " you must lose a point or two ;)
PeterO
PeterO
Tue Oct 18, 2016 12:29 pm
gregeric wrote:If your flight lands at either midday or midnight, you would be ill-advised to arrange for me to pick you up & quote me the time as 12AM or 12PM.
Reported as "Off Topic" !
PeterO
Return to “C/C++”
