Mahan_Micro
my problem with QT and TextBrowser
Mon Oct 03, 2016 8:31 pm
Hi
I have a form in QTcreator and I use serial port of RPI2.
I don't use any library like wiring pi, I write my code by linux file read/write function.
I can send any char by serial port,open and close port and...
I have a TextBrowser in my form and I want to show recieving buffer of serial port on it
I want a function that check the serial port for recieving always
and show the recieving in textbrowser (like a serial terminal) but I don't know how ?? !!! :?: :?: :?:
I can recieve 10 char in a simple program with :
count = read (fd,buff,10);
if (count > 0){
in QT ???
If your Dreams Don't Scare You , They Aren't Big Enough
topguy
Re: my problem with QT and TextBrowser
Tue Oct 04, 2016 9:17 am
You probably need to start a separate thread that will read the text from the serialport and then use some "append" method to add the text to the text-widget.
You might not be able to call the method directly so maybe use the Qt signal/slot functionality.
scotty101
Tue Oct 04, 2016 9:56 am
You could make use of the built in Qt Serial Port module.
There are some great code example at the link below
http://doc.qt.io/qt-5/qtserialport-examples.html
Odds are that you'll want to use a timer to periodically update the display with the data from the serial port.
Return to “C/C++”
