Mahan_Micro
closing serial port in QT
Sat Oct 01, 2016 7:07 am
HI
I am designing a GUI with QTcreator and I need to use Serial port on PI2.
I don't use any library and I write my code only with linux file function.
for example I have a buttom that opens the Serial Port :
int fd= open (...)
if (fd < 0) ..
else...
I want another buttom that close the port
after opening the port (in a simple C program) I can close the port with following code:
close(fd);
my problem : I want use this function in QTcreator for click slot of a buttom but QT cant recognize CLOSE() function with argumant
if I use close() (without any argumants) my GUI closed !
how I can close serial port with a BUTTOM ???
If your Dreams Don't Scare You , They Aren't Big Enough
scotty101
Re: closing serial port in QT
Sat Oct 01, 2016 8:54 am
Don't directly call the close function with a button press.
Create a separate function that contains the close(fd) and call that.
Mahan_Micro
Sat Oct 01, 2016 12:25 pm
scotty101 wrote:Don't directly call the close function with a button press.
Thanks a lot ! :) :) :)
Mahan_Micro
Sun Oct 02, 2016 8:19 am
I have another problem,If you can please help me :
I have a TextBrowser in my form and I want to show recieving buffer of serial port on it
I want a function that check the serial port for recieving always
and show the recieving in textbrowser (like a serial terminal)
I can recieve 10 char in a simple program with :
count = read (fd,buff,10);
if (count > 0){
Excuse me for bad English :|
Return to “C/C++”
